Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Thanks. I don't know why I couldn't find these in the search function.https://sharecg.com/v/62326/browse/11/Poser/Saber-Suit-for-Kururu
https://sharecg.com/v/68400/browse/11/Poser/MIKI4-Casuals-Suit-Set.
I answered my own question. I found her. Too bad the weight mapped version of her is only for DAZ. I would probably use her. But not in my current project. And her clothes won't fit V4, am I right?So who is Kururu?
And now I have your alternate solution too. Thanks again for the link.Don't feel bad, I did the search also, and resulted in the same behavior.ย So I went to my alternate solution.
I don't have anything for Kururu. I'd never heard of her before yesterday. I can't say how well it would fit V4. It would need converting.
RedPhantom posted at 9:40 AM Wed, 21 September 2022 - #4444935
A lot of converting.I don't have anything for Kururu. I'd never heard of her before yesterday. I can't say how well it would fit V4. It would need converting.
I downloaded her original version and took a look at the mesh compared to default V4.
I don't think it will work to try to use her clothing.
Anybody have a good shader to make skin look wet? Not sweaty, or just boosting the specular, but actually fell-in-a-lake wet? I need it for my scene and I am not sure how to pull it off in Superfly. I did it with Sydney in Firefly years back. But it didn't look quite right.
There was a MAT that someone did awhile back too. But it didn't work in Superfly. I used it on Miki, but you had to zoom in to the pic to see the water drops on her.
Basically, I want to make it look like my Kara was thrown through a water tower and comes out wet. I can do her clothes in post, but I need to be able to do her skin. If I use rev-viper's hair prop, there is an included wet hair morph for it that looks pretty good.
Speaking of skin,ย rokketย why not giving a test through EZSkin3? you may define what kind is each body part, so that you could create a character definition for this one.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟย Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟย Nas 10TB
๐ฟย Poser 13 and soon 14ย โค๏ธ
The only drawback that I have found in EZSkin3 is the inability to activate the SSS material settings for the skin textures.ย There is no check box option.
@ Y-Phil: I don't know if this is an option that can be easily implemented, and it would be appreciated if you have some time to look into it.ย I think it is a feature that should be available to users as an option rather than an assumption that it is already activated when EZSkin is applied.
I think that the SSS is always enabled (given it's active in the render parameters)
ย and the part you may control is how deep it goes, through each Scatter nodes (above is for Firefly and below for Superfly)
You may remark that my settings are for Superfly
I don't know Kururu but it looks pretty much like an Aiko3 or an Aiko19
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
This needs to be experimented more (I'm not used to this part), but using the Cycles plugin for EZSkin:
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
That's just it.ย The Use_Material_Colorย is unchecked.ย According to the Poser manual, you must check the tick box if you want to use the Material preset.ย Unfortunately, the Scale doesn't behave as I expect it to, at least.ย When I increase that value, I do not notice an increase in translucency, only by decreasing the value do I see a difference.ย When I get time to experiment with it closely, I'll determine if it is actually broken.ย The PrincipledBsdf SSS Scaling does increase the translucent behavior as it should.I think that the SSS is always enabled (given it's active in the render parameters)
Y-Phil posted at 1:14 PM Wed, 21 September 2022 - #4444948
That's just it.ย The Use_Material_Colorย is unchecked.ย According to the Poser manual, you must check the tick box if you want to use the Material preset.ย Unfortunately, the Scale doesn't behave as I expect it to, at least.ย When I increase that value, I do not notice an increase in translucency, only by decreasing the value do I see a difference.ย When I get time to experiment with it closely, I'll determine if it is actually broken.ย The PrincipledBsdf SSS Scaling does increase the translucent behavior as it should.$I think that the SSS is always enabled (given it's active in the render parameters)
For me, it's 10pm and I feel the tiredness lol, so that I may have to re-read your explanation and see if I can find where to interfere in EZSkni's code and correct this,
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Thanks. I will give this a shot right now. I am working on a Miki in the tub scene and The next thing will be to tackle how to make the bottom part of her strand based hair look wet.
Sometimes I bite off way more than I can chew.ย I know there has to be a math solution to getting the bottom part of the hair to look wet.
But I suck at math...
rokket posted at 8:41 AM Thu, 22 September 2022 - #4445033
I've deleted it as Ghostship already gave the respondWeird that there is a response from Y-Phil, but I am not seeing it...
Are you sure to have a file named "CycleSkin.py" in this folder?
Note that you must restart EZSkin to see it.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Just another hint: Poser11 is the last one to be installed within "Program Files". Poser12 and the next versions will always have their own tree, elsewhere. Actually: on a dedicated partition stored on a Samsung SSD 860 M.2, with all my runtimes (I've seen a difference in speed when I did this)
The "Program Files" zone is too strict, too complicated to manage.
And as you can see, all scripts such as EZSkin3 and the likes are stored on a third drive.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Great newsI fugured it out. I fixed it. It works now!!!!!
Thanks for the tip
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Yeah, so apparantly, the water is pretty cold. So cold it knocked her suit off...
Her body and hair both have cycles materials. The wet look of her hair came from a pose file that red viper included in the package for that hair.
Oh and red viper also provides with feg II a nice blush mask for the cheeks
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
Yeah, if I use V4, but I don't think it will work on Miki. Unless I can reverse engineer it.Oh and red viper also provides with feg II a nice blush mask for the cheeks
Bookmarked
