Mon, Dec 23, 6:51 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 17 11:57 am)
banner
Subject: Where are the support files?!
KaoticLord ( ) posted Thu, 10 December 2020 at 5:54 PM · edited Mon, 23 December 2024 at 6:33 PM
So I've been Googling like crazy but can't find a damn thing. Where do I download the Poser 11 support files from?!
structure ( ) posted Thu, 10 December 2020 at 7:22 PM
Forum Coordinator
In poser 11 / 12 you will find the extra content files in the purchases tab on the library panel.
the support files are installed with the main program.
Locked Out
KaoticLord ( ) posted Fri, 11 December 2020 at 2:10 AM · edited Fri, 11 December 2020 at 2:12 AM
I don't seem to have them. "Poser Reference Manual.pdf" just tells me to go download and install them. I have Poser 11.0.8.34338, if that means anything.
RedPhantom ( ) posted Fri, 11 December 2020 at 6:13 AM
Site Admin
go to https://www.posersoftware.com/downloads/11 enter your serial number when asked. then you'll get a list of download files, including one called posersupport.exe.
hborre ( ) posted Fri, 11 December 2020 at 7:59 AM
You might as well update your software while you're at it. The current and final version is 11.3.818.
structure ( ) posted Fri, 11 December 2020 at 9:42 AM
Forum Coordinator
KaoticLord posted at 9:39AM Fri, 11 December 2020 - #4407062
11.0 is the last smith micro version of the software and will no longer work correctly ( if at all ) . Since ownership has changed, you should update your software as suggested by hborre.
Locked Out
Seliah ( ) posted Fri, 11 December 2020 at 4:00 PM
Question : My version of Poser is 11.2. To update to the current/Bondware version, should I just run the installer exe for 11.3? Do I need to uninstall 11.2 first?
Thanks in advance.
structure ( ) posted Fri, 11 December 2020 at 4:20 PM
Forum Coordinator
Seliah posted at 4:20PM Fri, 11 December 2020 - #4407149
Thanks in advance.
You can do either, installing over 11.2 would give the added option of retaining your current settings.
Locked Out
Seliah ( ) posted Fri, 11 December 2020 at 6:10 PM
OK. Thanks very much!
