Mon, Jan 27, 6:39 AM CST
Subject: Just installed Poser 11.2 and...
  • 1
  • 2
smallspace ( ) posted Thu, 19 September 2019 at 6:09 AM · edited Sun, 26 January 2025 at 3:35 PM
...everything went fine except that now Dimension 3D's XL - Content Library script no longer works. That's bad because I've been using it instead of Poser's default library for years and I don't want to go back. I've got a message into D3D and will see if he can fix it.
EClark1894 ( ) posted Thu, 19 September 2019 at 6:16 AM
D3D unfortunately passed away a few years ago. Try putting in a ticket with Renderosity and see if they can find the problem and fix it.
smallspace ( ) posted Thu, 19 September 2019 at 6:19 AM
Didn't know. Sorry to hear that.
Biscuits ( ) posted Thu, 19 September 2019 at 6:19 AM · edited Thu, 19 September 2019 at 6:20 AM
:( Ralf was a script wizard, very missed.
My 2D&3D Store
My Youtube Channel
smallspace ( ) posted Thu, 19 September 2019 at 6:30 AM
Where do I "put in a ticket" with Renderosity?
smallspace ( ) posted Thu, 19 September 2019 at 6:32 AM
This is the error I get when activating the script:
Traceback (most recent call last): File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 3059, in File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 3057, in main File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 26, in init File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 140, in init IndexError: list index out of range
smallspace ( ) posted Thu, 19 September 2019 at 6:39 AM · edited Thu, 19 September 2019 at 6:41 AM
Also, EZskin 2 no longer works. Doesn't like the new Poser's build number. Gives the error message, "EZSkin requires build 21462 or later. You have build 272. This script does not work with your version of Poser."
EZskin 3 does work, but version 3 leaves a lot to be desired compared to version 2, especially in the effects department.
EClark1894 ( ) posted Thu, 19 September 2019 at 6:45 AM
EZSkin 3 is a later build. You may have more luck with that one. Are you using the right files?
tkdrobert ( ) posted Thu, 19 September 2019 at 6:50 AM
I installed this last night along with the new content, however, I don't see Dawn, Dusk, or the new horse. La Feme is there a bunch of other new stuff, but not Dawn, Dusk, or the Horse. ????
Glitterati3D ( ) posted Thu, 19 September 2019 at 6:52 AM
Reinstall your python scripts. That should fix any issues you might have.
RobZhena ( ) posted Thu, 19 September 2019 at 6:57 AM
Jenn Blake confirmed that D3D’s scripts don’t work because of a reference to Poser version number and other unstated issues. Bondware is looking at the scripts, but somebody else owns them. I filed a ticket on it many weeks ago, and Bondware is well aware of the issue.
As to the Hivewire content, it’s available now.
Glitterati3D ( ) posted Thu, 19 September 2019 at 6:59 AM
tkdrobert posted at 7:58AM Thu, 19 September 2019 - #4362584
You did not download the final version, then. All the Hivewire content is available on the server now.
I would suggest you re-download the official program build as well.
RobZhena ( ) posted Thu, 19 September 2019 at 7:01 AM
By the way, I renamed my old Poser 11 folder Poser 11.1 before I installed the early adopters version. I changed my license for the SM copy at the SM website to permanent, so I can run the D3D scripts in that version when I need to.
smallspace ( ) posted Thu, 19 September 2019 at 7:02 AM
The EZSkin 3 is V 089. Don't know what version EZSkin 2 is because I can't load it!
smallspace ( ) posted Thu, 19 September 2019 at 7:15 AM · edited Thu, 19 September 2019 at 7:15 AM
If bondware would just release the next version of Poser as 11.2.462 or higher that would fix the EZSkin 2 problem.
smallspace ( ) posted Thu, 19 September 2019 at 7:26 AM
RobZhena posted at 5:23AM Thu, 19 September 2019 - #4362591
OK RobZhena, I just used the Smith Micro download manager to roll back to 11.1. Now how do I also change my license to permanent so I can do what you did?
ghostman ( ) posted Thu, 19 September 2019 at 7:35 AM
smallspace posted at 2:32PM Thu, 19 September 2019 - #4362599
You can't! All versions from Poser Pro 2014Game Dev and up will have to upgrade or else it will stop working as it says in all the emails from Rendo. Once you have the official 11.2 installed then you can set it to permanent.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
RobZhena ( ) posted Thu, 19 September 2019 at 9:00 AM
ghostman: I did it, so you can. Posted by rokket in another thread:
https://pgportal.smithmicro.com/
Go here, sign in and you have to option to make your license permanent, which means you won't have to connect to the internet to activate it again.
