Sun, Nov 24, 11:16 PM CST
Subject: Antonia - Opinions?
jroulin ( ) posted Sat, 24 December 2022 at 3:29 AM
Thanks odf, I have downloaded it. If you are OK with it I will generate an easy sim for it and post it in the free section. The script will be located in the same folder as the skirt.
I will do it after the holidays. Wish you all the best for Christmas and year end!
odf ( ) posted Sat, 24 December 2022 at 3:48 PM
jroulin posted at 3:29 AM Sat, 24 December 2022 - #4452434
Of course! As usual, all add-ons, modifications, improvements are very welcome.
jroulin ( ) posted Wed, 04 January 2023 at 4:54 AM
odf posted at 3:48 PM Sat, 24 December 2022 - #4452463
The sim is waiting for approval.
jroulin ( ) posted Fri, 06 January 2023 at 9:39 AM
odf ( ) posted Fri, 06 January 2023 at 3:39 PM
Nice one, jroulin! 👍
I feel I'm about ready to publish the blouse, but it occurred to me that I might not be allowed to redistribute MD buttons under a CC license. So, just to be on the save side, I think I'll make my own buttons in Blender instead. Anyway, I'm quite happy with how it simulates, and hopefully I'll be a bit faster getting my dynamic clothes out into the open after these first "test balloons".
primorge ( ) posted Fri, 06 January 2023 at 7:46 PM
jroulin posted at 9:39 AM Fri, 6 January 2023 - #4453217
It is approved now.
Free Simulation preset for odf's SkirtPleated. (renderosity.com)
Thanks
jroulin ( ) posted Sat, 07 January 2023 at 7:19 AM
odf posted at 3:39 PM Fri, 6 January 2023 - #4453251
If you make the buttons in Blender try to reduce the poly count so that it will simulate faster in Poser. The MD buttons are really high in poly and this is reducing the sim speed a lot. If you send me the zip file before posting it in the free area, I can run the sim script generator for you so that you can include the sim files in your zip. Generating those files take me less than one min but posting a free item myself much more.
jroulin ( ) posted Sat, 07 January 2023 at 7:23 AM
primorge posted at 7:46 PM Fri, 6 January 2023 - #4453277
Thanks
You are welcome
odf ( ) posted Sat, 07 January 2023 at 3:58 PM
jroulin posted at 7:19 AM Sat, 7 January 2023 - #4453328
Agreed, those buttons don't need that many polygons, considering their size. But the worst offenders seem to be the little threads of yarn attached to them. 😁
Okay, I'll do that. Can the generated script be distributed under the CC-BY license like all my freebies, or does it need a separate one?
jroulin ( ) posted Sat, 07 January 2023 at 4:12 PM
odf posted at 3:58 PM Sat, 7 January 2023 - #4453345
The generated scripts can be freely distributed in free and in commercial products
odf ( ) posted Mon, 09 January 2023 at 1:02 AM · edited Mon, 09 January 2023 at 1:08 AM
A snapshot from testing the blouse with the new homemade buttons. I think I forgot to fix the normals in Blender, which is why they are looking pretty funky right now. Another small issue is that exporting from MD in the zero pose puts some strain on the garment, so the buttons tend to intersect the fabric. I may or may not have to fix their positions in Blender after exporting, but if so, that's not really a biggie, especially considering that the material zones come out weird and need manual fixing, anyway. Also, I'm assuming button-placement will only be an issue for the fully buttoned version.
Oh, before I forget: currently the blouse doesn't have a yoke. Does it need one? Do we have any seasoned seamstresses (of any gender) here that can weigh in on the issue?
FVerbaas ( ) posted Mon, 09 January 2023 at 2:25 AM
Forum Coordinator
It looks like the point of the breast dart sits too high. It usually ends at the point of the breast.
There's plenty of reference patterns available on line. If you want to flex your muscle in Italian here's a good one:
https://issuu.com/tallerbioarq/docs/la_tecnica_dei_modelli_uomo_-_donna.
