Forum Moderators: Kalypso, JacquelineJ
(Last Updated: 2024 Sep 29 6:32 am)
Oh no, I have a gorgeous GF for me shy hero and LF2 needs some cutoff jeans to show her cell and thighs and so forth. just a teaser please!
don
https://www.renderosity.com/marketplace/products/142997/summer-time-for-la-femme
From your screencaps, you are in two different rooms that are not remotely related to the Cloth Room. If you are trying to fit the LF clothing to LF2, there is a tool setting under the Parameters tab that will morph LF2 to the LF body shape. In the Pose Room, set up your animation for as many total frames you require, for example 60 frames. Start at frame 1 with the morphed LF2 and clothing in their zero position. Set your animation palette to frame 10 and set the morph tool setting to 0, reverting the morphed LF2 to her LF2 shape. Go to frame 60 and make certain that the morph is not applied and that LF2 is in her final pose. Return to frame 1. Go into the Cloth Room and continue setting up the simulation. Once you are done and satisfied with the scene, calculate your simulation (essentially run the simulation).
looks like you may have moved LF2 after you ran the simulation. Any movement of body parts that the clothing covers requires a rerun of the simulation. Also if you need to move the body, you'll want to parent the dress to her, usually the hip or chest works for a dress.
Reposing will always break the simulation. There is no way around that. But, rerunning the simulation will not require entering the Cloth Room again. In the Pose Room, click 'Animation' on the Taskbar ribbon and the contextual menu, and navigate to 'Recalculate Dynamics'. Select 'All Cloth' and that will automatically rerun the simulation. Ensure all the adjustments are performed on the last frame of your animation.
The image below is a render you have seen before but the figure morphed and reposed. I did not have to re-enter the Cloth Room because this scene has been saved with all the dynamic settings already embedded. All I did was rerun the animation mentioned above.
drawn posted at 1:19 PM Wed, 6 March 2024 - #4482229
Were you on the last frame of your animation and did you have LF2 selected?hborre, I did turn Y parameter dial a touch and this:
At this point, we would need a detailed description of your steps using the Cloth Room. I do see that this particular pose might cause some fitting problems.
Drawn, please use the nudity flag when you upload an image with nudity. This includes partial nudity.
Look at the picture I posted. It shows where the box is. You can also look just under the message box near the add comment button.sorry, I have no idea how to wave the nudity flag???
don
don
