Sat, Feb 8, 12:04 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 06 11:16 pm)
Subject: no show weight map
atpo ( ) posted Tue, 19 May 2020 at 5:49 AM · edited Sat, 08 February 2025 at 11:59 AM
Excuse me! Right click weight map that no show next. I ever met same issue,but I forget to deal with it.image.png
RHaseltine ( ) posted Tue, 19 May 2020 at 3:14 PM
Is there a weight map applied?
atpo ( ) posted Tue, 19 May 2020 at 5:58 PM
Yes,thanks Cat.😀 Let me check.
atpo ( ) posted Tue, 19 May 2020 at 6:01 PM
But if applied, no show this ,which how to do? I met dforce same issue, which you told me how to do,but I forgot click what.😁
RHaseltine ( ) posted Wed, 20 May 2020 at 2:33 PM
I usually use the Tool Settings pane to assign and select maps. I had forgotten the option was in the right-click menu at all. If there is at least one map assigned to the item you are working on I don't know why it would not appear in the list, sorry.
atpo ( ) posted Wed, 20 May 2020 at 6:34 PM
Thanks Cat.😀 And "dforce same issue" ,you ever say set what button to let it display next, but I just forgot. I'd better search it again "what button".
RHaseltine ( ) posted Thu, 21 May 2020 at 3:03 PM
Sorry, for dForce you need Create>New dForce Modifier Weight Node then select the map in the Tool Settings pane.
atpo ( ) posted Thu, 21 May 2020 at 6:17 PM
Thanks Cat. But not .😀
RHaseltine ( ) posted Fri, 22 May 2020 at 4:51 PM
Could you give some more details of what you are asking about then? I am probably misunderstanding the question.
atpo ( ) posted Fri, 22 May 2020 at 6:14 PM
Yes,Cat.I ever post a tile about "dforce pane cannot show" ,but I only find forum has two page,which I cannot read others. And in that tile,you told me need update G8F and click one button to let dforce pane show next,namely show "that triangle next collapse". But I forgot that button. Thanks.😀
RHaseltine ( ) posted Sat, 23 May 2020 at 3:31 PM
The figure you have selected uses weight-mapped rigging, assuming this a joint you want to edit? And you open the Tool Settings pane and see the area at the bottom for showing the list of maps? is it empty or not? If it is empty, is the button labelled Unused maps just above it? If you click the unused maps button are there any entries in the pop-up menu? If there are, can you select one so that it appears in the list of active maps?
atpo ( ) posted Sat, 23 May 2020 at 6:57 PM
Thanks Cat. Let me check it. But now I only want to know that you told me that button on "dforce pane no show that triangle next" ,I just forget it, It is like xxx manage button.
RHaseltine ( ) posted Sun, 24 May 2020 at 2:17 PM
I am still not sure what you mean. Which tab of Simulation Settings are you using?
atpo ( ) posted Sun, 24 May 2020 at 6:24 PM
Thanks Cat.😀 I will find where I put your answer, yes I record it ever. You cannot answer this tile again.😁
atpo ( ) posted Thu, 28 May 2020 at 6:21 PM
Well ,Cat, I find that,which that is "windows-workspace-update and merge menu". Thanks.😁
RHaseltine ( ) posted Fri, 29 May 2020 at 9:20 AM
Ah, I see. Sorry I wasn't understanding the problem this time.
