Forum Moderators: Kalypso, msansing
(Last Updated: 2025 Feb 17 10:21 am)
It's almost Christmas, it's been 10 days since I started Poser again after a 7 month break, I'll be very happy to play with all these textures.
I have followed all your work from afar and as has already been said, it is of high quality, but certainly of great complexity of crossed knots!
Thanks in advance.
It's all described in the readme file. In the material room, find the node that's plugged into the "Base Color" channel of the "Principled BSDF". That usually has all the colors listed, except for the flannel which has another node in between. Just play with the colors and see what happens. If there are any problems, let me know.Sweet, you are so generous! One quick question: is there a way to change the colors?
looks very nice now
SIGASIGA posted at 12:35 PM Wed, 11 December 2024 - #4492071
The furniture textures were replaced with odfs fabrics too :)Very beautiful composition.
I don't know who made the fabrics including the furnishings... it looks good!
you can see the original furniture textures here :)
https://www.renderosity.com/marketplace/products/144226/modern-apartment-bedroom
this bedroom is included in Poser 11.
Does anyone here who's tried out my fabric materials also have a copy of Poser 11 lying around? If so, could you do me a solid and quickly check if the materials work with that? I only have P12 and P13 and I'd like to know how backwards compatible they are (P12 seems to work).
No big rush, just curious.
Poser 11 doesn't have the PrincipledBsdf node so they won't work.
Ah, I should have known that. Thanks!Poser 11 doesn't have the PrincipledBsdf node so they won't work.
I thought I'd add a pair of ankle socks, the open shirt from earlier and a new choker to her heatwave outfit. The choker is a bit wider than the one from the bikini set and it has a loop so that users can dangle any appropriate props they may have lying about from it.
Happy 2025 everyone!
Starting with the office combo, I am now making two versions of every fabric material for my published clothes, one using the P-BSDF node available from Poser 12 onward, and one for P11 users with the physical surface node in its place. So then for the new outfit - henceforth known as the explorer outfit because of that alphabet thingy I have going - I made a pair of comparison renders, and just for fun, also used two corresponding versions for the skin and backdrop materials (not the hair, eyes and teeth, though). Then I reduced the strength of the main light a bit in the P-BSDF version because I was starting to get washed out highlights on the skin.
Thanks! Yes, I heard about that but haven't tried it yet.Excellent. As a note, if you plan to use displacement in Poser 11 & 12, it has been fixed in Poser 13. The feature had been broken for quite some time and displayed incorrect displacement.
I don't do yoga, so I couldn't really tell, but I would probably shorten the legs and sleeves a bit and lengthen the top and maybe tie it around the waist for that if I were her. I took some inspiration from 70s clothing and things I've seen on Instagram for this one.
Turns out I can get a pretty decent machine knit simulation by rotating and stretching a twill and adding another bump that pushes down the areas between the "ribs" a bit. Which, to be honest, is pretty similar to what I did for my earlier procedural knit texture.
