Sat, Feb 1, 4:43 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Two questions about skin maps
RAMWorks ( ) posted Sat, 06 June 2020 at 5:49 PM · edited Wed, 29 January 2025 at 6:12 AM
Hi,
Still busily working on a couple of characters for Poser. I have some maps I made a while back for a DAZ Studio version and they are very saturated. They look fine with the shaders I made in DAZ Studio but as some know, I'm still feeling my way around Poser's Material room.
So is there a way to desaturate the maps a bit with an additional node?
Also what should a map look like or what type of map should be plugged into the Physical Surface Scatter node inputs. See below.
Thanks so much
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
EldritchCellar ( ) posted Sun, 07 June 2020 at 1:48 AM · edited Sun, 07 June 2020 at 1:55 AM
Color Math: hsv node
Distribution values, probably modulated in each channel by a distribution map or maps generated by something like substance painter. The PhysicalSurface root's intent is being utilized with maps rather than nodes from my understanding. Only guessing on this answer though. Probably Chuck or Ted could answer more accurately.
ghostman ( ) posted Sun, 07 June 2020 at 2:48 AM
The PhysicalSurface Root is for the PBR textures that is generated by Substance and Quixel and other programs that makes PBR textures. We asked for it in the early P11 beta at SM. It's made so that it's just to plugin the different PBR texture maps in a more direct and easy way.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
EldritchCellar ( ) posted Sun, 07 June 2020 at 5:30 AM
So I guess I guessed pretty good :)
RAMWorks ( ) posted Sun, 07 June 2020 at 9:39 AM
Not really understanding allot of that. I realize that it's for PBR but can be used for other things too so my main question was is there a math node or other node I can feed the texture maps through to desaturate them a bit from the color/diffuse channel hook up node?
I gave up on the scatter nodes as I think they work best with nothing attached to them. I was looking over an older thread over at Smith Micro using the scatter nodes to get that "behind the ear" lit effect via BagginsBill. So all I need is info on how to desaturate the maps, I know Photoshop is good for that but as I stated the maps are set up for DAZ Studio as well and the shader I have built there for the character looks fine. In Poser he looks like he got hit with an orange bomb and it's not the lighting, I've tried various lighting options and he still looks over saturated
Thanks so much Richard
My Store is HERE
hborre ( ) posted Sun, 07 June 2020 at 11:19 AM
As EldritchCellar mentioned in the above post, use the HSV node to control color and saturation. Plug the texture map into that and change the settings to something that will work for you.
RAMWorks ( ) posted Sun, 07 June 2020 at 11:30 AM
Gracias!
My Store is HERE
RAMWorks ( ) posted Sun, 07 June 2020 at 11:41 AM
OK, that works. Thanks so much! KEWL!
My Store is HERE
