Mon, Feb 10, 1:18 PM CST
Subject: Snarly's scripts
  • 1
  • 2
rokket ( ) posted Tue, 30 January 2024 at 11:10 PM · edited Mon, 10 February 2025 at 1:18 PM
Where can I find them again? I've searched the forums for an hour.
When I lost my laptop, I lost EZSkin3, EZDome....
Thanks!
donnena ( ) posted Tue, 30 January 2024 at 11:40 PM
Google shows them as being here
https://cobrablade.net/snarlygribbly/poser.html
Andy!
rokket ( ) posted Wed, 31 January 2024 at 8:58 AM
Huh. I didn't even think to try Google. Thanks!
rokket ( ) posted Wed, 31 January 2024 at 1:48 PM · edited Wed, 31 January 2024 at 1:49 PM
How come when I try to import the definitions, presets et al, they are not showing up in the folder that I put them in??? Those are the only folders that are showing up when I click on it.
I added those folders into the settings menu, too. I don't understand why it isn't working.
rokket ( ) posted Wed, 31 January 2024 at 1:51 PM
I am absolutely mind blown. I installed it according to the readme...
jimros ( ) posted Wed, 31 January 2024 at 3:10 PM
Here`s where I have mine,C:\Program Files\Poser Software\Poser 11\Runtime\Python\poserScripts\ScriptsMenu\snarlygribbly-ezskin3
Hope this helps
rokket ( ) posted Wed, 31 January 2024 at 4:28 PM
I have it in the scripts menu also. Maybe it needs it's own folder?
rokket ( ) posted Wed, 31 January 2024 at 4:55 PM
That didn't work either. I am still seeing this:
The other folders in that directory are NOT visible. I don't understand why.
rokket ( ) posted Wed, 31 January 2024 at 4:59 PM
This is what is in the folder, that is not showing when I attempt to do anything in EZSkin...
rokket ( ) posted Wed, 31 January 2024 at 7:22 PM
I figured it out. Snarly's script was looking in my runtime folder in my public folder, and not in the programs folder I put the EZSkin folder. Sheesh, what a pain in the ---
RodS ( ) posted Thu, 01 February 2024 at 9:41 PM
Does anyone know of any updates to EZskin3? I
I've been using it for a while with Poser 12 with no issues, but recently the renders involving skin have been extremely flat - as if the model has a heavy application of make-up powder from head to toe. There is no normal skin shininess in direct light.
I can render the same scene in PP 2014, with EZskin2 ant it looks great. Any ideas? Thanks!
Rod
"I reject your reality and substitute my own" - Adam Savage
rokket ( ) posted Thu, 01 February 2024 at 9:51 PM
EZSkin 3 has a Poser 12 update.
RodS ( ) posted Thu, 01 February 2024 at 11:54 PM
Got it! EzSkin 3.2.
I'll post the link to this library of Snarly's scripts - maybe help someone else..   https://cobrablade.net/snarlygribbly/poser.html
Thanks!
RodS ( ) posted Fri, 02 February 2024 at 3:20 PM
Installed EZSkin 3.2. Wish I hadn't - it's jacked up everything to hell. Poser 12 won't even render now. I'm hoping I can uninstall it and go back to EZSkin3 - although it's results are flat shin tones - no natural skin shine, no matter what I do. 😪
At this point, I'm thinking about going back to PP 2014 on this machine.
RodS ( ) posted Fri, 02 February 2024 at 4:36 PM
I don't know what EZSkin 3.2 did, but it has TOALLY screwed my Poser 12 to hell.
When I installed it, I followed the directions:
1. Extract all files from the zip archive to a folder of your choice. This can be anywhere you like.
2. Copy EZSkin3.py to the Runtime:Python:poserScripts:ScriptsMenu of the runtime installed in the same folder as the Poser executable. Note that while this location is recommended, EZSkin will in fact run from any location.
3. Set up the custom shader engines folder: Create a folder anywhere on your computer to which you have write access. Then copy the files from the zip's 'Custom shaders' folder into your newly created folder. Run EZSkin and open the settings dialog. Set the 'Custom shader engines' folder to the newly created folder.
