DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
Smart content is driven by the database, though nothing will show if the files themselves cannot be seen.
You don't need to search, just set the content directories to point to the correct folders (the one that holds the Runtime and Data folders - e.g. My Daz 3D Library if using the defaults) by right-click on Daz Studio Formatas and/or Poser Formats in the Content Library pane.
Took a look at the files I have transfered.
Currently -Documents/Daz3d studio
My Daz connect library
My library
Render library
All seem present. My Daz is large and does not visible as your previous statement.
Think I have found on the tabs where to tell Daz to look for old directory. Will try tonight hopefully.
First off Thank You Richard ! I have made some progress by wrapped my head around some aspects that may need to change.
I have reluctantly loaded Daz Central and reloaded some stuff.
I have recovered some of my Content Library and some of it works and some not. Would like to get that honed in if possible.
Still have original daztime on other drive that could be moved again if there is a better way to do it.
How about the database?
For Daz products, and soem products from other stores, you can reimport metadata - that will also catch any of your own metadata (recategorisations and your saved files) from before the last time you did an export userdata (if you did). The database on the old system will have everything that was, but it isn't possible to directly merge that with the dataabse on the current system so you risk losing metadata assigments either way with that.
Guess I learned more over the weekend. I reloaded some stuff and added a couple new things and still nothing works completely.
I for a long time have thought something in this daztime has caused my characters to be thicker and voluptuous than portrayed. Know I bought characters at Rendo and Hub that intruded in part or whole on base G8. Dug these out but suspected there was more.
So Richard where should I build my next Content Library?
If I leave the old library will this conflict with the old?
The location of your content directories is not significant, as long as you can access them. Yes, if one with "bad" files is still connected they will be read, unless the "good" version (if there is one) is earlier in the list of content directories. It does sound as if you have one or more morphs isntalled with a non-zero default - if you load the plain base figure and go to Edit>Preferences>Zereo>Zero Figure Shape does it change?
Your always helpful. You explained a way to look for this problem and that's helpful. Sure beats the heck out of watching models load or going through all ones morphs looking for problems.
You just hang tight and be observant because after loading Daz Connect my detailed mind is adding questions to a growing list.
Well that was an Epic failure. While my Content Library is showing my reloaded stuff everything in smart content is now hosed.
Still have pretty thumbnails but nothing in smart content is working. Daz attempted a 5000+ meta update that failed.
I think I'm grounded due to my limited net connection but the Bull in the china shop will inquire.
The metadata is a description of the content, rather than the actual content itself - it says which categories and products the files are part of, what type of file they are, what they are compatible with. What is happening with the Smart Content pane, and are other containers that depend on the database OK - the presets tabsd in various property panes, Categories and products in the Content Library pane, and the type tags (Actor, materials etc. at top-right of a file's thumbnail) in the Daz Studio Formats tree?
Daz Central is a simplified interface for Install Manager, Daz Connect is the system for installing through Daz Studio itself (Install pane or Smart Content pane or Products in the Content Library pane)
Not found and generating error messages or not found in that the sliders are not there?
Not that I want to send you on another sidetrack but the original Install Manager iss till avaiualble, it isn't a choice between Connect and Central only - there should be links on any product Library page for an item than can be installed through DIM.
Not found in the sliders. They don't show up UNLESS I load a figure then sliders are there and work. Loading a figure and trying to swap a head does not find the head morph. Loading 3 characters 2 with working morphs the 3rd will not see the morphs on the other 2. Hope ya understood.
Yes I understood once explained. Both could be used except for drai on bandwidth. Considered that. I seem to have more complications with central. Connect combined with meta seems to offer a more organized form I can tolerate.
If you uninstall stuff that still shows as installed by another emthod then DS will still show it as installed (and will load it if the files are really there).
The only way I can possibly think of for morphs to load onto previously saved items but not new would be if the morphs were in a nested content directory on saving (e.g. My Daz 3D Library/Content/Data/etc. with both Content and My Daz 3D Library set as content directories) - the saved scene might then be including the inner folder in the paths (/content/data/etc.) and if the files were still there they would load, but a newly loaded item would not check the Content sub-directory and so would not see or load the morphs. But that is a fairly arcane set of circumstances.
