Mon, Feb 17, 2:28 PM CST
Forum Moderators: RedPhantom
Subject: Rendered in Superfly
Glitterati3D ( ) posted Tue, 18 February 2020 at 8:52 PM · edited Tue, 18 February 2020 at 8:53 PM
wolfmanjim posted at 9:46PM Tue, 18 February 2020 - #4380974
So, how do I change the 'gravel' texture?
I don't know. Where's it from? Change the diffuse map to get rid of the gravel. But you're going to be right back at the same place with blowout because of the light with a light color. Do you have a dome on the scene? Something smaller than the Construct?
Try lighting it with EZDome sIBL lights for EZDome here
hborre ( ) posted Tue, 18 February 2020 at 9:15 PM
Online Now!
We will need to take a look at the material room with all the nodes uncollapsed to make an assessment. As mentioned, your lighting could be too harsh for the scene. Lower light intensity and a dome might be the answer.
hornet3d ( ) posted Wed, 19 February 2020 at 5:50 AM
Boni posted at 11:47AM Wed, 19 February 2020 - #4380957
I actually like the graininess on this one. Was working on getting enterestion eye effects.
There are certainly renders where grain actually adds something and this is certainly one such render. It can add to the atmosphere or, in certain cases add some' dirt to a night or dirty scene.
wolfmanjim ( ) posted Wed, 19 February 2020 at 9:27 AM
OK, here are the material settings for the two skating renders. The no reflection one is on the left and the reflective one that has the ugl colors is to the right.
The presence of the bump map seems to make no difference.
I used the ice shaders in the Vincebanga Supperfly Shader set from the RM marketplace for them both. One is on the left and two is on the right.
hornet3d ( ) posted Wed, 19 February 2020 at 9:41 AM
wolfmanjim posted at 3:31PM Wed, 19 February 2020 - #4381017
I am no expert but I doubt much can be gathered from the screen captures you have shown, one help would be to expand the materials to see more details. To do this you would need to click click on the down arrow on the ice panel but posting this expanded material might just breach the usage agreement of the material.
DreaminGirl ( ) posted Wed, 19 February 2020 at 10:56 AM
Um, you really shouldn't be posting commercial shaders like that.. that's called copyright violation, unless the creator gave you permission
hornet3d ( ) posted Wed, 19 February 2020 at 11:35 AM
DreaminGirl posted at 5:27PM Wed, 19 February 2020 - #4381029
I was uneasy with it but at least the screen captures so far show limited info. I was trying to find a balance between suggesting that what has been posted is not enough to rectify the problems but anything else would probably be too much. I have used the Vince Banga Superfly Shader sets for a year of more and they are great so I would not want to encourage anything that would impact their use and/or sales.
There is a great deal of information supplied with the sets and they encourage users to experiment but to do this you would need to be able to expand the compound node.
RedPhantom ( ) posted Wed, 19 February 2020 at 2:50 PM
Site Admin Online Now!
For ice 2, if you look into the compound node, you'll see a colorramp and a noise texture. Those are what is causing the mottled look. To get rid of it completely, delete those and adjust the fac on the mix closure they were connected to so that the ice looks like how you want. If you don't mind a little mottle, adjust the colors so they are closer together. Darker colors make it more opaque, lighter more transparent.
ironsoul ( ) posted Wed, 19 February 2020 at 4:15 PM · edited Wed, 19 February 2020 at 4:16 PM
A couple of attempts at using the scatter volume node to create lighting effects after many hours of frustrating tweaking. Curious if anyone has mastered this node and if there were any tutorials on the subject?
Glitterati3D ( ) posted Wed, 19 February 2020 at 5:16 PM · edited Wed, 19 February 2020 at 5:22 PM
ironsoul, that 2nd image is especially nice!
Don't know if it's still there, but Bagginsbill did a good tutorial on adding atmosphere to Superfly on the SM Poser forum. It is searchable.
Here's one, though not the one I spoke of above: https://forum.smithmicro.com/topic/913/atmosphere-in-superfly
ironsoul ( ) posted Wed, 19 February 2020 at 5:40 PM
Many thanks Glitterati3D, very helpful :)
Glitterati3D ( ) posted Wed, 19 February 2020 at 6:12 PM
ironsoul posted at 7:12PM Wed, 19 February 2020 - #4381083
You're welcome.
knyghtmare2021 ( ) posted Wed, 19 February 2020 at 8:25 PM
Online Now!
ypvs ( ) posted Thu, 20 February 2020 at 4:47 AM
V4 in the old Mediterranean Patio from DAZ. Scene is so old it was using gradient bump- now converted to Physical Surface. Lighting is single infinite and skydome.