It worked for me. I'd do it now/now/now because the SM license servers are supposed to stop working today, I believe.
quietrob ( ) posted Thu, 19 September 2019 at 9:09 AM · edited Thu, 19 September 2019 at 9:18 AM
Bondware cant make our licenses permanent?
This doesn't make sense.
And now I'm reading that the scripts that most of use no longer work?
I am sorry but things seems a long way from fine. What do we do with our Poser 9? Will that no longer work? People are rolling back to 11.1, we are still going back to S/M to make our licenses permanent?
Did the downloads that I did yesterday have any meaning? Do people like me with slow connections have to go through that again?
Renderosity Bondware. What should we do?
jennblake ( ) posted Thu, 19 September 2019 at 9:09 AM
That permanent activation will no longer hold true. It may for a bit...but not indefinitely. You will at some point have to install the update...and that permanent licenses will cease to work also. You will need to submit a support ticket with us for us to then reset that for you on the new license server. 😄
RobZhena ( ) posted Thu, 19 September 2019 at 9:11 AM
By the way, I will use the Bondware version close to all the time because it is much better!
jennblake ( ) posted Thu, 19 September 2019 at 9:12 AM
😄 so do I!
jennblake ( ) posted Thu, 19 September 2019 at 9:13 AM
@quietrob We can...you need to request it be done...just like you did with SM. Just submit a ticket for it. 😄
quietrob ( ) posted Thu, 19 September 2019 at 9:28 AM
Re: Licenses being made permanent. I suppose I will do that. I am still quite confused though. I always thought we had a permanent license.
Also, I downloaded a lot of things yesterday. Should I download them again, today?
I think everyone here loves Poser so please understand our frustration at the thought of losing what has become part of our workflow.
quietrob ( ) posted Thu, 19 September 2019 at 9:49 AM
Oh and I hope you and Boni got some rest! Health is more important that Poser.
Snarlygribbly ( ) posted Thu, 19 September 2019 at 9:53 AM
smallspace posted at 3:51PM Thu, 19 September 2019 - #4362581
Also, EZskin 2 no longer works. Doesn't like the new Poser's build number. Gives the error message, "EZSkin requires build 21462 or later. You have build 272. This script does not work with your version of Poser." Send me a sitemail with your email address and I'll send you an updated version.
EZskin 3 does work, but version 3 leaves a lot to be desired compared to version 2, especially in the effects department. This makes Snarly sad
Free stuff @ https://poser.cobrablade.net/
Snarlygribbly ( ) posted Thu, 19 September 2019 at 9:55 AM
smallspace posted at 3:54PM Thu, 19 September 2019 - #4362579
Tell us what line 140 says and we can tell you what to change it to
jennblake ( ) posted Thu, 19 September 2019 at 10:19 AM
😄 It has to be moved. it has to be put on our license server. 😄
smallspace ( ) posted Thu, 19 September 2019 at 12:35 PM
Snarlygribbly: Tell me how to read and edit python script and I'll tell you what line 140 says.
Snarlygribbly posted at 10:33AM Thu, 19 September 2019 - #4362664
smallspace ( ) posted Thu, 19 September 2019 at 12:40 PM
Well, I'm glad I got your attention. Does this mean you'll fix EZSkin 2 to work with the new Poser?
Snarlygribbly posted at 10:39AM Thu, 19 September 2019 - #4362662
Alisa ( ) posted Thu, 19 September 2019 at 12:44 PM
tkdrobert posted at 12:37PM Thu, 19 September 2019 - #4362584
Those are there now. Click on Download Additional Content Files (License required), plug in your serial number for P11 and all the files will show up including the 6 HiveWire zips (Rendo combined a bunch of the products for the Poser download, so most of the zips will have the original HW zips inside of them)
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
smallspace ( ) posted Thu, 19 September 2019 at 1:01 PM
Looks like a Reality error as well:
"An errror occurred importing addon Reality : ERROR: need more than 3 values to unpack
An errror occurred importing addon Reality : ERROR: need more than 3 values to unpack"
smallspace ( ) posted Thu, 19 September 2019 at 1:04 PM
So now I've got both 11.1 and 11.2 to work and my license is set to "permanent". However, 11.1 still phones home and I'm afraid soon SM won't answer.
smallspace ( ) posted Thu, 19 September 2019 at 1:18 PM
BTW Snarly:
I'm sorry I said EZSkin 3 wasn't as good as EZSkin 2, but I really miss having the effects that are in EZSkin 2. Why didn't you include them in EZSkin 3?
smallspace ( ) posted Thu, 19 September 2019 at 3:13 PM
Ok. According to Notepad++, line 114 of the XL script says
I somehow doubt that is going to help...
