Sun, Feb 16, 11:20 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Feb 13 3:42 pm)
Subject: I am the most questions asked, I know. reflections on human skin
  • 1
  • 2
Rhia474 ( ) posted Fri, 01 September 2023 at 6:22 PM · edited Fri, 01 September 2023 at 6:24 PM
Online Now!
Yeah, that fixed it. I am sloppy. Thankies!
ETA: nice roughness modulation with this, many, many, thanks.
Rhia474 ( ) posted Fri, 01 September 2023 at 6:31 PM
Online Now!
Yeah, this is good.
Y-Phil ( ) posted Fri, 01 September 2023 at 6:47 PM
Wow!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
CobraBlade ( ) posted Fri, 01 September 2023 at 7:30 PM
Awesome Phil! I'll be sure to update the version hosted on my website shortly to this newest version, and thank you for always coming through for us. :)
Also for going beyond the call of duty, tasking yourself with creating a Ghostship's Cycles in the future, as I know that won't be easy.
Poser scripts by Snarlygribbly
CobraBlade ( ) posted Fri, 01 September 2023 at 9:20 PM
Rhia474 posted at 6:31 PM Fri, 1 September 2023 - #4473882
Yeah, this is good.
Yeah, I didn’t give the Cycles shaders much of a chance back in Poser 11/12 since the SuperFly shaders did what I needed, but with Poser 13, I’ve finally played around with them.
Your render is a good example of the shader in action.
CobraBlade ( ) posted Mon, 25 December 2023 at 5:29 PM · edited Mon, 25 December 2023 at 5:29 PM
All happy on the skin side of things, but I have to say I'm missing being able to just apply BB Hair Shader by AP ever since upgrading to Poser 13.
So doing a bunch of testing with hair to find what I'll use as a replacement going forward. Here are my tests I'm selecting from.
I think I'm leaning into still using EZSkin, and was thinking of going with the SuperFly shader... but when it came to Aether Hair that one of my main characters use, this...xi0spcJ4bBXkCtrgScAtcHlRkGZWSnf0fRiTZPUv.png
Turned into this
Y-Phil ( ) posted Tue, 26 December 2023 at 9:16 AM
CobraBlade posted at 5:29 PM Mon, 25 December 2023 - #4479586
I am not sure to understand. I mean, I don't know how to set the BB Hair Shader correctly (and I clearly doesn't know anymore how to use EZSkin with firelfly - lool), as I prefer largely Superfly and Cycles-based nodes. But a fast test shows that it's useable with EZSkin 3.2bis
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CobraBlade ( ) posted Tue, 26 December 2023 at 1:59 PM · edited Tue, 26 December 2023 at 1:59 PM
You can apply it using EZSkin no problem, it's more of how Poser 13 handles the shader.
If I use my example from earlier.
The exact same scene rendered using SuperFly in Poser 11 & 13. With how it renders in Poser 13, that's why I've tried to find a replacement.
hborre ( ) posted Tue, 26 December 2023 at 3:22 PM
From what I understand, some nodes have been modified and improved internally.  It becomes a matter of isolating and changing the modified settings.  It might mean that the shaders need a complete overhaul.
Y-Phil ( ) posted Fri, 29 December 2023 at 2:40 PM · edited Fri, 29 December 2023 at 2:40 PM
I  had to increase the LowGloss and the HighGloss parameters for EZ_CycleSkin:
For the Hair, I've used the default values for the BB Hair shader. except:
* the "Spcular Normal 2: 0.42 instead of 0.45,
* white color tint, as I've checked "Use color map"
And that gave me:
Using my 3-lights setup: 2 areas (front-right + back-right) + infinite for the background
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CobraBlade ( ) posted Fri, 29 December 2023 at 7:06 PM
Thanks for taking a look into the settings, but I think some things just render very differently in Poser 13. It looks like your settings have calmed the result a bit. But you'll notice it in your render too, if we use BB Hair shader, Poser 13 will give the hair random white glows in strange places.
As for the Superfly shader and Aether hair MAT 2 turning orange. I just tested it in Poser 11. Looks like that has always been the case, possibly why I didn't go with it back then.
hborre ( ) posted Fri, 29 December 2023 at 8:09 PM
The problem arises with the use of the PoserSurface node for Superfly rendering.  Try connecting the PhysicalSurface node to BB's shader array and you will get a different render result.  My suspicions center around the usage of the Translucent feature in the original setup but I can only verify that by meticulously pulling every connector apart and replacing every node with Superfly-specific nodes.  In all reality, if you are serious about embracing Superfly-rendering as your primary workflow, I suggest making a clean break from the PoserSurface node as your root base.
CobraBlade ( ) posted Sat, 10 February 2024 at 1:09 AM
You're probably right hborre, and it would be great if we could get the BB Hair Shader by AP remade for Poser 13 upwards, but unfortunately, I think we have lost the entire development and creation with the SmichMicro Poser forums disappearance. So I'm not even sure who was responsible for its creation. I'm guessing BB stands for Bagginsbill, but I'm not sure who AP would be.
CobraBlade ( ) posted Sat, 30 November 2024 at 3:37 PM · edited Sat, 30 November 2024 at 3:37 PM
Time to resurrect this post again? I hope I've done something stupid on my end... but applying EZ_CycleSkin (SF) via EZSkin in Poser since updating Poser is giving me super shiny people despite not having changed anything with EZSkin to my knowledge.
This is how the character looks from when I applied EZ_CycleSkin earlier.
But if I apply EZ_CycleSkin now it will now look like this.
I even tried Defaults thinking I may have bumped a setting here or there, but this is the current setting giving me extra shine.