My default render settings for sub 10 min render
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
Glitterati3D ( ) posted Thu, 20 February 2020 at 7:07 AM
Looks great ypvs. Well, except for the boob poke through and the shoe in the stones. :-)
The bump on the walls, bricks and stones is really good. And I love the lighting.
Glitterati3D ( ) posted Thu, 20 February 2020 at 7:09 AM
knyghtmare2021 posted at 8:09AM Thu, 20 February 2020 - #4381106
Wow, knyghtmare! Great render!
knyghtmare2021 ( ) posted Thu, 20 February 2020 at 10:25 AM
Online Now!
Glitterati3D posted at 10:25AM Thu, 20 February 2020 - #4381131
Thanks!
ypvs ( ) posted Sat, 22 February 2020 at 9:10 AM · edited Sat, 22 February 2020 at 9:17 AM
A WIP for a project I'm trying to get finished, featuring a tomb and a lady who will need no introduction. The hair needs a movement morph and the jewellery needs a colour boost, as well as the poke thru at the shin.
Having to remove alt diffuse and alt specular I find a real pain
bwldrd ( ) posted Sat, 22 February 2020 at 10:40 AM
Online Now!
I like the way this one turned out, so I'll go ahead and post.
Credits
AJ - Modern Interior 8 ; 3DC - Adriatic Scenes: Summervilla - Background Hemisphere ; LaFemme & Aryabella Hair ; CHK2033 - Eve Character ; Divabug - Kahlia Texture ; Gordo - Dynamic Kaftan Romper For LaFemme (Freestuff)
Consider me insane if you wish, but is your reality any better?
Glitterati3D ( ) posted Sat, 22 February 2020 at 2:43 PM
bwldrd posted at 3:42PM Sat, 22 February 2020 - #4381438
Credits
Great lighting and scene!
Glitterati3D ( ) posted Sat, 22 February 2020 at 2:47 PM
ypvs posted at 3:46PM Sat, 22 February 2020 - #4381421
Great scene and nice lighting. Always hated that skirt, it was such a PITA to get right.
Glitterati3D ( ) posted Sat, 22 February 2020 at 3:53 PM
Streets of Old London by Stonemason (objects imported to Poser and rigged) in Superfly.
ghostship2 ( ) posted Sun, 23 February 2020 at 4:30 PM
Online Now!
Glitterati3D posted at 3:28PM Sun, 23 February 2020 - #4381506
Great shot! You might try a wide screen aspect ratio with a large FOV setting and ad in DOF blur to make it feel larger.
Glitterati3D ( ) posted Sun, 23 February 2020 at 5:37 PM · edited Sun, 23 February 2020 at 5:37 PM
ghostship2 posted at 6:36PM Sun, 23 February 2020 - #4381608
Good idea.......assuming I can get DOF to work for me. For some reason I just don't get along with it.
ghostship2 ( ) posted Sun, 23 February 2020 at 6:56 PM
Online Now!
Glitterati3D posted at 5:40PM Sun, 23 February 2020 - #4381611
it's pretty simple. I don't do any calculations just eyeball it with a couple of rules in mind. The larger the camera focal equals a larger (longer) camera lens in the real world. a smaller lens would be used to get up close and personal with your subject. The camera is physically closer, the focus area is smaller so use a smaller fstop number on the camera controls. just make sure it's large enough to not make the figure look miniature. In your shot here you want a large lens and have the camera set far away and use slightly larger fstop to widen out the area that's in focus otherwise the scene will look like a miniature again. Here is an example where I have the camera pretty close to the subject and the focal set smallish (probably around 50mm) and the fstop just enogh to get her into focus but blur out the back side of the pool prop. Pool test.jpg
structure ( ) posted Tue, 25 February 2020 at 10:36 PM · edited Tue, 25 February 2020 at 11:43 PM
Forum Coordinator
Locked Out
hornet3d ( ) posted Wed, 26 February 2020 at 4:27 AM
structure posted at 10:26AM Wed, 26 February 2020 - #4381871
What a great set of renders, I love the middle one best.
