Poser 12 F.A.Q (Last Updated: 2024 Aug 27 11:19 am)
ghostship2 posted at 1:08 PM Fri, 12 November 2021 - #4430349Exactly my thought too.from my upcoming material set for P12 :background lighting and speculars.
Wooow 😍
_______________
Y-Phil posted at 8:47 AM Sun, 14 November 2021 - #4430503
La Femme: Ravena, by a friend: Silverwind 😍
WOW, I love this.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
I found lighting figures with the background very difficult as Poser shows only a restricted image of the background in preview, so I have tried another way. Render the scenes with the selected background and use an AI background remover to mask the image. Replace the background with the image but as a .jpg suitable adjusted, which should get you back to square one but now you have a layer of each which can be moved and adjusted accordingly. It will only works for figures and I suspect the same could be done with two renders, one for the figure and one for the background. Anyway this is what I achieved in about thirty minutes using an existing render.
hornet3d posted at 1:07 PM Sun, 14 November 2021 - #4430524
Actually, that's not correct, you can manipulate the background image if you are strictly using an image and not an HDRI. This is demonstrated here. And if you set the background image to cast light, there will be ambient lighting applied to the render as demonstrated below:I found lighting figures with the background very difficult as Poser shows only a restricted image of the background in preview, so I have tried another way. Render the scenes with the selected background and use an AI background remover to mask the image. Replace the background with the image but as a .jpg suitable adjusted, which should get you back to square one but now you have a layer of each which can be moved and adjusted accordingly. It will only works for figures and I suspect the same could be done with two renders, one for the figure and one for the background. Anyway this is what I achieved in about thirty minutes using an existing render.
No problem if I am using the background with an image but I was using the set up in the tutorial for using background lighting.
When set up like this my preview windows is shown like this.
and renders like this
I can change the rotation and of the back ground to change the position in relation to the figure but none of this is reflected in the preview.
It is unfortunate that such a feature doesn't exist in preview. The next best solution is to use the Raytrace Preview window to give you an idea of what the background scene will look like instead of using the render engine. I usually have that window available in the material room when fine-tuning adjustments.
As you say the Raytrace Preview window is a help and I also did a few low sample renders when I was getting close but it does mean that the process is more difficult than using a dome for lighting. Just not sure at the moment if the extra work when lighting from the background gives me anything better than a dome.
hborre posted at 10:20 PM Mon, 15 November 2021 - #4430607Hey!It is unfortunate that such a feature doesn't exist in preview. The next best solution is to use the Raytrace Preview window to give you an idea of what the background scene will look like instead of using the render engine. I usually have that window available in the material room when fine-tuning adjustments.
Bastep posted at 11:24 AM Wed, 17 November 2021 - #4430654
Thank you 😁Y-Phil posted at 4:47 PM Tue, 16 November 2021 - #4430636
Looks great. Especially the shadow on the bottom. Could you possibly answer a question about the shadowcatcher from EZDOME?Lit by an HDRi on the background node + the round Groundplane in shadow catcher
Greetings
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Ahh Okay! Then I have misunderstood something. I thought you were working with the Shadowcatcher from EZdome. I already knew the other one. But thank you! There is a picture for that:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
As I'm still on Poser 11 I'd love to know if there are any visible improvements in the Cycles/Superfly render engine in Poser 12. So far I understand that pixel-based displacement (as in Firefly) is still not possible. :(
Is there a difference when you render the same scene with the same render settings in Poser 11 and Poser 12? If so, a side by side comparison picture would be greatly appreciated.
I can show you my own, humble experience. I'm not an expert with the Material room, that's why the 3rd picture doesn't look exactly the same as the 1st and the 2nd.
The first two are based on EZSkiin3, using the Cycles plugin, with a slight difference: we have to lower the gloss effect with Poser12, for the rest both are 100% the same.
The lighting: a clamshell + one light above, all three are area lights, nothing around the scene except the backdrop.
My computer: an old Intel Core i7 at 4.3Ghz, the computations done using my RTX2080ti, each time using the official "Ultra NonBranched (GPU)" setting.
Don't forget that Poser12 has a new optimization system that is not present in Poser11
Each picture has been computed at 459x800px
Poser 11: 60"
Poser 12, using its default GTX mode: 34"
Poser 12, using its new RTX mode: 19"
Poser 12, using my shader (I'm using a second layer for the anisotropic/gloss effect): 32", and it takes longer without the second layer...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I don't have any side-by-side comparisons at this moment. There are some differences as they used an updated version of cycles for Poser 12. They added a few nodes. The sensitivity of the roughness of the various glossy nodes is different so some shaders may look too shiny. The shadow catcher now sort of works. It can be used with a background, but not with a skydome. The speed has improved and they've added adaptive sampling and a denoiser which can both help reduce time more.
