Poser 12 F.A.Q (Last Updated: 2024 Nov 27 7:24 pm)
Ok found something that maybe it's causing the issue. I noticed it only happens after I work with the Unwrap3D app, then I compared the OBJ version of ZBrush Vs Unwrap3D. The face count is the same but I'm losing some decimals on the vertices points.
There is a bug report in for this issue, has been for some time. It may be related to the issue with higher-res morphs, it's something to do with accuracy of vertex positions. Basically it's not a trivial problem, hence no fix yet. Please drop a bug report in via posersoftware.com if you can as the more feedback the devs get the better, thanks.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
Ok thank you for pointing it out!
Well anyway some more from my recent attempt: if OBJ is not working then I thought: how about trying FBX? Ok I exported from UU3D as FBX, it really has more decimals... But when importing Poser crash on me... OMG o/ I'll update here in case it work later.
Good news here, nothing like a good night of sleep and a brand new day! I was missing an important step before exporting from Unwrap3D, It's the "2D Tool/ Weld UVs". Now it works just like magic as expected! See images (using OBJ file format):
I imported an OBJ and assigned textures for its materials, it all looks reasonable but when I set subdivision level to 1 or greater (for preview or render) the texture gets blurry... I'm new to this system (I have not used Poser in years) so I might be missing something, any help would be appreciate!
PREVIEW OK (subdiv 0):
PREVIEW NOT OK (subdiv 1):
RENDERS S-SUPERFLY F-FIREFLY (SAME HAPPENS):
MATERIAL SETUP:
EVargas.Art