Did all of the above. Opened a Poser file and went through the "Edit Skin" dialogue, which showed the settings imported from EZSkin3.1. Hit the 'render' button. My dual monitors flashed a couple times, then the SSS screen opened, and showed the SSS being applied to the figure.
Then the 'render' screen opened with the render progress bar. Then.... Nothing. It just sat there doing nothing. I left it for 10 - 12 minutes, and there was zero progress. Top of the screen showed "Poser Application Not Responding." Poser was completely locked up. Had to CTRL-ALT-DEL to get out of it.
Started Poser up again, opened the same figure, re-checked the "edit skin" settings. Tried again with the same result. Same for the next 3 - 4 attempts. Re-started Poser (again). Same result. Re-started computer, tried again. Same result.
Removed EZSkin3.2, tried rendering same figure. Rendered fine. Re-installed the older EZSkin3.1 which had been working fine (other than the super-flat skin tones), and tried again. Locked up on render. Tried another figure. Locked up on render.
So, now it appears EZSkin 3.2 left some nasty little something behind that's totally jacking Poser to the point of making it unuseable.
Removing 3.1 from the "Runtime:Python:poserScripts:ScriptsMenu of the runtime installed in the same folder as the Poser.exe" brings Poser back to working status. 3.1 worked previous to trying 3.2.
I know I can add SSS from Poser's Material Room, but it's such a pain in the a$$. You can't apply it to the figure's full body (at least I've not stumbled onto a way to do it), you have to do it a zone at a time (I.E: chest, abdomen, hip, right thigh, left thigh, etc.)
Is there another plugin out there that does what EZSkin is supposed to do without sending everything to hell? I've been fighting this all day, and have pretty much had enough.
Any ideas out there?
RodS ( ) posted Fri, 02 February 2024 at 7:39 PM
Finally got everything sorted after a couple days of fighting with it. Apparently no one reads this forum - thanks for all the help.
Y-Phil ( ) posted Sat, 03 February 2024 at 10:47 AM · edited Sat, 03 February 2024 at 10:47 AM
I'm sorry that you encountered those difficulties.
I have tested EZSkin 3.2bis with Poser 12.0.1029:
Using the corresponding EZ Cycles plugin:
Using the default Superfly plugin:
I didn't checked the values used, I just wanted to be sure that this EZSkin3.2Bis runs well with Poser12 also.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
hborre ( ) posted Sat, 03 February 2024 at 1:30 PM
I think there have been some changes to the specific Material Room nodes after P12 that have affected the way rendered images appear.  You should thoroughly understand what is going on in the Material Room before tweaking EZSkin, depending on your methodology for approaching Superfly materials and rendering.  I honestly think that there should be an overhaul of the app to accommodate node settings.  For example, despite the fact that you are given options to apply different skin types to the Subsurface Scatter node, there is no actual mechanism to turn it on in EZSkin.
@Y-Phil: The render with the default Superfly plugin looks much better than the EZ Cycles.  The overblown specular skin does not look natural or realistic.  Some individuals will object because they like that dermal sheen, but take a good look around, unless you bathe in baby oil, no normal individual looks like that.
RodS ( ) posted Sat, 03 February 2024 at 5:59 PM
I do like a reasonable bit of sheen (check my gal in the yellow bikini - is that too much sheen?) as long as it doesn't go overboard. On the other hand, I don't like the skin having a "flat" look over the entire body. It looks like a heavy layer of makeup has been applied to the entire figure. I'll see if I can find one of the flat renders and post it.
Everything seems to be back to 'normal' (whatever that is....) with P-12 now.
RodS ( ) posted Sat, 03 February 2024 at 9:24 PM
OK - here's one of the older renders - before I started mucking around with things. To me, she looks a little flat on the skin tones (I'm NOT telling her she looks flat, though...) What do you think? Do you like it like this, or with a little bit of specularity?
Just be careful what you say or she might use different fingers.... 😁
RodS ( ) posted Sat, 03 February 2024 at 9:30 PM
And, Y-Phil, those renders do look good. I hope 3.2 continues to work flawlessly for you! 👍👍
hborre ( ) posted Sun, 04 February 2024 at 5:35 AM
A slight bit of specularity should be about right.  The texture color looks odd though, a little yellowish.
CobraBlade ( ) posted Sun, 04 February 2024 at 5:36 AM
That's really strange. No idea what could have made everything go so crazy.
