Forum Moderators: Kalypso, msansing Forum Coordinators: Anim8dtoon
(Last Updated: 2025 Feb 18 3:12 pm)
That said, I just checked, and I did in fact have the nipple morphs on when I thought I didn't. Apologies! *wipes egg from face*
Here's the same pose with all morphs off (I hope) and a more opaque shirt (except for sleeves). I haven't made the skirt longer yet, but it turns out not to ride up as much when she's her original, skinnier self.
I was about to yell SHE IS VERY PG-FRIENDLY IN DEFAULT but you beat me to it LMAO (or: how to tell that odf got the Pro version, dialed favorites and saved it back to library xD )
Feel free to call me Ohki!
Haha, sorry! I think I must have used the "areolas small" morph in my default character, which made them a bit pinchy.I was about to yell SHE IS VERY PG-FRIENDLY IN DEFAULT but you beat me to it LMAO
Tipol posted at 8:39 AM Mon, 28 October 2024 - #4490844
great! can we know more? sale? tutorial?Well traditionally, I hide all my procedural materials in clothing freebies and leave it to the brave to find out how to modify and adapt them. I do like sharing the toys I make, but it's a bit like lending out my bicycle when I was a teenager: "Sure, you can have it, but you should know that it veers a bit to the right, the front brakes don't work so well, if you go into the lowest gear it tends to get stuck there, and I think the left pedal is about to come off."
Anyway, fitting to the thread title, it's all very much work in progress at this point.
hborre posted at 9:17 AM Mon, 28 October 2024 - #4490845
Well, you asked for it, so don't complain when your eyes start bleeding.Incredible-looking procedural fabrics. I am very interested in what the Shaders look like in the Material Room.
Here's the top level of the red-and-black checked fabric:
The central piece is the Weaver compound node which I made. It takes the u and v coordinates - which I'm distorting by adding some fractal noise in order to introduce irregularities - a scale to determine how many threads to draw per uv unit, a gap parameter to determine the density of the fabric, and three more that determine the type of the weaving. The main outputs are a bump map the simulates the elevation of the threads in the weaving and an opacity mask so that we can look through the gaps between the threads. Then there's some output that helps with the coloring of individual threads as shown in the lower left corner. I'm also adding a bit of extra bump after the fact.
Here's what the inside of the compound node looks like:
That goes on for quite a bit, as you can see by the sliders. How did I make this? Not by hand, obviously. Here's the script with the formulas (actually a slightly more recent version with more outputs):
Together with a library I made, the script produces an .mt5 file that I can load into Poser to get the compound node. It's a bit like a poor person's matmatic and loom.
Holy scrambled noodle, Batman! xD
Edit: you could totally sell a pack of procedural shaders for Superfly, wink wink nudge nudge.
Rhia474 posted at 8:37 AM Tue, 29 October 2024 - #4490875
Ooh, challenges! How Intriguing! To tell the truth, I've got some ideas, but whether I'll be able to pull them off I don't know.Wow. Can you make nubby silk? Woven brocade? Corduroy?
*grabbyhands*
Incidentally, I wonder if textile enthusiasts would give me dirty looks if I claimed that corduroy was just a special case of brocade.
Well, if I worked out the general principles and published some example materials for free, enterprising minds who don't have the privilege of a well-paying day job could use that as a starting point.Holy scrambled noodle, Batman! xD
I'm sure this is far away from what actual nubby silk looks like, but it's kind of nubby and kind of silky, and I like it.
What I really need is a better understanding of how the fBm node works so that I can do per-thread variations in thickness and coloration in a random but controlled way. So, I guess I'll work on that now...
Here's a first take on linen. Took me a while to get the variation in thread thickness working nicely. None of the texture nodes in Poser were particularly cooperative, so I ended up with a different approach to achieving randomness. Here the thickness of each individual thread is still constant all the way through. I think that works out alright for linen although it's not ideal, but for other materials I'd definitely want it to vary along the thread as well.
sweet! is it hard to change the colors? i know some of your spaghetti node shaders are, well, challenging to tweak colorwise. and will any of these take a texture so you could have like textured printed fabric? used to use Loom all the time so am happy to have a new mini-loom to play with.
lost in the wilderness
Poser 13, Poser11, Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine! Win11, I7, RTX 3060 12GB
Unfortunately, I've never used the Loom myself. I saw BB's posts about it back in the day, but was too busy with other things then, and then when I came back to Poser in 2021, I jumped straight to P12. A pity, I'm sure I would have learned a lot.
The weaver node does not produce any color output itself. One can plug anything into the diffuse color of the shader, be it a solid color, an image map or a procedural texture. I'd probably use a plain or satin weave in that case. Things get more complicated though when one wants to simulate a weaving where the color varies by thread, the simplest case being one color for the weft (horizontal threads) and a different color for the warp (vertical threads). The weaver node produces some output to help with that kind of thing, such as masks for the warp and weft, a thread number and thread-relative uv coordinates - some of these heavily inspired by a YouTube video I watched.
The houndstooth and checkered fabrics I showed are examples where both the warp and the weft use two different colors. I imagine in such cases I could hide away the logic for the color distribution into a compound node and give it two inputs for the colors to be used or something like that. It really depends on the specific material. I admit I haven't been very good at that kind of thing in the past, in part because I find organizing a shader into logical parts and laying it out on the screen in a readable fashion quite challenging.
i never understood bb's stuff even when i used it but the results were really interesting. and the spaghetti was impressive. i'm not sure we had compound nodes back then either, which at least help clean up the palette.
would be nice to be able to modify colors easily, but whatever you do works for me.
didn't see the yellow dress above, that's perfect.
Yes, I'll try to remember to always make it obvious how the colors can be changed.
Incidentally, here's the outcome of the latest battle with my age-old enemy, the villain known as Denim. I've yet to best the legendary foe, but I feel that their advantage is becoming smaller.
Here's a simple tartan. Not much in the way of calculation in this case, just using a 1-row image for the pattern that I'm loading into two separate image-map nodes. I'm debating whether I should make another compound node that lets one specify a sequence of colors and thread counts. The problem is that because of how Poser nodes work, I'd have to put an arbitrary limit on the complexity.
I would SOOOOO buy these mats! I love procedural mats, and these are gorgeous.
Old lady hobbyist. All visual art or fiction is "playing with dolls."
VISIT MY ALBUMSFOR COMICS: https://www.renderosity.com/users/VedaDalsette/gallery/albums
You can also get to my comics from my book website: https://www.vdbooks.com.
What I'll probably do is get a dozen or so fabrics together, make sure they're all up to date and release them as a freebie. With most of the complexity hidden away in compound nodes it should not be too hard to create new fabrics after seeing a few examples, but maybe I'm overly optimistic here. :-) Anyway, it will all be free for commercial and non-commercial use as usual, so if any enterprising vendors wanted to create more fabrics based on my setup, they'd be very welcome to.
Here's a more complex tartan I made up:
And here's what it looks like in the material room now:
As you can see, I moved away from the image input and am instead now using a pair of compound nodes for the thread counts and colors. I think I may have to increase number of inputs from 8 to 12 or even 16.
Varnayrah posted at 6:29 AM Sun, 10 November 2024 - #4491205
Well, here in Australia it seems that I have to declare any income for taxes, no matter how small, and I can’t be bothered to set that up. Gifts on the other hand, are completely tax free *wink-wink-nudge-nudge*Now I have a third favourite fabric *gg* Gorgeous!
A freebie with your fabrics would be much appreciated, but I too would be very willing to pay for them.
As long as we can get the nipple morphs set to zero, we should be good, yeah.
