Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Sep 13 6:20 am)
Also you have Display weights checked. You won't see the cloth itself that way but the weights on the whole of the clothing item. Uncheck it and you will see the item itself. If you haven't modified the UI, it should be on your right. You'll see your figure and the cloth on it and be able to see all the changes you make.
The reason I didn't include the scene is because there is nothing to show. I even did a render, rendered blank. Didn't matter about Display Weights, those are checked by default, I simply turned them off to see if the figure would pop up but didn't.
---Wolff On The Prowl---
So installed the Release Candidate, that's fixed the issue in the Fitting Room.
Now I need to figure out what I did wrong with fitting. The Cat suit is a full suit minus the head. The only thing that's become a conforming item is the shorty shorts and the collar. The rest of the suit sort of just went away strangely enough. See the screen gab below of the entire thing. Just imagine that when it was all done the collar and the shorts were all that came over to the Pose Room! WEIRD!
Hi,
I've tried and tried and tried to get my cloth into the fitting room with La'Femme or L'Homme and it will NOT show. Yes, I have created "New" and loaded up the cloth prop and the figure, see below. I'm using the newest version of Poser!
Thanks for any tips or help understanding this!
Richard
My Store is HERE
My Freebies are HERE
