Sun, Nov 24, 8:45 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: Subdivision causing blurry texture
EVargas ( ) posted Mon, 30 August 2021 at 12:44 PM · edited Sun, 24 November 2024 at 8:35 AM
I imported an OBJ and assigned textures for its materials, it all looks reasonable but when I set subdivision level to 1 or greater (for preview or render) the texture gets blurry... I'm new to this system (I have not used Poser in years) so I might be missing something, any help would be appreciate!
PREVIEW OK (subdiv 0):
PREVIEW NOT OK (subdiv 1):
RENDERS S-SUPERFLY F-FIREFLY (SAME HAPPENS):
MATERIAL SETUP:
EVargas.Art
EVargas ( ) posted Mon, 30 August 2021 at 4:02 PM
Ok found something that maybe it's causing the issue. I noticed it only happens after I work with the Unwrap3D app, then I compared the OBJ version of ZBrush Vs Unwrap3D. The face count is the same but I'm losing some decimals on the vertices points.
EVargas.Art
caisson ( ) posted Mon, 30 August 2021 at 4:39 PM
There is a bug report in for this issue, has been for some time. It may be related to the issue with higher-res morphs, it's something to do with accuracy of vertex positions. Basically it's not a trivial problem, hence no fix yet. Please drop a bug report in via posersoftware.com if you can as the more feedback the devs get the better, thanks.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
EVargas ( ) posted Mon, 30 August 2021 at 4:52 PM
Ok thank you for pointing it out!
Well anyway some more from my recent attempt: if OBJ is not working then I thought: how about trying FBX? Ok I exported from UU3D as FBX, it really has more decimals... But when importing Poser crash on me... OMG o/ I'll update here in case it work later.
EVargas.Art
primorge ( ) posted Mon, 30 August 2021 at 7:30 PM
I've seen it before too, but in a bit different way. Especially on gradients. There's faceting on gradients when subdivision is applied. It's seems particularly bad on textures that occupy a very small area of an overall uv tile.
primorge ( ) posted Mon, 30 August 2021 at 7:40 PM
primorge ( ) posted Mon, 30 August 2021 at 7:43 PM
I can't really fault Poser for it. The example model is very poorly UV mapped in terms of texture space optimization. Still annoying when I discovered it. I think the figure was intended purely for toon shaders however.
EVargas ( ) posted Tue, 31 August 2021 at 8:45 AM · edited Tue, 31 August 2021 at 8:48 AM
Good news here, nothing like a good night of sleep and a brand new day! I was missing an important step before exporting from Unwrap3D, It's the "2D Tool/ Weld UVs". Now it works just like magic as expected! See images (using OBJ file format):
EVargas.Art
FVerbaas ( ) posted Tue, 31 August 2021 at 9:35 AM
Forum Coordinator
Good to see this is solved.