RedPhantom ( ) posted Sat, 30 November 2024 at 4:29 PM
Site Admin
I don't remember which version, but the glossy node was changed making it more sensitive so the ezskin default is now too shiny. I think it was recommended to raise the high gloss and low gloss each by 0.2. I have mine higher usually 0.7 and 0.9 respectively, but that removes most of the shine. You'll need to test for your preferences.
Y-Phil ( ) posted Sat, 30 November 2024 at 4:51 PM · edited Sat, 30 November 2024 at 4:55 PM
Here is an example with higher settings, as RedPhantom explained:
This is due to the fact that the glossiness had once been corrected and this node is indeed far more sensitive.
There's another place that can be changed also, but it's actually not accessible from EZSkin's parameters, if you'd like to play with the Material room: increase the pointed distance. I've checked with 0.02, but that's somewhat tedious because it must be done on each material
till I upgrade the plugin to give access from the parameters dialog, directly GtZ28qTUq2un1T7eaukyjGfwS0zOLJgaOWSz6E2Z.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CobraBlade ( ) posted Sat, 30 November 2024 at 5:02 PM · edited Sat, 30 November 2024 at 5:03 PM
This is a very recent thing. I was using 13.3.686 when I used EZSkin for that character originally. If I apply it now in 13.3.895 I got this. Both of these are rendered in 13.3.895.
If either of you have a character that EZSkin has already been applied to in the past (preferably EZ_CycleSkin) can you render them, then apply EZskin again and see if it renders differently now?
RedPhantom ( ) posted Sat, 30 November 2024 at 9:13 PM · edited Sat, 30 November 2024 at 9:13 PM
Site Admin
Here is my test. The left was made in a previous Poser 13 version. I don't remember which. The right was run through ezskin in 13.3.895. And both were with the EZ_Cycles Skin
RedPhantom ( ) posted Sat, 30 November 2024 at 10:10 PM
Site Admin
I reset some of my settings in ezskin. They seemed to have gotten changed somehow. Getting everything back how it had been I got this
CobraBlade ( ) posted Sat, 30 November 2024 at 11:45 PM
Pretty sure I've just used the default settings for EZ_CycleSkin. Strange that it affects applying EZSkin, I'd understand more if it started just rendering different after an update.
I might try rolling Poser back with Time Machine and do some testing.
CobraBlade ( ) posted Sun, 01 December 2024 at 12:03 AM
Yep, I double-checked and I've got identical settings but only got the glossy skin when applying in 13.3.895. In 13.3.686 it was fine. Not sure what change would have caused this, but I'll open a ticket. Thanks for testing too RedPhantom.
CobraBlade ( ) posted Mon, 09 December 2024 at 2:16 PM
It turns out on the Mac side of things... EZ_CycleSkin (SF) wasn't being affected by the super glossy changes Poser 13 caused (which quickly made it my favourite).
So when 13.3.895 fixed this bug I was suddenly faced with glossy skin. Great news though, Y-Phil has come through and made an updated version of the shader that gives the desired results even in Poser 13.3.895.
You can download the latest version of EZSkin 3.2 from https://poser.cobrablade.net/
To use the newly updated shader, be sure to select EZ_CycleSkin (SF2)
Y-Phil ( ) posted Mon, 09 December 2024 at 2:49 PM
Just to add some information concerning the Cycle plugin for EZSkin.
The old one is not overwritten, the update has a new name, and in EZSkin dialog, its name is "EZ_CycleSkin (SF2)"
I have included the  SSS radius, and the selector between Burley and Random walk  for all skins (face, lips, etc...)
Tell me if I've missed something.
I have included the SSS radius because the logic in Poser has changed lately for that parameter. Here's what I'm using:
If the SSS radius is not recognized as a tuple with 3 floats, it will revert to the values hard-coded by our friend Charles ('3.67,1.76,0.6').
If you look at Vic's ear, you will notice that the light correctly traverse the cartilage, not using Burley IMO.
The values I'm using come from Poser's official on-line help.
"SSS Random Walk" is a rather recent option, visible in all Subsurface Scattering related nodes, included in Physical. Unchecked this to use the default "Burley" option.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CobraBlade ( ) posted Mon, 09 December 2024 at 3:46 PM
Thank you Phil, not only for your work on this but also for sharing all of this for anyone eager to play with the new version of the shader.
Y-Phil ( ) posted Mon, 09 December 2024 at 4:02 PM
CobraBlade posted at 3:46 PM Mon, 9 December 2024 - #4492028
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
nerd ( ) posted Tue, 10 December 2024 at 11:27 AM
Forum Moderator
Just for clarity what changed was the default shading methods on some of the Cycles native nodes. The ones affecting EZSkin were the GlossBSDF and SubsurfaceScatterBSSDF. The change to Gloss will remain because it makes the default the same on WIndows and Mac. The change to SSS was unintended fallout. The default will be returned to it's original (Burley) in the next SR.
Again this is only the default values when the shaders are added to a material. This change won't affect existing scenes or library materials.
Y-Phil ( ) posted Tue, 10 December 2024 at 2:57 PM
Pretty much why I'm offering the choice between Random Walk and Burley  for what matter the SSS.
If someone would like the choice: for the High-Low-Gloss: ask 2ou9mfPJYLbqj9T6fPUv5uAJHGCXITGQ7nmRq8uQ.png
In the new version, Beckman is now the new default, it replaces GCX which was causing too much reflection if I understood correctly the explanations.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
nerd ( ) posted Tue, 10 December 2024 at 7:07 PM
Forum Moderator
Wait GGX is in the list twice?  ... Oh good grief. WHYYYY did Cycles feel the need to rename all the shading methods for Cycles 4.1
Y-Phil ( ) posted Wed, 11 December 2024 at 5:06 AM
Oops... 😁
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
  • 1
  • 2
