Sun, Jan 5, 5:24 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 30 12:17 pm)
banner
Subject: Bug in Fitting Room?
RAMWorks ( ) posted Fri, 28 February 2020 at 10:55 AM · edited Fri, 03 January 2025 at 5:03 AM
Hi,
I've tried and tried and tried to get my cloth into the fitting room with La'Femme or L'Homme and it will NOT show. Yes, I have created "New" and loaded up the cloth prop and the figure, see below. I'm using the newest version of Poser!
Thanks for any tips or help understanding this!
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
hborre ( ) posted Fri, 28 February 2020 at 2:47 PM
The default settings look fine, however, do you see both the figure and cloth in the preview windows? You are not including those in your image.
Kalypso ( ) posted Fri, 28 February 2020 at 5:55 PM
Site Admin Online Now!
Also you have Display weights checked. You won't see the cloth itself that way but the weights on the whole of the clothing item. Uncheck it and you will see the item itself. If you haven't modified the UI, it should be on your right. You'll see your figure and the cloth on it and be able to see all the changes you make.
RAMWorks ( ) posted Sat, 29 February 2020 at 9:00 AM
The reason I didn't include the scene is because there is nothing to show. I even did a render, rendered blank. Didn't matter about Display Weights, those are checked by default, I simply turned them off to see if the figure would pop up but didn't.
My Store is HERE
nerd ( ) posted Sat, 29 February 2020 at 3:50 PM
Forum Moderator
Just to check the obvious, make sure the camera is framed. In the lower left of the camera gizmo click the camera frame button [0].
RAMWorks ( ) posted Sun, 01 March 2020 at 10:54 AM
Yes, tried all that too! LOL
My Store is HERE
RAMWorks ( ) posted Sun, 01 March 2020 at 12:15 PM
So installed the Release Candidate, that's fixed the issue in the Fitting Room.
Now I need to figure out what I did wrong with fitting. The Cat suit is a full suit minus the head. The only thing that's become a conforming item is the shorty shorts and the collar. The rest of the suit sort of just went away strangely enough. See the screen gab below of the entire thing. Just imagine that when it was all done the collar and the shorts were all that came over to the Pose Room! WEIRD!
My Store is HERE
