Sun, Feb 16, 11:42 AM CST
Renderosity Forums / La Femme 2
Welcome to the La Femme 2 Forum
Forum Moderators: Kalypso, JacquelineJ
(Last Updated: 2025 Feb 11 3:47 am)
Subject: need cutoff jeans for her
drawn ( ) posted Mon, 04 March 2024 at 6:49 PM · edited Sun, 16 February 2025 at 11:42 AM
Oh no, I have a gorgeous GF for me shy hero and LF2 needs some cutoff jeans to show her cell and thighs and so forth. just a teaser  please!
don
Tipol ( ) posted Tue, 05 March 2024 at 8:26 AM · edited Tue, 05 March 2024 at 8:26 AM
drawn posted at 6:49 PM Mon, 4 March 2024 - #2986604
don
https://www.renderosity.com/marketplace/products/142997/summer-time-for-la-femme
drawn ( ) posted Tue, 05 March 2024 at 11:35 AM · edited Wed, 06 March 2024 at 2:03 PM
looks great Tirol but I get to a certain place...DkrTo7ZpW5LTRly1x2KScOpj5hbqvPNot1CFcUri.png
I seem to miss hitting the "run simulation" button, but where is it to be found?
don
hborre ( ) posted Tue, 05 March 2024 at 4:34 PM
From your screencaps, you are in two different rooms that are not remotely related to the Cloth Room.  If you are trying to fit the LF clothing to LF2, there is a tool setting under the Parameters tab that will morph LF2 to the LF body shape.  In the Pose Room, set up your animation for as many total frames you require, for example 60 frames.  Start at frame 1 with the morphed LF2 and clothing in their zero position.  Set your animation palette to frame 10 and set the morph tool setting to 0, reverting the morphed LF2 to her LF2 shape.  Go to frame 60 and make certain that the morph is not applied and that LF2 is in her final pose.  Return to frame 1.  Go into the Cloth Room and continue setting up the simulation.  Once you are done and satisfied with the scene, calculate your simulation (essentially run the simulation).
drawn ( ) posted Wed, 06 March 2024 at 10:36 AM · edited Wed, 06 March 2024 at 2:03 PM
I thought I did everything right, but when I really looked at her I see this:
wx3P2IXLVnJUirrJXCz4QIfQinlbL6DB3y1FRwCX.pngdarn
don
RedPhantom ( ) posted Wed, 06 March 2024 at 12:38 PM
Site Admin
looks like you may have moved LF2 after you ran the simulation. Any movement of body parts that the clothing covers requires a rerun of the simulation. Also if you need to move the body, you'll want to parent the dress to her, usually the hip or chest works for a dress.
hborre ( ) posted Wed, 06 March 2024 at 12:53 PM
It is not essential to parent the clothing prop to the figure.  Translate the body position using the parameter dials and the clothing will follow along.  It's the body part movement that can throw the simulation off.
drawn ( ) posted Wed, 06 March 2024 at 12:56 PM · edited Wed, 06 March 2024 at 2:03 PM
I can't run a new sim every time I move her! I tried parenting but would only let me parent to her body and this:
why?
don
drawn ( ) posted Wed, 06 March 2024 at 1:19 PM · edited Wed, 06 March 2024 at 2:02 PM
hborre, I did turn Y parameter dial a touch and this:
hborre ( ) posted Wed, 06 March 2024 at 1:33 PM
Reposing will always break the simulation. There is no way around that.  But, rerunning the simulation will not require entering the Cloth Room again.  In the Pose Room, click 'Animation' on the Taskbar ribbon and the contextual menu, and navigate to 'Recalculate Dynamics'.  Select 'All Cloth' and that will automatically rerun the simulation.  Ensure all the adjustments are performed on the last frame of your animation.
The image below is a render you have seen before but the figure morphed and reposed.  I did not have to re-enter the Cloth Room because this scene has been saved with all the dynamic settings already embedded.  All I did was rerun the animation mentioned above.
hborre ( ) posted Wed, 06 March 2024 at 1:40 PM · edited Wed, 06 March 2024 at 2:02 PM
drawn posted at 1:19 PM Wed, 6 March 2024 - #4482229
Were you on the last frame of your animation and did you have LF2 selected?
At this point, we would need a detailed description of your steps using the Cloth Room.  I do see that this particular pose might cause some fitting problems.
drawn ( ) posted Wed, 06 March 2024 at 1:55 PM
OK but for some reason the first time I deleted the palette that showed the actual animation, so I couldn't hold figger on last frame and change it and I'm confused about things in general!
RedPhantom ( ) posted Wed, 06 March 2024 at 2:05 PM
Site Admin
Drawn, please use the nudity flag when you upload an image with nudity. This includes partial nudity.
drawn ( ) posted Wed, 06 March 2024 at 2:19 PM
sorry, I have no idea how to wave the nudity flag???
don
RedPhantom ( ) posted Wed, 06 March 2024 at 2:22 PM
Site Admin
To help you understand conforming clothing vs dynamic clothing, think of conforming clothing as a separate figure that mimics the movement of your person in real-time like an annoying little sibling. Dynamic clothing is like actual clothing in that it needs something to move it, like a body inside it. However, it isn't real-time. It only moves when you run a simulation because it needs a lot more computing power to calculate all the collisions and bends as it drapes. It would likely bog down your computer as you try to pose your figures.
RedPhantom ( ) posted Wed, 06 March 2024 at 2:24 PM
Site Admin
drawn posted at 2:19 PM Wed, 6 March 2024 - #4482237
don
Look at the picture I posted. It shows where the box is. You can also look just under the message box near the add comment button.
