Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Yes, attach a mask to the reflection value black for non reflective, white for reflective on the area you want to reflect. Quick example using the ball primitive.
Consider me insane if you wish, but is your reality any better?
And you'll want to invert the mask and apply that to the Diffuse_Value because whenever the specular reflection increases, the diffuse reflection decreases. Total reflection cannot exceed 1.
Here's an example of using a mask to control what is metallic/mirror, and the inverse of that mask for diffuse value.
Firefly render:
Superfly render (using metallicity in the PhysicalSurface root); I think I have the roughness of the metallic/mirror areas too high:
You can render the PoserSurface root in Superfly, though I zeroed out the displacement since Superfly doesn't have micropoly displacement.
OSes: Win7Prox64, Win7Ultx64
This might be a stupid question but... Is it possible to only have reflections on part of a single texture? For instance, if I have a bump map that raises a very specific area of a shirt, is it possible to only have the raised portion reflective?
