Thu, Feb 13, 12:26 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
Subject: after dforce simu
atpo ( ) posted Mon, 09 December 2019 at 10:35 PM · edited Thu, 13 February 2025 at 12:24 AM
RHaseltine ( ) posted Tue, 10 December 2019 at 3:02 PM
I'm not quite sure what you mean, and the image of the Simulation Settings pane doesn't show whether you had Frames to Simulate set to Current Frame or Animated. If it was Animated, drag the play head to the end and you should see the final drape.
atpo ( ) posted Tue, 10 December 2019 at 6:37 PM
Thanks cat.😀 But not “”Current Frame or Animated“,the second choose.
RHaseltine ( ) posted Wed, 11 December 2019 at 9:21 AM
Yes, if you set it to Animated then the final drape would be in the last frame you simulated. Of course the plane does need to have enough divisions to bend - if that is a single division plane then it won't drape nicely whatever you do.
