Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Hmmm I see the new threads - what to do if almost all of my renders are La Femme IN Superfly? Choices, choices~~
- - - - - -ย
Feel free to call me Ohki!
Well, right now all I got are wips.
Wips of the hairy kind, but Superfly nonetheless I love how good Superfly is at rendering all those hair strands. They don't slow it down.
- - - - - -ย
Glitterati3D posted at 11:36AM Fri, 14 February 2020 - #4380428
What are your settings?? I see no grain whatsoever!
knyghtmare2021 posted at 12:49PM Fri, 14 February 2020 - #4380435
I did not save the file after the render so I can't tell you which lights I used, but I can tell you they were Superfly specific lights because I always use SF lights.
I render CPU. These are my settings for every render:
Kalypso posted at 2:37PM Fri, 14 February 2020 - #4380451
Great lighting in the outdoor scenes Glitterati3D and the water is very realistic. Are you using EZDome?
In some of them, yes. Others I might use Flink's sky. I do, however, almost always enclose my renders in something MUCH smaller than the Construct to get light bounces around my subjects.
As for the water, in almost all cases of water I use Vince Banga's or Ghostship's water shaders for Superfly. If I'm adding things like Flink's Water FX or those rings around the dabbling duck (an object freebie from ShareCG) I use Vince Banga's shader.
knyghtmare2021 posted at 6:44AM Sat, 15 February 2020 - #4380545
Think this one turned out better, same characters, different poses and set. I think I'm gonna need to invest in some SF lights... why not take a look at my free light set at ShareCG first? http://www.sharecg.com/v/86639/browse/11/Poser/Studio-Portrait-Lights-for-Poser-11-Poser-11-Pro
AppleJack's Futuristic Train:
A wooden bookend transforms into a faerie door during the night...
Commander's office, Atlantis:
Poser 12, in feet.ย ย
OSes:ย Win7Prox64, Win7Ultx64
knyghtmare2021 posted at 10:47AM Sat, 15 February 2020 - #4380554
Thanks Ghostship! Downloaded!
So what is the difference in lights from earlier versions and lights specifically for Superfly? I know Superfly utilizes light emitting props to create light by default, but is there any other difference?
Poser 11/ Superfly adds area lights which function like mesh lights. You'll get soft shadows with area lights. It's hard to describe but I'd say that depending how you use them they can look more realistic than the other Poser lights.
ghostship2 posted at 1:27PM Sat, 15 February 2020 - #4380592
Thanks! Do you have any tips on how to optimize the render? I want to use Superfly for production of my comic, so I need to figure out a work flow to get the renders I need with out taking hours and hours if possible
@Ironsoul That is awesome! @knyghtmare2021 I'm probably the wrong guy to ask about optimization. I use two GTX cards and run settings that get me good results. How you light the scene is going to play a big roll in how many samples you need to render a shot. A skydome with a JPG for lighting will render cleaner than using an HDR but the lighting will be homogeneous. I'll try to render an example.
knyghtmare2021 posted at 2:29PM Sat, 15 February 2020 - #4380601
here are two examples with same settings but the only thing changed is the image used on the skydome. The JPG renders 30 seconds faster AND has less noise but the lighting is very homogeneous and bland whereas the HDR takes longer, and needs a lot more samples to become noise free but has more dramatic highlights and shadows.
I love Superfly and that is all I use these days.
Using a Dome for lighting.
Using only area lights
ย
ย
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 -ย Ryzen 9ย 5900HX,ย with 64 gig ram and 3 TBย storage, mini PC with final rendering done on normal sized desktop using anย AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU .ย ย The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
Mixed lighting.
A Dome - Flinks Sky2 Sunset, a couple of spots on the faces and then emissive materials on the lamps and candle flames.
ย
ย
knyghtmare2021 posted at 1:06PM Mon, 17 February 2020 - #4380601
My personal opinion would be to avoid using Superfly or any PBR renderer for comic reproduction. Especially if your goal is to speed things up.
knyghtmare2021 posted at 12:52AM Tue, 18 February 2020 - #4380601
Avoid transparency and reflection :)
EClark1894 posted at 12:07PM Tue, 18 February 2020 - #4380791
Yeah, thats the decision I came to.
You're going to have to change the lighting in the one with the white floor. The light is shining right down onto the floor wiping out the gloss completely. You've got blowout because of the position of your light. The one on the right looks like she's trying to skate on wet gravel. The expression on her face is just weird.
This thread is for all Superfly renders. Post, comment, experiment, ask and learn more about Superfly!
