Thu, Nov 21, 8:08 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 21 4:11 am)
Subject: G3M One Vein on Bicep
flibbits ( ) posted Fri, 01 March 2019 at 3:10 AM · edited Thu, 21 November 2024 at 2:15 PM
See the image: https://i.ytimg.com/vi/nxrN2-FEkW0/maxresdefault.jpg
There are Add Some Veins and Vascularity for G3M. Both can add upper arm veins, but they add a bunch of veins - can't get the one big bicep vein look.
How would this be done? Any ideas?
FlagonsWorkshop ( ) posted Fri, 01 March 2019 at 3:08 PM
Easiest way would probably be a bump or displacement map fibbitts. Are you familiar with those? That's pretty much how those products work to start with. If you have one of those products, look at what map is loaded into the displacement channel, that's how you can get a start at it. You will need a program like Gimp or Photoshop
flibbits ( ) posted Fri, 01 March 2019 at 9:44 PM
I'll take a look. Thanks.
flibbits ( ) posted Sat, 02 March 2019 at 1:34 AM
Neither of the products I mention uses a bumb or displacement map as you mentioned. I checked geometry, displacement - nothing there when the vein products are applied.
hborre ( ) posted Sat, 02 March 2019 at 7:49 AM
The problem is that the posted image shows very prominent vein bulges which can cause other issues if a displacement map is used. The mesh may need to be modified to display such abnormal features.
skinklizzard ( ) posted Sat, 02 March 2019 at 10:31 AM
best bet would probably be a combination of a custom morph and a bump/displacement map for finer details on it if required. set G3M to base resolution and send him to hexagon (assuming you have it installed) then paint on the vein using the displacement brush and send him back to daz, this should work but I don't usually do character morphs.
flibbits ( ) posted Sat, 02 March 2019 at 12:42 PM
Thanks.
Found out those existing vein packages use HD morphs.
The displacement, even to a pretty extreme level, works well, I don't need it as extreme as it is in that image.