It gives a lot of theory first. Patterns for 'corpini e camicie' start at page 139.
There's also a part 2 with patterns for Antonius.
FVerbaas ( ) posted Mon, 09 January 2023 at 2:28 AM
Forum Coordinator
BTW: The Marvelous Designer Discord has a channel for pattern references.
odf ( ) posted Mon, 09 January 2023 at 3:08 AM
FVerbaas posted at 2:25 AM Mon, 9 January 2023 - #4453458
Yeah, but that's just because of the pose. Her shoulders are pulled way back, making the fabric stretch across her chest and ride up on it. Increasing her breast size from the default probably didn't help either. The dart is just where it belongs in the A-pose.
Pretty sure that's what will happen in real life, as well. Most ladies don't glue the darts to their nipples, or so I hear. Of course, I'm no expert, so I'm just guessing. 😁
On the other hand, making the fit a bit looser and adding a yoke to compensate might help a bit with the riding up.
That's saying "page not found".
Looking at patterns is definitely helpful, but I find it can be a bit of a hen and egg problem. Not all patterns are easy to read, sometimes I need to understand the construction principles first before I can understand what the pattern does.
odf ( ) posted Mon, 09 January 2023 at 3:32 AM · edited Mon, 09 January 2023 at 3:32 AM
Oh, and it turns out MD splits the buttons along UV seams when exporting, so then Poser treats each button as many individual rigid decorations, causing chaos. That's why they looked so funky, nothing wrong with the normals. One more thing to fix in Blender.
FVerbaas ( ) posted Mon, 09 January 2023 at 6:35 AM
Forum Coordinator
Ok. Looks like there's a combination of things there. I had not noted the shoulders were pulled back.
Real life breasts would be flattened / pushed aside under the pressure which would reduce the effect.
DCArt ( ) posted Mon, 09 January 2023 at 7:33 AM
It looks to me like the dart starts around the bottom of the underarm. Typically, darts start at roughly "bra-strap" level.
FVerbaas ( ) posted Mon, 09 January 2023 at 9:56 AM · edited Mon, 09 January 2023 at 9:59 AM
Forum Coordinator
I just uploaded the V4_to_Antonia injection for the Prefitter-CR2 as a freestuff. It is under review now.
The prefitter is a marketplace product. if any of you current active contributors in this thread is interested in this and you do not yet own the Prefitter drop me a sitemail and I will provide you with a copy.
jartz ( ) posted Mon, 09 January 2023 at 11:01 AM
FVerbaas posted at 9:56 AM Mon, 9 January 2023 - #4453474
Wow, that's welcoming news.  Yes, I'm interested.  I have the base Prefitter base.  Look forward to it, since I like to see if I can get some footwear for her.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
odf ( ) posted Mon, 09 January 2023 at 1:09 PM
DCArt posted at 7:33 AM Mon, 9 January 2023 - #4453468
True, for a blouse/shirt a more horizontal dart at the bust seems more common. I‘ll give that a try.
odf ( ) posted Mon, 09 January 2023 at 1:17 PM
FVerbaas posted at 6:35 AM Mon, 9 January 2023 - #4453465
My fault, of course. It’s not easy to see from that angle.
Quite true! For a "real“ render, morphing the breasts accordingly would have been a good idea.
odf ( ) posted Mon, 09 January 2023 at 10:11 PM
So, I changed the direction of the dart, and that looks so much better with the pin stripes, and probably other fabric patterns, as well. This is the kind of thing that makes posting random in-progress snapshots and having folks “nitpick” them worthwhile. So, thanks for that!
odf ( ) posted Thu, 12 January 2023 at 1:56 AM
Some progress on the buttoned version of the blouse:
I'll probably go with the materials on the left, which I really like for this garment. But I'm also showing some texture variations to highlight the new dart direction (see middle image) and the slight self-intersection at the button placket (see image on the right), which is probably unavoidable in Poser.