I have not tried loading previous loaded stuff yet. Old stuff still on other drive and when this problem developed I knew that was gone. Happened before with Daz 3 some years back. I have a dozen or so characters that are new made on this system. Loading them has not been attempted yet due to lack of assets loaded.
What I was saying before is if I load a character from content it loads true. It except morphs and modifications that are loaded FROM smart but loading something from content library does not see the morph even if another loaded character has the desired morph. Load Bob and Tom both load properly but I can not swap heads etc.
This applies to Content Library only. Smart seems fine. Products show up in content library as the should. Hierarchy appears ok.
2 g8s-As follows
One loaded as a character, say Betty. loads fine morphs intact. Morphs register in parameters fine. Adding additional morphs contained in content library are not to be found. This includes optional morphs such as nipples included with Betty. Non functional.
Second loaded "base character" but when you try to load Betty morphs the Betty morphs do not show up in parameters at all. Nothing that should show does not register in parameters.
Clothing and hair - The object in question loads fine and with mats. Mats seem to load correctly. Morph that should be in parameters are no present and pose morphs that are in content library are non functional. Wind hair poses , unbutton shirt do not work or fail to show in parameters.
I have not noticed any irregularity with character pose sets.
Recent discovery is gen mats are not working properly. I use a lot of Krash products and they contain a special gen uv. Surface does not register its existence. Know it loaded.
I have tried loading a couple saved characters compiled after loading Daz on this computer but before dumping my previous Daztime and while not perfect seem to load better than expected. Likely small items I have not reloaded yet missing but shape and most mats present.
So is Betty a custom character of your own creation, with the morph not saved as a morph asset? If so it will be embedded in the preset file and will load if that is sued to create a new figure but not if it is used to modify an existing figure. That does sound as if the morphs are not correctly installed but the base figure is. Are textures loading?
Textures loading on characters does not seem a problem . Seem to load with characters or adding to a base one as they should. Changing hair mats has not been problematic.
Other than the afore mentioned UV issue the big problem is morphs, hair and clothing morphs originating in content library. Exception is loading a vendor originating character (1st) from Character category and that will load with shape and mat. A blank base character (2) will not see the same morph just loaded with 1st character. I know the morphs are there since it loaded on 1st.
g82022-09-09 07:10:47.771 *** Scene Cleared ***
2022-09-09 07:10:59.511 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLRage_HD.dsf#eCTRLRage?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Teen%20Josie%207/eJCMJosie7Rage.dsf
2022-09-09 07:10:59.572 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLWink_HD.dsf#eCTRLWink?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Mei%20Lin%208/eJCMMeiLin8_Wink_HDLv2.dsf
2022-09-09 07:10:59.629 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLScream_HD.dsf#eCTRLScream?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Mei%20Lin%208/eJCMMeiLin8_Scream_HDLv2.dsf
2022-09-09 07:10:59.643 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLRage_HD.dsf#eCTRLRage?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Mei%20Lin%208/eJCMMeiLin8_Rage_HDLv2.dsf
2022-09-09 07:10:59.662 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLPain_HD.dsf#eCTRLPain?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Mei%20Lin%208/eJCMMeiLin8_Pain_HDLv2.dsf
2022-09-09 07:10:59.717 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLHappy_HD.dsf#eCTRLHappy?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Mei%20Lin%208/eJCMMeiLin8_Happy_HDLv2.dsf
2022-09-09 07:10:59.736 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLFear_HD.dsf#eCTRLFear?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Mei%20Lin%208/eJCMMeiLin8_Fear_HDLv2.dsf
2022-09-09 07:10:59.753 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLExcitement_HD.dsf#eCTRLExcitement?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Mei%20Lin%208/eJCMMeiLin8_Excitement_HDLv2.dsf
2022-09-09 07:11:00.710 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6777): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Aiko%208/FHMAiko8.dsf#FHMAiko8?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Aurora/FHMAurora.dsf
2022-09-09 07:11:00.757 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6777): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Aiko%208/FBMAiko8.dsf#FBMAiko8?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Aurora/FBMAurora.dsf
2022-09-09 07:11:00.875 Begin Loading Character Addons...
