Poser 12 F.A.Q (Last Updated: 2024 Aug 27 11:19 am)
I'm currently running a full backup on my MacBook Pro. It has several hours to go until completed.
If someone doesn't jump in and answer, I'll be installing the Poser 12 upgrade after the backup completes and will test this for you.
I do see where tburzio is using Poser 12 on their Mac. They haven't mentioned any issues with the parameter dials.
Lee
I did a reboot and the dials started working. I did all sorts of gyrations on Michael 4 and it seemed to go well. But...
Once I put his willie on, things went wonky. When I clicked part of the object to adjust it, the dial panel on the right didn't keep up. The top left said "M4 Genitalia Testicles" for instance, but the top of the dial window wouldn't update to the same part. Then I couldn't select parts of the model any more. And then the dials stopped working.
Maybe M4's willie is just too old...? (ug, there's a thought....)
ghostship2 posted at 9:34AM Fri, 05 February 2021 - #4411934
The snozzberries taste like snozzberries.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
I don't use Poser a lot, but I upgraded my Mac Poser 11 to 12. When I get a new version I set my default scene to a naked Michael 4. So today I put Mike on the stage, put on his "naked" skin and put on his genitals. So far so good.
Then as I set about trying to put everything in his/my default pose, I could not get the parameter dials to work. I could select the body part I wanted, but when I tried to use the dials to dial a setting...the dials don't move.
Did something change about the process that I'm missing? Or is this a bug? User error?
Thanks!
