Fri, Nov 22, 1:14 PM CST
Subject: Does P 11 run on Linus with Wine?
starlingblue ( ) posted Tue, 29 March 2022 at 4:25 PM · edited Fri, 01 November 2024 at 4:38 AM
I consider switching to Linux Mint with Wine, does anybody know if poser runs in this environment?
It seems that previous versions did run with Wine.
I have zero experience with Linux... I am just fed up with MS and want to try to switch
Penguinisto ( ) posted Wed, 30 March 2022 at 10:19 AM
Neither Poser or DAZ Studio run on Linux natively...
Not sure about P11, but here's what the WINE devs know about Poser's compatibility: https://appdb.winehq.org/objectManager.php?sClass=application&iId=115
(Last time I tried it was in 2004... it worked for the most part, but it was more than a little touchy back then. Hoping that 18 years may have improved things a bit for you... good luck!)
Cage ( ) posted Wed, 30 March 2022 at 11:08 AM
I used Poser Pro 2014 on Mint a bit in 2020.  It ran well enough on WiNE, although definitely slower than on Windows.  The main problem I had was the broken library, but that now affects all of the Poser 8 - 10 versions, and you wouldn't have to worry about it with P11.  A bigger complication for me was activating some of the lesser 3D programs that I use to support Poser.  It was possible, but I think I had to do some registry editing, copying entries from Windows to Linux.