2022-09-09 07:11:01.075 File loaded in 0 min 0.1 sec.
2022-09-09 07:11:01.076 Loaded file: genesis 8 female eyelashes.duf
2022-09-09 07:11:01.081 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:01.083 Loaded file: PHMEyelashesLengthUpper.dsf
2022-09-09 07:11:01.084 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:01.084 Loaded file: PHMEyelashesLengthLower.dsf
2022-09-09 07:11:01.085 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:01.085 Loaded file: PHMEyelashesCurl.dsf
2022-09-09 07:11:01.108 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:01.109 Loaded file: PHMEyelashesLengthUpper.dsf
2022-09-09 07:11:01.114 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:01.115 Loaded file: PHMEyelashesLengthLower.dsf
2022-09-09 07:11:01.120 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:01.120 Loaded file: PHMEyelashesCurl.dsf
2022-09-09 07:11:01.125 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:01.127 Loaded file: PHMEyelashesExpand.dsf
2022-09-09 07:11:01.243 File loaded in 0 min 0.0 sec.
2022-09-09 07:11:01.249 Loaded file: base mat eyelashes.duf
2022-09-09 07:11:01.252 Finished Loading Character Addons
2022-09-09 07:11:01.276 File loaded in 0 min 13.5 sec.
2022-09-09 07:11:01.277 Loaded file: genesis 8 basic female.duf
2022-09-09 07:11:02.411 Loaded image g8fbasetorsomapd_1002.jpg
2022-09-09 07:11:02.421 Loaded image g8fbasetorsomapb_1002.jpg
2022-09-09 07:11:02.509 Loaded image g8fbasetorsomaps_1002.jpg
2022-09-09 07:11:02.866 Loaded image g8fbasefacemapb_1001.jpg
2022-09-09 07:11:02.985 Loaded image g8fbasefacemapd_1001.jpg
2022-09-09 07:11:03.073 Loaded image g8fbasefacemaps_1001.jpg
2022-09-09 07:11:03.077 Loaded image g8fbasefacemaps_1001.jpg
2022-09-09 07:11:03.169 Loaded image g8fbasemouthmapb_1005.jpg
2022-09-09 07:11:03.171 Loaded image g8fbasemouthmapd_1005.jpg
2022-09-09 07:11:03.522 Loaded image g8fbaselegsmapb_1003.jpg
2022-09-09 07:11:03.531 Loaded image g8fbaselegsmapd_1003.jpg
2022-09-09 07:11:03.651 Loaded image g8fbaselegsmaps_1003.jpg
2022-09-09 07:11:03.725 Loaded image g8fbaselegsmaps_1003.jpg
2022-09-09 07:11:03.982 Loaded image g8fbasearmsmapb_1004.jpg
2022-09-09 07:11:04.072 Loaded image g8fbasearmsmapd_1004.jpg
2022-09-09 07:11:04.190 Loaded image g8fbasearmsmaps_1004.jpg
2022-09-09 07:11:04.253 Loaded image g8fbasearmsmaps_1004.jpg
2022-09-09 07:11:04.285 Loaded image g8fbaseeyesb_1007.jpg
2022-09-09 07:11:04.288 Loaded image g8fbaseeyes01_1007.jpg
2022-09-09 07:11:04.374 Loaded image g8fbaseeyelashes_1006.jpg
2022-09-09 07:11:15.003 Loaded image fbmthin.png
2022-09-09 07:11:15.005 Loaded image fbmthin.png
2022-09-09 07:11:24.756 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:24.756 Loaded file: Body Thin.dsf
2022-09-09 07:11:40.120 Loaded Morph Deltas in 0 min 0.0 sec.
2022-09-09 07:11:40.120 Loaded file: Hip Thighs Size.dsf
Got myself a newer Box, stronger, bigger and faster. Problem is two fold.
1) When I copied my Daztime smart content did not come along.
2) I am not finding the content search so daz can recognize what I copied from the old computer.
Tried to load the newest Daz but my lack of a consistent internet connection caused me to du.p that and install 4.15 like on the old box.
I use a combination manual and offline loading.
Thanks