Well, that depends on which Cycles method you are using. If you are incorporating the PoserSurface as your root node then I would tend to think that nothing has changed there. There have been some corrections with the PhysicalSurface between the 2 versions as mentioned in the above posts. There is also the addition of the PrincipledBsdf node in P12 that does not exist in P11, it makes assembling shader nodes better because many settings have been consolidated into 1 node. As for using the Cycles root node, again node setting corrections happen to be the main focus between the versions.Is there a difference when you render the same scene with the same render settings in Poser 11 and Poser 12? If so, a side by side comparison picture would be greatly appreciated.
Some things have already been mentioned here. What convinced me to use the Superfly renderer exclusively is the rendering speed of Poser 12. In Poser 11, the SF renderer was a lame duck and I only worked with the Firefly renderer. Since Poser 12, I have not used the FF renderer. Add to that the use of the Cycles nodes. Since I have worked a lot with Blender, I see this as a big advantage for me. To which there is a wealth of information and examples of Cycles material on the internet. Well, not everything can be implemented yet, because nodes are still missing, but I think the Poser developers are on the right track here.
Greetings
Translated with www.DeepL.com/Translator (free version)
Thanks a lot for all the responses to my question.
Before Poser 11 came out, I was desperate because of the limitations of Firefly. Superfly really opened up a whole new world for me and I haven't used Firefly ever since, except when I need some shadows for a photo background.
I understand that the speed of Superfly has doubled in Poser 12, which is a good thing, because all I could do to speed it up was throw more processing power at it. I also see the improvements on the different nodes, but I think unless pixel based displacement is introduced in Superfly, I will stay on Poser 11 for a while. Man, I really miss that feature. A lot.
....... but I think unless pixel based displacement is introduced in Superfly, I will stay on Poser 11 for a while. Man, I really miss that feature. A lot.
I think that you're not alone: a lot are still missing this feature,and hope is allowed, for this and for a preview that's able to use the Cycles nodes: a kind of Blender's Evee for Poser: they've enrolled a true Cycles expert, who used to work for Poser long time ago.
I don't remember his name but it looks like he's back
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
To say microdisplacement doesn't work at all with the superfly engine isn't exactly true. It depends on your root node. It works with the poser root node and the physical surface root node. It doesn't work with the cycles root node. Here is a sample. Each is the primitive ball (not the hi-res one). Each has poser's original noise node as the displacement map. The first is the poser root node, then is the physical surface, then cycles and cycles with the subdivision cranked up.
An up-close render of the 4th ball shows there is actual displacement going on, but I see no way of controlling the strength.
Even with a multiplicator or something like that?To say microdisplacement doesn't work at all with the superfly engine isn't exactly true. It depends on your root node. It works with the poser root node and the physical surface root node. It doesn't work with the cycles root node. Here is a sample. Each is the primitive ball (not the hi-res one). Each has poser's original noise node as the displacement map. The first is the poser root node, then is the physical surface, then cycles and cycles with the subdivision cranked up.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
RedPhantom posted at 7:53 AM Mon, 22 November 2021 - #4430760That I don't know. I'm not good with math when it's just numbers. Add colors and images, and I'm totally lost.Even with a multiplicator or something like that?To say microdisplacement doesn't work at all with the superfly engine isn't exactly true. It depends on your root node. It works with the poser root node and the physical surface root node. It doesn't work with the cycles root node. Here is a sample. Each is the primitive ball (not the hi-res one). Each has poser's original noise node as the displacement map. The first is the poser root node, then is the physical surface, then cycles and cycles with the subdivision cranked up.
RedPhantom posted at 9:38 AM Mon, 22 November 2021 - #4430766
Y-Phil posted at 8:38 AM Mon, 22 November 2021 - #4430763Ok, lol... You've launched me in a few experiments, I'll have to test further as I don't completely understand all the rules here, but but I've guessed is that if you use a difuse node for the Cycles root node, and you connect something that makes some "noise" in its "Normal" input, it seems to add some real displacement:RedPhantom posted at 7:53 AM Mon, 22 November 2021 - #4430760That I don't know. I'm not good with math when it's just numbers. Add colors and images, and I'm totally lost.Even with a multiplicator or something like that?To say microdisplacement doesn't work at all with the superfly engine isn't exactly true. It depends on your root node. It works with the poser root node and the physical surface root node. It doesn't work with the cycles root node. Here is a sample. Each is the primitive ball (not the hi-res one). Each has poser's original noise node as the displacement map. The first is the poser root node, then is the physical surface, then cycles and cycles with the subdivision cranked up.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Are you sure about that? And it's not just that your spheres have more polys than you think? Because I have used displacement with PhysicalSurface and I needed to raise the subdivision level a ton to get it to work on some props. I would have preferred not to because it cost a lot of render time.