Basically, 3.1 was the last Snarlygribbly update to get EZSkin working in Poser 12
3.2 is the further updated version by Y-Phil that is still being maintained and also has extra fixes like 3rd party shaders updated to also keep them working in newer version of Poser.
Poser scripts by Snarlygribbly
Y-Phil ( ) posted Sun, 04 February 2024 at 10:51 AM · edited Sun, 04 February 2024 at 10:51 AM
RodS posted at 9:30 PM Sat, 3 February 2024 - #4481226
I have to say that I don't use EZSkin anymore as I've my own materials now, but: I will retire at the end of April, as I have given enough of my time and energy to society in general, and I'd really like to create a new EZCycle plugin for skin, something like EZGhostship plugin, based on what he published here. I'll just have to retrieve the references.
That's something I've already started some times ago.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil ( ) posted Wed, 18 December 2024 at 2:45 PM
Hello
Here: https://kdrive.digital-paradize.com/app/share/116364/91424416-1763-4bdf-bf2f-e0e7ec589478
You will be able to download EZSkin3.2ter, an update of EZSkin3.2bis. still for Poser 12+
The difference: it restores the file names, example with the famous suntan file name on my PC:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil ( ) posted Thu, 19 December 2024 at 6:46 AM
If anyone has dowloaded the EZSkin 3.2ter, replace it with this one:
https://kdrive.digital-paradize.com/app/share/116364/fc59fb81-fa2c-4211-b8e1-5b2cbbcda55e
It's labeled "EZSkin3.3" as I don't know what comes after 3.2ter... EQuKecDdXmqtvFlLGC75YS8Ht5CS2lY9CrByzbYO.gif
The correction avoids the material shader to be unnecessarily cluttered with orphan nodes
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
bwldrd ( ) posted Thu, 19 December 2024 at 9:23 PM
@Y-Phil
Thanks so much for the script updates. :)
Consider me insane if you wish, but is your reality any better?
CobraBlade ( ) posted Thu, 19 December 2024 at 10:29 PM
Thank you Phil, I have updated the mirror on my site to your latest version of EZSkin also. :)
Y-Phil ( ) posted Fri, 20 December 2024 at 3:23 AM
bwldrd posted at 9:23 PM Thu, 19 December 2024 - #4492250
@Y-Phil
You're welcome 😊
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CobraBlade posted at 10:29 PM Thu, 19 December 2024 - #4492251
Cool, thank you 😎
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil ( ) posted Sun, 29 December 2024 at 10:10 AM · edited Sun, 29 December 2024 at 10:18 AM
HI everybody, especially the EZSkin users... 0SsdD9xTf9jIwrLW1R9qbC7viqN7UN4oaifX36XQ.gif
In April, 2023, Ghostship created a thread dedicated to human skin, based on Cycles SSS: here.
For my needs, I have written an EZSkin plugin that is using more or less what were shared in the said thread, I mean: using the famous PrincipledBSDF node.
Actually, it handles all parts for Vic4's and Sasha's, even though the skin parts may be used for all other characters I think. Furthermore, blush can be added (face and ears), and even an hypno effect if you have the corresponding iris bitmap LYmd7kOtF6HtlRyEt12CHXjB2ZS6tNTK3M1IJusx.gif (here, it comes from RebelMomy's Holly)
The material for the teeth is based on what Ghostship showed us.
If you're interested, I'd be happy to share. You will just need an update for EZSkin, of course compatible with the existing plugins.
Typical result:
I've put compound nodes everywhere, as I do love simple material setups with just the right parameters visible.
Note that actually it relies on Bump maps, but I have some characters that have none, but rather a normal map, and I'm going to prepare a version for those.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hborre ( ) posted Sun, 29 December 2024 at 1:11 PM
I would be greatly interested in what you have.  I always like to compare notes.