FVerbaas ( ) posted Mon, 16 January 2023 at 11:32 AM · edited Mon, 16 January 2023 at 11:32 AM
Forum Coordinator
Just made the first version of a sort of Prefitter-CR2 using LaFemme as donor and Antonia as target. This aims to do a 95% refit of LaFemme stuff to Antonia.
Succesful now for jeans, T-Shirt and hair. She runs barefoot because shoe conversion is notoriously difficult.
It is not a Prefitter-CR2 injection but an independent item. If there is interest I can release it as a freebie. Would there be any interest?
DCArt ( ) posted Mon, 16 January 2023 at 11:56 AM · edited Mon, 16 January 2023 at 12:01 PM
The darts look better, but still not quite right. From a sewing perspective:
The "peak" of the dart (the end)  is generally around the nipple, or at the fullest part of the breast. That's the purpose of the dart, to make the flat fabric fall properly around that non-flat shape. Otherwise you will get bunching and pulls in places you don't want. 8-)
Then the split part is generally slightly lower than that. You show that part right, it's just that your dart "peak" needs to be closer to the nipple area.
Here's an example. Hard to tell where the nipple actually is, but hopefully you get the point (no pun intended LOL)
primorge ( ) posted Mon, 16 January 2023 at 1:34 PM
FVerbaas posted at 11:32 AM Mon, 16 January 2023 - #4454046
Yes, there is interest.
FVerbaas ( ) posted Mon, 16 January 2023 at 1:50 PM · edited Mon, 16 January 2023 at 1:57 PM
Forum Coordinator
Antonia nicked LaFemme's 'En Noir' set. OOPS!
Anyway, good case to try arm gloves and boots. (Antonia's ankles and feet are made invisible)
Works largely OK.
Will polish a little and release when ready.
jartz ( ) posted Mon, 16 January 2023 at 3:05 PM
Yes, I’m interested
odf ( ) posted Mon, 16 January 2023 at 4:15 PM
That looks very promising, FVerbaas.
odf ( ) posted Mon, 16 January 2023 at 4:58 PM · edited Mon, 16 January 2023 at 4:58 PM
Since there's so much interest in my darts... I've added a few more to get a more fitted shape. I've also tapered the sleeves and changed the armholes a bit. Here's an MD screenshot which hopefully is a bit clearer.
DCArt ( ) posted Tue, 17 January 2023 at 7:29 PM
odf posted at 4:58 PM Mon, 16 January 2023 - #4454069
Yes, that is MUCH better! 8-)  (Sorry, years of sewing make me aware of how darts fall LOL)
DCArt ( ) posted Tue, 17 January 2023 at 7:33 PM
PS ... the additional shaping darts are great also. You done good!
odf ( ) posted Wed, 18 January 2023 at 2:55 AM
DCArt posted at 7:33 PM Tue, 17 January 2023 - #4454123
Thanks! Always trying to learn.
odf ( ) posted Wed, 18 January 2023 at 3:15 AM · edited Wed, 18 January 2023 at 3:18 AM
Lots of little changes on the blouse to make it behave better as Poser dynamic cloth. Here's what the latest version looks like. I think I'm getting very close now, but I've said that before. :-)
One thing that annoys me is that I cannot make all 127 combinations of open and closed buttons available in Poser. The way I keep a button closed is by sewing a corresponding section of the front and back placket together in MD, which makes them share an edge in the exported mesh and thus keeps them together in Poser. So, with this method 127 button combinations would require 127 separate meshes, which is way too many.
If anyone knows of a trick to keep two pieces of fabric together in a Poser simulation that are not topologically connected in the mesh, let me know. Without the sewing, a closed button goes right through the fabric.
Otherwise, I'll just make three or four fixed versions, which is also fine.
DCArt ( ) posted Wed, 18 January 2023 at 8:41 AM
Yes the new blouse fitting is TONS better. I anticipated that it would look much better when posed and animated. Again, good job!
I can't imagine even doing 127 different button morphs, nevermind 127 different morph objects.