ghostship2 ( ) posted Thu, 27 February 2020 at 5:44 PM
Online Now!
willdial ( ) posted Sat, 29 February 2020 at 7:04 AM
ghostman ( ) posted Sun, 01 March 2020 at 12:00 PM
The cool Marvin robot made by Dodger. :)
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
Lotharen ( ) posted Thu, 05 March 2020 at 6:24 AM
ghostship2 posted at 6:23AM Thu, 05 March 2020 - #4381989
Nicely done! Been thinking of moving from Daz to Poser since I see its getting a breath of fresh air and the other place is starting to irritate me.
ghostship2 ( ) posted Fri, 06 March 2020 at 11:08 AM
Online Now!
thanks! I've tried to get on with DS but I just can't. Poser is like an old friend to me and using it is like a form of relaxation.
ghostship2 ( ) posted Fri, 06 March 2020 at 11:10 AM
Online Now!
willdial ( ) posted Wed, 11 March 2020 at 8:29 PM
RedPhantom ( ) posted Mon, 16 March 2020 at 11:49 AM
Miss B ( ) posted Mon, 16 March 2020 at 12:54 PM
Very nicely done Red. I'm liking this a lot. 🙂
_______________
Butterfly Dezignz
TwiztidKidd ( ) posted Thu, 19 March 2020 at 11:10 PM
Victoria 4 in Poser looking cute lol
bantha ( ) posted Mon, 23 March 2020 at 3:29 PM
A test render, which came out better than I thought.
-"Amazing Grace" Hopper
hborre ( ) posted Mon, 23 March 2020 at 10:26 PM
Online Now!
After a very long absence, I will be posting images again in the gallery. Here is something I've been working on:
Inspired_Art ( ) posted Fri, 03 April 2020 at 3:48 AM
Just a question, is the grain in Superfly controllable at all? I'm looking for grainless render here. Superfly Render and Settings.jpg
Eddy
hborre ( ) posted Fri, 03 April 2020 at 8:04 AM
Online Now!
You can start off with increasing the number of pixel samples. The more pixels, the cleaner the render becomes. This will be at the expense of longer rendering.
hornet3d ( ) posted Fri, 03 April 2020 at 12:30 PM
Now running 11.3
ghostship2 ( ) posted Fri, 03 April 2020 at 6:07 PM
Online Now!
If you remove the background construct and replace it with EZDome or BaginsBill's Envirosphere and use a low res jpg on it for lighting that will cut down on noise as well. Inspired_Art posted at 4:05PM Fri, 03 April 2020 - #4385285
ghostship2 ( ) posted Fri, 03 April 2020 at 6:26 PM
Online Now!
@Hornet: Poser users like to show their work. What I mean by this is that they like to show off the background props when they've spent time setting them up. That's fine except it distracts from the main "focus" of the image. Focus is what you should be using in this image to separate the figure from the background. In Superfly it really doesn't add any render time to check the DOF box and set the camera focus. Even if this is just a background image or the back of the Envirosphere get into the habit of setting up your focus and rendering with DOF on.
hborre ( ) posted Fri, 03 April 2020 at 10:25 PM
Online Now!
I agree with ghostship2, using DoF selectively will add more interest and focus on the scene. The other thing that bothers me is the lack of life in the eyes, there are no highlights to spark interest. A small light source can bring out the sparkles.
ghostship2 ( ) posted Fri, 03 April 2020 at 10:59 PM · edited Fri, 03 April 2020 at 11:00 PM
Online Now!
hborre posted at 8:55PM Fri, 03 April 2020 - #4385388
Here is an example with a room prop. DOF set so the room is blurred. This image also shows off my other trick for getting life into the eyes. Turn the figure's head away from the camera and then point the eyes back at it so they are looking at you. BedroomSmall.jpg
hornet3d ( ) posted Sat, 04 April 2020 at 3:34 AM
Thank you both for your comments, I will rework the render in question incorporating the suggestions you have made.
hornet3d ( ) posted Sat, 04 April 2020 at 5:39 PM
OK so here's the second attempt.
ghostship2 ( ) posted Thu, 09 April 2020 at 9:09 AM
Online Now!
That looks better! hornet3d posted at 8:04AM Thu, 09 April 2020 - #4385485
ghostship2 ( ) posted Thu, 09 April 2020 at 9:10 AM
Online Now!
