Mon, Jan 6, 7:52 PM CST
Subject: Can't poser Poser figure
randym77 ( ) posted Fri, 20 August 2021 at 7:09 PM ยท edited Sun, 05 January 2025 at 12:33 AM
Weird problem I'm having. Using Poser 11, but the same problem if I open the file with Poser 12.
The figure I was using became partly frozen. (It's M4, if that matters.) I was posing as usual, when all of sudden some of the dials stopped working. Not all of them, just some. For example, I can bend M4's chest, but not his neck or head. I can move his thumb, index, and little finger, but none of the other fingers. "Grasp" moves just the index and little finger. Applied poses work, but I can't adjust the frozen parts.
The figure isn't frozen. The hierarchy editor looks normal, except the top part of the figure was set invisible (but actually wasn't invisible). Toggling it didn't fix my problem.
Any way to fix this? I assume something's gotten corrupt, but ugh, I don't want to re-do this. I've put a lot of work into this scene.
ShaneNewville ( ) posted Fri, 20 August 2021 at 7:27 PM
what version of 12 are you using (as seen no splash screen)?
_____________________________
My most recent Poser animation:
Previs Dummies 2
primorge ( ) posted Fri, 20 August 2021 at 7:28 PM
Try saving a copy pz3 under a different name and load. Worth a shot.
randym77 ( ) posted Fri, 20 August 2021 at 7:48 PM
It's the same in Poser 11 and 12, so I don't think the version of Poser 12 is the issue.
I have tried resaving it with a different name, but there's no change. If I add a new M4 to the scene, I can pose him normally.
RedPhantom ( ) posted Fri, 20 August 2021 at 7:53 PM
Site Admin
a few things to try, checking that the parts didn't mysteriously get locked. You might also try using the replace option in the library to create a new figure. If you have autosave turned on, load one of those up to see if the figure is still good, and save that to the library and bring it into the current scene.
primorge ( ) posted Fri, 20 August 2021 at 7:59 PM ยท edited Fri, 20 August 2021 at 8:01 PM
RedPhantom posted at 7:58PM Fri, 20 August 2021 - #4425747
...Was also going to suggest to check if actor is locked. Select body part that refuses to rotate and object menu check to see if lock object is checked. There's also lock figure in figure menu. You suggest only parts are frozen though.
randym77 ( ) posted Fri, 20 August 2021 at 8:06 PM
How can I tell if Lock Object is on?
primorge ( ) posted Fri, 20 August 2021 at 8:07 PM ยท edited Fri, 20 August 2021 at 8:08 PM
It will have a check mark next to it
primorge ( ) posted Fri, 20 August 2021 at 8:17 PM
Are the dials for the rotations showing increasing/ decreasing values when you spin them but no result? Also, this is a long shot, double click a rotation (bend, twist, side side) dial that refuses to work (double click the dial itself) and this will bring up the dial settings. Check to see what the min max values are and if use limits is checked.
randym77 ( ) posted Fri, 20 August 2021 at 8:17 PM
Well, it looks like certain body parts are locked. But I can't un-lock them. This is so weird.
primorge ( ) posted Fri, 20 August 2021 at 8:34 PM
Did you uncheck the check next to lock object?
primorge ( ) posted Fri, 20 August 2021 at 8:37 PM
If that doesn't work and you really need those actors unlocked I can make you a pose file to force unlock them. I'd need to know which parts are locked though. Also I'm pretty sure there's a script around to force such operations. Do you have scene toy pro by netherworks?
randym77 ( ) posted Fri, 20 August 2021 at 9:01 PM
I don't think I have Scene Toy. I remember buying some Netherworks scripts from RDNA, back the day, but I don't remember which ones.
I can just re-do this scene. But I'm worried that this might happen again. I can't think of anything I did that would cause it.
primorge ( ) posted Fri, 20 August 2021 at 9:03 PM
Give me a few minutes and I'll write that unlock file.
primorge ( ) posted Fri, 20 August 2021 at 9:18 PM
This pose file will force unlock all actors in M4. If this doesn't work I'm stumped. Tested on M4 in PP11...
Unlock_M4
randym77 ( ) posted Fri, 20 August 2021 at 9:50 PM
Thank you. It did not unlock body parts I can't move. However, it does work very well for other parts. I suspect people will find your script useful, so you didn't waste your time.
And I think I figured it out. When I click on Edit Dependencies for the body parts I can't move, there's this extra line:
It says Left Hand::EMPTY-INVThreeFinger
It's the same for the other parts I can't move: neck, the fingers of the other hand, etc.
When I delete that line, the body part works normally.