As for keeping fabrics together during simulation, you'd have to experiment with the Soft Decorated Group and Rigid Decorated Group options in the cloth room. I'd start with assigning both front and back plackets to the soft decorated, and the buttons to rigid decorated. See if that helps.
FVerbaas ( ) posted Wed, 18 January 2023 at 8:56 AM · edited Wed, 18 January 2023 at 9:03 AM
Forum Coordinator
odf posted at 3:15 AM Wed, 18 January 2023 - #4454138
I did some investigations into this a few years ago. If memory serves me well making topology changes via Python turned out to be the only potentially feasible route. (I did not explore it) If there were only a single connection, say a clip holding a robe you could play a little with vertices assigned to '_rigid decorated_', but that hardly is highly experimental and I would not recommend it for any content other than strictly own use.  (Sorry Denise I saw your post only later)
Toplogy changes in the cloth object of course require setting up a new simulation.
odf ( ) posted Wed, 18 January 2023 at 5:00 PM
Thanks! I would have been surprised if a user-friendly solution existed in Poser. It's still kind of interesting just for the heck of it, but I don't think I'll make any attempts at getting this kind of thing to work for a free-stuff item.
There'll probably be four versions: fully buttoned, unbuttoned, buttoned only in the middle, buttoned only in the top and bottom. It depends a bit on which versions I think fall nicely, so with the new fitting I'll have to do a few more experiments.
primorge ( ) posted Wed, 18 January 2023 at 5:38 PM
odf posted at 5:00 PM Wed, 18 January 2023 - #4454182
Sounds like the most reasonable approach. Can you include a diaphanous pink material with delicate tiny hearts? Asking for a friend...
primorge ( ) posted Wed, 18 January 2023 at 5:42 PM
On second thought, nix the tiny hearts. Probably not possible without a texture map. The diaphanous material would be appreciated.
odf ( ) posted Wed, 18 January 2023 at 6:04 PM · edited Wed, 18 January 2023 at 6:05 PM
primorge posted at 5:42 PM Wed, 18 January 2023 - #4454189
I'll see what I can do. I had been planning to add something pinkish or turquoise as a second material, anyway.
Formulas for heart shapes exist, but I draw the line at two dozen shader nodes or so. 😁
primorge ( ) posted Wed, 18 January 2023 at 6:08 PM
Cool. Thanks...
odf ( ) posted Thu, 19 January 2023 at 1:10 AM
is this more of less what your friend had in mind, primorge?
Y-Phil ( ) posted Thu, 19 January 2023 at 3:43 AM
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
primorge ( ) posted Thu, 19 January 2023 at 4:16 PM
odf posted at 1:10 AM Thu, 19 January 2023 - #4454211
Yes, that's good. Looking forward to the item(s)...
odf ( ) posted Thu, 19 January 2023 at 6:59 PM
primorge posted at 4:16 PM Thu, 19 January 2023 - #4454252
Cool, but now of course you've nerd-sniped me into researching procedural heart textures for a bit...
odf ( ) posted Fri, 20 January 2023 at 1:04 AM
Well, here are some delicate procedural hearts for your approval. Luckily for our lady of the pointy teeth, the pattern part of the shader came to just below two dozen nodes.
RFreise ( ) posted Fri, 20 January 2023 at 1:28 AM
That looks good
odf ( ) posted Fri, 20 January 2023 at 1:41 AM
RFreise posted at 1:28 AM Fri, 20 January 2023 - #4454283
That looks good
Thank you!
Also, here's a FireFly render for those who are into that:
primorge ( ) posted Fri, 20 January 2023 at 6:43 PM
odf posted at 1:41 AM Fri, 20 January 2023 - #4454284
That looks good
Thank you!
Someone who is now of a few hundred morphs/controllers is mightily pleased by the results of the Nerd Snipe...
odf ( ) posted Fri, 20 January 2023 at 6:59 PM
primorge posted at 6:43 PM Fri, 20 January 2023 - #4454335
Glad I could be of service. Shouldn't be too long now.