Y-Phil ( ) posted Sun, 29 December 2024 at 3:50 PM · edited Sun, 29 December 2024 at 3:58 PM
The new EZSkin V3.4 is here:
https://kdrive.digital-paradize.com/app/share/116364/c9c3812b-e75f-42c0-842f-ca98da3a412c
The new plugin, based on PrincipledBSDF is here:
https://kdrive.digital-paradize.com/app/share/116364/7a305ed4-4dec-48a5-a61e-58ab586e9002
Some words of explanation: most settings are based on my humble experience. For example, in the common settings below:
- Bump's distance and strength are the one that works for my Vic4's. I have often seem them interchanged in many Blender examples
- in the same bloc, SSS anisotropy and Anisotropic are new params for the PBSDF node, and I like those as is, not sure it's correct
- the new EZSkin saves the path you have set: click OK in this dialog and exit EZSkin => definitely saved
- the nipples part have their own setting, so that one can set a different roughness (not sure that they are as glossy as normal skin), same for the face and the lips
-all the parameters lie in that huge dialog box, other settings (from the other buttons on the main dialog box) are ignored
- to active the blush: replace "face" by "face_blush" and "skin" "skin blush" here:
Remember that each section can be displayed independently using the top selector.
One last word with Poser 13: even though EZSkin works well in both the Pose Room and the Material Room, avoid its use in the Material Room. Quite often Poser truly HATES when a Python script modifies the organization of the nodes. Changing values aren't a problem but adding/removing nodes is often a no-go and ends up in an instant crash, especially when the currently selected material is updated by the script.
Once again: it's actually to be used with bump maps (or the generated pores, the code being the one in use by EZSkin since long ago). A version that can handle Normal map is on the way.
I remain opened to any suggestion (defaults values, other internal settings to offer as input of the compounds, etc.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CobraBlade ( ) posted Wed, 01 January 2025 at 12:27 AM
You've been really busy Phil, thank you! I'll have to check this new plugin out. In the meantime, I've updated the zip pakedge on my site to your latest version and placed this plugin into the custom shaders folder for anyone who newly downloads EZSkin.
Y-Phil ( ) posted Wed, 01 January 2025 at 8:30 AM · edited Wed, 01 January 2025 at 8:30 AM
CobraBlade posted at 12:27 AM Wed, 1 January 2025 - #4492526
Oh since I've retired at April, 1st of 2024 I've got plenty of time XYrwehObdUqOBxhe23AeOK2IimjUfhMQJ1KcPdjw.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Rhia474 ( ) posted Wed, 01 January 2025 at 1:03 PM
Many thanks for this, sir!
Y-Phil ( ) posted Wed, 01 January 2025 at 1:14 PM
Rhia474 posted at 1:03 PM Wed, 1 January 2025 - #4492541
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil ( ) posted Thu, 02 January 2025 at 3:53 PM
Hi
Note to each person who have downloaded the PBSDF-version of EZSkin: please, re-download it from the same link:
I've found an error (on "tear" and "invisible"), which is now corrected.
Thank you,
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CobraBlade ( ) posted Thu, 02 January 2025 at 11:49 PM · edited Thu, 02 January 2025 at 11:51 PM
Mirror also updated 👍
Now it's finally time to play around with it 🙂
Y-Phil ( ) posted Fri, 03 January 2025 at 7:06 AM
Cool, thank you so much  CobraBlade  👍
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
midinick ( ) posted Fri, 03 January 2025 at 1:09 PM
Just a dumb question .. I am possible to use more than one version of EZskin at the same time? (I use 3.2 and wanted to test the versions here, but I have a bit fear to crash my working script) XD I am really happy that it runs without any problems XD
by the way, thank you so so much for your scripts :D They are such a life saver :)
CobraBlade ( ) posted Fri, 03 January 2025 at 1:41 PM
The EZSkin3.py you have at Runtime:Python:poserScripts:ScriptsMenu (or your desired alternative location) is the core and what you'll see in the Poser scripts menu. You can rename it, or the new one you downloaded and have more than one.
I used to still have EZSkin 3.1 for when I jumped back into Poser 12, I simply renamed that one EZSkin3Old.py
Y-Phil ( ) posted Sun, 05 January 2025 at 1:41 PM
Here is another correction of the PrincipledBSDF-version plugin, for EZSkin.
Still downloadable at the same address:
- new: the possibility to tell EZSkin that the Bump maps are replaced with Normal maps (link to the Normal entry of the PrincipledBSDF node)
- possibility to ignore the link between the RedFilter and the Clearcoat entry of the PrincipledBSDF node, as well as the Clearcoat Normal entry.
