This is the error I get when activating the script:
Traceback (most recent call last): File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 3059, in File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 3057, in main File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 26, in init File "C:GrafikPoser 10 Pro 64RuntimePythonposerScriptsScriptsMenuDimension3DXL.py", line 140, in init IndexError: list index out of range
Also, EZskin 2 no longer works. Doesn't like the new Poser's build number. Gives the error message, "EZSkin requires build 21462 or later. You have build 272. This script does not work with your version of Poser."
EZskin 3 does work, but version 3 leaves a lot to be desired compared to version 2, especially in the effects department.
Jenn Blake confirmed that D3D’s scripts don’t work because of a reference to Poser version number and other unstated issues. Bondware is looking at the scripts, but somebody else owns them. I filed a ticket on it many weeks ago, and Bondware is well aware of the issue.
As to the Hivewire content, it’s available now.
tkdrobert posted at 7:58AM Thu, 19 September 2019 - #4362584
I installed this last night along with the new content, however, I don't see Dawn, Dusk, or the new horse. La Feme is there a bunch of other new stuff, but not Dawn, Dusk, or the Horse. ????
You did not download the final version, then. All the Hivewire content is available on the server now.
I would suggest you re-download the official program build as well.
RobZhena posted at 5:23AM Thu, 19 September 2019 - #4362591
By the way, I renamed my old Poser 11 folder Poser 11.1 before I installed the early adopters version. I changed my license for the SM copy at the SM website to permanent, so I can run the D3D scripts in that version when I need to.
OK RobZhena, I just used the Smith Micro download manager to roll back to 11.1. Now how do I also change my license to permanent so I can do what you did?
smallspace posted at 2:32PM Thu, 19 September 2019 - #4362599
You can't! All versions from Poser Pro 2014Game Dev and up will have to upgrade or else it will stop working as it says in all the emails from Rendo. Once you have the official 11.2 installed then you can set it to permanent.
"Dream like you'll live forever. Live like you'll die tomorrow."
ghostman: I did it, so you can. Posted by rokket in another thread:
https://pgportal.smithmicro.com/
Go here, sign in and you have to option to make your license permanent, which means you won't have to connect to the internet to activate it again.
It worked for me. I'd do it now/now/now because the SM license servers are supposed to stop working today, I believe.
Bondware cant make our licenses permanent?
This doesn't make sense.
And now I'm reading that the scripts that most of use no longer work?
I am sorry but things seems a long way from fine. What do we do with our Poser 9? Will that no longer work? People are rolling back to 11.1, we are still going back to S/M to make our licenses permanent?
Did the downloads that I did yesterday have any meaning? Do people like me with slow connections have to go through that again?
Renderosity Bondware. What should we do?
That permanent activation will no longer hold true. It may for a bit...but not indefinitely. You will at some point have to install the update...and that permanent licenses will cease to work also. You will need to submit a support ticket with us for us to then reset that for you on the new license server.
Re: Licenses being made permanent. I suppose I will do that. I am still quite confused though. I always thought we had a permanent license.
Also, I downloaded a lot of things yesterday. Should I download them again, today?
I think everyone here loves Poser so please understand our frustration at the thought of losing what has become part of our workflow.
smallspace posted at 3:51PM Thu, 19 September 2019 - #4362581
Also, EZskin 2 no longer works. Doesn't like the new Poser's build number. Gives the error message, "EZSkin requires build 21462 or later. You have build 272. This script does not work with your version of Poser." Send me a sitemail with your email address and I'll send you an updated version.
EZskin 3 does work, but version 3 leaves a lot to be desired compared to version 2, especially in the effects department. This makes Snarly sad
Free stuff @ https://poser.cobrablade.net/
smallspace posted at 3:54PM Thu, 19 September 2019 - #4362579
Tell us what line 140 says and we can tell you what to change it to
Snarlygribbly: Tell me how to read and edit python script and I'll tell you what line 140 says.
Snarlygribbly posted at 10:33AM Thu, 19 September 2019 - #4362664
Well, I'm glad I got your attention. Does this mean you'll fix EZSkin 2 to work with the new Poser?
Snarlygribbly posted at 10:39AM Thu, 19 September 2019 - #4362662
tkdrobert posted at 12:37PM Thu, 19 September 2019 - #4362584
Those are there now. Click on Download Additional Content Files (License required), plug in your serial number for P11 and all the files will show up including the 6 HiveWire zips (Rendo combined a bunch of the products for the Poser download, so most of the zips will have the original HW zips inside of them)
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
smallspace posted at 4:15PM Thu, 19 September 2019 - #4362710
So now I've got both 11.1 and 11.2 to work and my license is set to "permanent". However, 11.1 still phones home and I'm afraid soon SM won't answer.
I guess we'll find out.
smallspace posted at 10:10PM Thu, 19 September 2019 - #4362736
Ok. According to Notepad++, line 114 of the XL script says
I somehow doubt that is going to help...
True :( I didn't realise it was a compiled script.
smallspace posted at 10:15PM Thu, 19 September 2019 - #4362701
I already have. I refer to my previous message inviting you to get in touch via sitemail so that I can send it to you :)
Sorry Snalry, I was confused. I clicked on the "Snarly's Space" which came up as a dead link in the post. I didn't realize you wanted me to copy the email address.
Snarlygribbly posted at 2:25PM Thu, 19 September 2019 - #4362757
i can't even open the program after installing the 11.2 "UNABLE TO CONTACT LICENSE SERVER" "you must have an active internet connection to renew your lease"
DarksealStudios posted at 1:17AM Fri, 20 September 2019 - #4362779
I Would suggest that you go to C:-ProgramData-Poser-11 make a backup of this folder then delete it this causes to reset your activation just as if would be the first time. naturally hoping that they kept the same licence path
I had this issue a few times when building models in the Setup room and deleated wrong bones in the hierarchy it caused crashes that corrupted my licence files... it gave me the same error but after removing the folder i was able to reactivate the licence.
with a little hope this might work for you
i repeated the uninstall reinstall and now everything seems fine..... very odd. I didn't even need to reinstall my octane plugin or GoZ app.
smallspace posted at 8:59AM Fri, 20 September 2019 - #4362758
In view of python incompatibilities, maybe Bondware should just undo the changes they made to Poser python and roll it back to the code they got from SmithMicro.
The core problem is that D3D's scripts aren't written to work with any new version of Poser itself.
RobZhena posted at 2:04PM Fri, 20 September 2019 - #4362888
No - the core problem is that Bondware have changed the version number format of Poser, and reset the build numbering to 1. It used to be something like 11.1.0.35540, i.e four elements with the build number being the fourth one. Many scripts look for the build number to check for the availability of certain features. The new version is reported as 11.2 .272, i.e. only three elements, and a much lower build number. When a D3D script looks for the fourth element, it crashes. Even if it found it, it would decide that the Poser version was too old anyway. The fact that the reported version also has a space in the middle of it doesn't help either :)
poser.AppVersion() The space isn't causing much of a problem, but the fact that it has changed format is.
Thanks for looking into it Tim!
...everything went fine except that now Dimension 3D's XL - Content Library script no longer works. That's bad because I've been using it instead of Poser's default library for years and I don't want to go back. I've got a message into D3D and will see if he can fix it.
