DAZ|Studio F.A.Q (Last Updated: 2025 Jan 22 11:25 pm)
Great, fighting the lighting right now as I can't see what I am wanting to render! image is flatish and too dark to see details . . . just now, in trying to find a fix for it, I ended up with ground and back ground when I want a transparent render . . . now got to fight that. Will switch to fold then and see if I can find that . . . LOL
Thank you
When you render, assuming you are rendering to a window, you have two lines under the image - the first is image name and type, the second is the library (default) or folder to save to - click the icon by the name and select the folder icon instead, then use a folder that isn't the render library folder for your saves.
I made the folder in my graphics folder to get away from the library images and they followed me; so there was a place where I could set the number of renders for the Render Library to 1, so I did that and made a sub folder to the other one nd changed the saving directory to that folder.
After un-installig and re-installing 3 times, I can't remember where I set it to 1 and they are back again. so am foinf to set the folder directory to someplace else and then just delete that folder and see if that works LOL Too many things I can't find, like how to shut off the background colors . . . brain is getting to old after.
How do I get rid, stop generation of the tiny rendered images along with the images I save?