At first, I added the latter based on this excerpt :
Ref: https://www.renderosity.com/forums/comments/4460954/permalink
I am still not sure how I have to manage that link, so that even though it's actually added by default, checking the corresponding option will ignore it. The reason is that  I may have misunderstood its purpose jZvrEDeXv8FQI0wJuVagD2TWAx2DWjLZLewppKNv.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Rhia474 ( ) posted Sat, 01 February 2025 at 12:20 PM
Just wanted to post a thank you for keeping this updated and letting us have it for free. It is indeed a huge improvement.
Y-Phil ( ) posted Sat, 01 February 2025 at 3:31 PM · edited Sat, 01 February 2025 at 3:31 PM
Rhia474 posted at 12:20 PM Sat, 1 February 2025 - #4493368
You're welcome: that's with great pleasure 99Zhk9aJc5rR2QrPNqAdsWGt8zFaGnkWZnE9647B.png
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
philadam ( ) posted Sun, 02 February 2025 at 4:55 PM
Y-Phil posted at 3:31 PM Sat, 1 February 2025 - #4493370
Thanks for the update.
Where did you get your documentation on poser python compound nodes?
I am trying to modify and link another compound node with two outputs without any luck, but the documentation on how to do this is very scarce.
Any insight would be great.
Y-Phil ( ) posted Sun, 02 February 2025 at 7:25 PM
philadam
Oh most of the time, I open the Material Room, I select an existing material. Then I launch Poser's python shell, and I start with those 4 lines:
scene=poser.Scene()
mat=scene.CurrentMaterial()
tree=mat.ShaderTree()
node = [n for n in tree.Nodes() if n.Name()='the_right_node_name'][0]
Then I experiment with the desired node. In the shell, "node." starts a list, upon selecting one line of the list and entering the character "(", Poser describes the function and its the parameters. The rest represents hours of experimenting and finding errors and glitches.
Reading Poser's existing scripts helps too. For this, I'm using Microsoft's Visual Studio Code and its search function in Poser's library of scripts.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
philadam ( ) posted Mon, 03 February 2025 at 12:46 AM
Thanks, I'll give it a try.
philadam ( ) posted Wed, 05 February 2025 at 5:33 PM · edited Wed, 05 February 2025 at 5:33 PM
Y-Phil
Just an observation, but I don’t think your code in setup_output:
         If exposed_output_name:
                n1, _ = compound_data.ExposedOutputs()[0]
                n1.SetName(exposed_output_name)
Is needed. I had issues with creating a second compound node with two outputs getting labeled properly when connecting to another compound node.
With your code:
With code commented out:
After experimentation, I believe that the "compound_data.ExposeOutput(node.OutputByInternalName(output_name))" statement resolves the output name based on the internal name of node being connected.
I may be wrong, but I got the desired results by commenting out that section of your code.
Y-Phil ( ) posted Thu, 06 February 2025 at 11:58 AM
philadam posted at 5:33 PM Wed, 5 February 2025 - #4493487
Y-Phil
Which version of Poser are you using?
I mean, I use this addon quite everyday and I haven't met this situation, but I'm using Poser 13.3.895, and I haven't tested it with older versions, nor with Poser 12.x
The code you are referencing in your comment is to allow me to rename the output in some cases, for example when I'd like to distinguish between lips, face, etc.
That being said, I don't recognize the "GlossSpecular Convert" compound node?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
philadam ( ) posted Thu, 06 February 2025 at 4:34 PM · edited Thu, 06 February 2025 at 4:35 PM
Y-Phil posted at 11:58 AM Thu, 6 February 2025 - #4493518
Y-Phil
Using Poser 13.3.895. GlossSpecular Convert I duplicate in my code. You can find it in: "included\Superfly Materials\Superfly Tileable\!Guide\Gloss-Spec_Conversion."
Right or wrong this is just an observation that I found by trial and error to get my compound nodes (compound to compound) to connect correctly using your code as a baseline.
Tried to get some documentation on Poser 13.3 poser python compound nodes from support but they told me none was available yet. Told me that they would include an updated Poser Python Methods manual in the future.  I am currently using the PDF manual from Poser 11 Pro, but it does not include all the methods for compound nodes.
  • 1
  • 2