Yes, all you have to do is take your displacement source (e.g. an image map) and plug it into a Math node, and then plug that into the Displacement input of the Cycles root node. I generally use Multiply. You can then raise or lower the amount of displacement by multiplying by more or less.
I did some more work on the background shader. Especially the use of radians instead of the usual degrees. The Firefly math nodes do not offer a solution here. But the Math Node from Cycles does. It has a much wider range of functions. And here we also find two functions to convert the rotation direction from radians to degrees and vice versa.
I have also uploaded the whole thing as a free item. This should be unlocked soon.
The whole thing now looks like this:
This is great! Thank you 😊
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
ChromeStar posted at 11:33 PM Tue, 23 November 2021 - #4430826
Here's a close-up of one of the spheres I used. I'll let you decide how high poly it is.>To say microdisplacement doesn't work at all with the superfly engine isn't exactly true. It depends on your root node. It works with the poser root node and the physical surface root node.
>Even with a multiplicator or something like that?Yes, all you have to do is take your displacement source (e.g. an image map) and plug it into a Math node, and then plug that into the Displacement input of the Cycles root node. I generally use Multiply. You can then raise or lower the amount of displacement by multiplying by more or less.
I'm not saying the displacement is perfect. It still has a long way to go. I was only trying to say it's not completely missing and you don't always have to subdivide the item to ridiculous degrees to use it. And yes, I'd like to see it work fully too.
Bastep posted at 4:26 AM Wed, 24 November 2021 - #4430829
The shader is now unlocked in the Free Items: Free Background ShaderI did some more work on the background shader. Especially the use of radians instead of the usual degrees. The Firefly math nodes do not offer a solution here. But the Math Node from Cycles does. It has a much wider range of functions. And here we also find two functions to convert the rotation direction from radians to degrees and vice versa.
Thank you 😊Bastep posted at 4:26 AM Wed, 24 November 2021 - #4430829
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Bastep posted at 11:45 PM Thu, 2 December 2021 - #4431205
Honestly: I don't remember, it's dated February 18, 2016.The picture looks good!
Greetings
PS: Where do you get the Superfly logo?
Here is the original that was be downloaded, and I slightly modified it to add a "12". It should be a png with transparent background
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thank you very much.Bastep posted at 11:45 PM Thu, 2 December 2021 - #4431205
Greetings
The way of the Nunja! Was watching the Simpsons and this came out of the blue. Yeah, they probably practice the ancient art of Nunjitsu, scribed in the Nunja Scrolls. Figure is V4, outfit by me. Rendered in Poser with Cycles OptiX.
Characters, Body Sculpts, Morph Corrections, Outfits, Python Scripts, Universal Heads, and Videogames!
Bastep posted at 2:01 AM Fri, 3 December 2021 - #4431210
Y-Phil posted at 1:19 AM Fri, 3 December 2021 - #4431209You're welcome 😊Thank you very much.Bastep posted at 11:45 PM Thu, 2 December 2021 - #4431205
Greetings
Have a great day!
Have a nice day, too
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Ken1171_Designs posted at 2:29 AM Fri, 3 December 2021 - #4431212
Great picture 🥰The way of the Nunja! Was watching the Simpsons and this came out of the blue. Yeah, they probably practice the ancient art of Nunjitsu, scribed in the Nunja Scrolls. Figure is V4, outfit by me. Rendered in Poser with Cycles OptiX.
It's always to see you around, Ken 😊
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
@ Bastep downloaded your background shader. Great stuff! I'm no good with math so this helps.
@ Y-Phil Nice! looks like folks are enjoying the new shaders.
@ Ken1171 https://www.youtube.com/watch?v=sqkowVU5mZI
@ ghostship2 Thank you 😊@ Bastep downloaded your background shader. Great stuff! I'm no good with math so this helps.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
experimenting with lighting and render settings. In this image I'm using TrekkieGrrrl's Render Room prop and 4 copies of a lamp from one of Santuzi's room models. I have placed one point light inside each lamp (set to inverse square and 4% intensity). The lamp shades have an inner mat and outer mat. The inner mat is set to ambient of 1 and the out mats are set to translucent (PBSDF node). Originally I had the inner shade mat set to transparent and the lamps looked f**king fantastic but there was too much noise being thrown out by this setup. The lamps are placed in the corners of the room and then I added 1 mesh light (a sphere) stuck into the middle of the ceiling like it was a ceiling lamp. That mesh has an ambient setting of 20. I kicked up diffuse bounces to 16 and set clamping to 0. The extra bounces brighten up the enclosed space a lot. There are still a couple of stay fireflies but that could be fixed in Photoshop.
I already have lights for Poser and the first collection of Poser 12 materials so my credit card is already primed and ready to go.
