Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Well, you asked ;). 1. I think the inside of the mouth is too pink and much too light in color. 2. Could you consider any other eyeshadow color than green? I know I personally used to avoid that color because I looked rather like a ghoul when I wore it ;). 3. The crease marks on the lips are too much straight up and down. Maybe angle them out a little more as they approach the sides of the lips. 4. The eyebrows are a bit too dense. You may want to thin them out just a little bit. Other than that, I think it looks okay. Certainly better than I could do ;). Laurie
Thanks I will thin the eyebrows and work on the lip lines, I knew the tongue was to pink so I will fix that too :) Thanks :)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
System Ram: 8GB
This is looking really good. Couple of suggestions. The eyeshadow looks much better, but try softening the eyeliner with a smudge brush. It's too dark and harsh. Also, clone out the highlights from the eyes (I'm assuming you used a photo for the irises). dina's cornea layer will let you make very convincing and more realistic highlights by adjusting the reflection. Also, try making the wrinkles on the bottom lip less straight up and down. They should follow the curve of the lip.
Lookin' good Poketdots ;-) 2 suggestions... Lower eyelashes need to be less well defined. Try using a finer line in your graphics program to make them. The edges on the eyebrows look to harsh, try softening then a bit. I have Dina and know how thin the actual outer mesh is so you may just want to put them on the actual face map so you can make them more feathered ;-)
Ok, I'm gonna give it another try :) lol, by the way those are my lips on her :) so MY lip lines are off! roflol And the eyebrows are painted on the texture,, so a thinning I will go!
System Ram: 8GB
System Ram: 8GB
oops! lol thats my tongue too :) I have lines and shading in the eyewhites, but I can't figure out why it doesn't show, I will try and fix that :) Thanks Nathalie :)
System Ram: 8GB
Pokeydots, I have found that the colors in the eyewhites tend to get washed out, I think because poser eyes are set to be very reflective. To compensate, I either make the texture much darker/richer than looks right unrendered, or set the material color to a cream color, so that gets multiplied into the texture
Wow, that tongue IS great! Sallie, the lip thing may be happening because of the way you are applying the lip photo to the map. If you look at a straight on photo of lips, you will see that the lines appear to curve inward toward the mouth toward the edges. If you are applying a 3/4 view photo to the map or one that was taken at an angle from below, you will get lines running the wrong way. One easy way to fix this is to use a liquify brush and push the lines a little.
Okey dokey, I will try try again :) Thanks!
System Ram: 8GB
Thanks ! And no I didn't put my tongue on the scanner!! lol I have a digital camera :) Hmmm but I do have dentures, maybe I could scan them for the teeth!!!
System Ram: 8GB
Looking really good. My one suggestion would be to tone down the nostrils a little bit. I know we don't want them glowing, but I personally don't like to see them looking like an obvious brown spot. One suggestion would be to "smudge" some of the face into the nostrils. It makes it a little more subtle of a shift.
System Ram: 8GB