I have no idea how that got in there. I don't even know what Edit Dependencies means, and would never try to mess with it.
primorge ( ) posted Fri, 20 August 2021 at 11:51 PM
It's a morph channel that hasn't had anything injected into it. Empty. DAZ readscript type morphs. A value operation multiply. I'm not at Poser right now to check but off the top of my head by the name it looks like it might be one of the Creature creator morphs (or similar) that gives M4 a three fingered hand, INV being a visibility toggle to hide fingers. The gap left in the mesh is covered by the morph part that pushes the mesh together to cover the gap. I created something similar in the past for V4 called V4AMP that makes V4 into an amputee.
Why such an empty morph channel would be freezing the figure and be existing in the neck also doesn't make sense, but many things don't.
randym77 ( ) posted Sat, 21 August 2021 at 12:05 AM
I own the Creature Creator morphs, but did not inject them, and I don't think any of the poses I used would inject them. I don't use them very often.
FWIW, the line in the neck says:
Neck::EMPTY-INVNeckGone
randym77 ( ) posted Sat, 21 August 2021 at 12:16 AM
Also...I did notice in the Hierarchy window that a bunch of the body parts were toggled invisible. The weird thing is, they weren't actually invisible. They were visible, I just couldn't pose them.
primorge ( ) posted Sat, 21 August 2021 at 7:10 AM ยท edited Sat, 21 August 2021 at 7:12 AM
randym77 posted at 6:42AM Sat, 21 August 2021 - #4425765
If you own a daz morph set and the data folders for that morph set are present in the !DAZ folder at the top of Libraries, when you run the .bat file all of the morph channels and groups will be present in the figure parameters in preparation for injection if you choose to do so. Each morph dial that hasn't had the INJ pose applied will have the EMPTY tag and won't have an effect. Probably most of the morph dials in your examples, that are basically utility dials (not meant to be manipulated by the end user but rather part of a controller, MCM, or JCM), are set to hidden by Daz. You can show all hidden dials by clicking the white pointing right arrow at the top right of the parm palette and checking 'Show Hidden Parameters'. I always have show hidden parameters enabled, for various workflow reasons. Sometimes it will make the palette a bit laggy because of the sheer number of dials visible. Usually you can overcome this by collapsing the 'other' group.
In terms of why the INV utility dials are causing actor lock I can't say. Perhaps the INV dials have a related lock actor feature but still this shouldn't be occurring if you didn't inject the associated morphs. Some bug I've never encountered.
primorge ( ) posted Sat, 21 August 2021 at 7:41 AM
...near as I can figure the bug is causing one part of Poser to see the actor as locked which is in conflict with another part which is seeing it as unlocked. Would explain why my unlock pose wouldn't work on those specific locked parts where the conflict is happening.
There's been a few people lately having gen 4 readscript weirdness with M4/V4 and Poser 11. Unresponsive dials mostly.
hborre ( ) posted Sat, 21 August 2021 at 9:41 AM
This almost sounds like the bat file was not run after the Creature Morph package was installed. My recommendation would be to run the bat file now and test the morphs afterward with a fresh M4 figure. If this is the case and the problem is cleared up then it is prudent to always run the bat file after every installation of a morph package as directed by DAZ.
randym77 ( ) posted Sat, 21 August 2021 at 10:59 AM
I always run the .bat file after installing DAZ morphs, and I wasn't even using the Creature Creator morphs. And I have used the Creature Creator morphs in the past, on this system, with no problem.
I did run the .bat file again yesterday, just because that often fixes that kind of problem, but it didn't help. And loading a fresh M4 in the same file worked fine.
hborre ( ) posted Sat, 21 August 2021 at 11:40 AM
Then it definitely sounds like corruption. I've had Superfly textures go completely wrong after multitudes of changes and setup. Not a pleasant experience when you have to replace something completely within a scene.
RedPhantom ( ) posted Sat, 21 August 2021 at 1:07 PM
Site Admin
You can try using replace to substitute a new mike into the scene so you don't have to redo everything, just the mike character.
If the scene is corrupt, you can save everything that works out to a temporary folder in your runtime and start a new scene and just load everything as is. You might even be able to save the morphs and texture for the corrupt figure.
randym77 ( ) posted Sat, 21 August 2021 at 3:41 PM
Everything is working fine now. I just had to delete Neck::EMPTY-INVNeckGone, etc. from Edit Dependencies in each affected body part.
ghostship2 ( ) posted Tue, 24 August 2021 at 9:28 PM
I didn't read all that just skimmed. Did you try creating a new Poser file and loading M4 into that to see if that has the same problems? If so, you might need to re-install or re-initialize M4.
randym77 ( ) posted Wed, 25 August 2021 at 6:40 AM
I just deleted the problematic lines from Edit Dependencies for each body part I wanted to pose, and everything was fine.
I had previously tried loading a new M4 into the same file, and it worked as usual.