RobZhena ( ) posted Thu, 19 September 2019 at 3:15 PM
smallspace posted at 4:15PM Thu, 19 September 2019 - #4362710
I guess we'll find out.
sloan ( ) posted Thu, 19 September 2019 at 3:54 PM
Reality issues should probably be reported to de guy who owns Reality, since it be an add-on built to work wif Poser and not de other way round.
Snarlygribbly ( ) posted Thu, 19 September 2019 at 4:11 PM
smallspace posted at 10:10PM Thu, 19 September 2019 - #4362736
True :( I didn't realise it was a compiled script.
Snarlygribbly ( ) posted Thu, 19 September 2019 at 4:16 PM
smallspace posted at 10:15PM Thu, 19 September 2019 - #4362701
I already have. I refer to my previous message inviting you to get in touch via sitemail so that I can send it to you :)
smallspace ( ) posted Thu, 19 September 2019 at 4:20 PM
In view of python incompatibilities, maybe Bondware should just undo the changes they made to Poser python and roll it back to the code they got from SmithMicro.
smallspace ( ) posted Thu, 19 September 2019 at 4:28 PM
Sorry Snalry, I was confused. I clicked on the "Snarly's Space" which came up as a dead link in the post. I didn't realize you wanted me to copy the email address.
Snarlygribbly posted at 2:25PM Thu, 19 September 2019 - #4362757
smallspace ( ) posted Thu, 19 September 2019 at 4:49 PM
Messaged you here.
DarksealStudios ( ) posted Thu, 19 September 2019 at 5:11 PM
i can't even open the program after installing the 11.2 "UNABLE TO CONTACT LICENSE SERVER" "you must have an active internet connection to renew your lease"
My Store   My Gallery    Contact
gate ( ) posted Thu, 19 September 2019 at 6:25 PM
DarksealStudios posted at 1:17AM Fri, 20 September 2019 - #4362779
I Would suggest that you go to C:-ProgramData-Poser-11 make a backup of this folder then delete it this causes to reset your activation just as if would be the first time. naturally hoping that they kept the same licence path
I had this issue a few times when building models in the Setup room and deleated wrong bones in the hierarchy it caused crashes that corrupted my licence files... it gave me the same error but after removing the folder i was able to reactivate the licence.
with a little hope this might work for you
DarksealStudios ( ) posted Thu, 19 September 2019 at 7:33 PM
i repeated the uninstall reinstall and now everything seems fine..... very odd. I didn't even need to reinstall my octane plugin or GoZ app.
RobZhena ( ) posted Fri, 20 September 2019 at 8:00 AM
smallspace posted at 8:59AM Fri, 20 September 2019 - #4362758
The core problem is that D3D's scripts aren't written to work with any new version of Poser itself.
Snarlygribbly ( ) posted Fri, 20 September 2019 at 8:09 AM
RobZhena posted at 2:04PM Fri, 20 September 2019 - #4362888
No - the core problem is that Bondware have changed the version number format of Poser, and reset the build numbering to 1. It used to be something like 11.1.0.35540, i.e four elements with the build number being the fourth one. Many scripts look for the build number to check for the availability of certain features. The new version is reported as 11.2 .272, i.e. only three elements, and a much lower build number. When a D3D script looks for the fourth element, it crashes. Even if it found it, it would decide that the Poser version was too old anyway. The fact that the reported version also has a space in the middle of it doesn't help either :)
RobZhena ( ) posted Fri, 20 September 2019 at 8:24 AM
Any new version was going to have a low build number.
Snarlygribbly ( ) posted Fri, 20 September 2019 at 8:27 AM
RobZhena posted at 2:27PM Fri, 20 September 2019 - #4362893
It's never happened before. That's how we got to 35,540.
tim ( ) posted Fri, 20 September 2019 at 8:28 AM
Site Admin
We'll look into this. What function is returning the version number with extra space?
Snarlygribbly ( ) posted Fri, 20 September 2019 at 8:38 AM
poser.AppVersion() The space isn't causing much of a problem, but the fact that it has changed format is.
Thanks for looking into it Tim!
  • 1
  • 2
