Sun, Feb 9, 9:04 AM CST
Subject: Really useful and FREE !!! ... Adjust the length of the P4 skirt ... FREE !!!
geralday ( ) posted Fri, 04 January 2002 at 4:15 PM · edited Sun, 09 February 2025 at 7:24 AM
Attached Link: http://members.tripod.com/~knittingman/index.htm
The P4 Skirt is perhaps the most useful of the clothing props for animators because of it's simple mesh and small file size. With these morph targets you now have much greater control over the skirt's length.. particularly when requiring a longer style.
wgreenlee1 ( ) posted Fri, 04 January 2002 at 4:18 PM
wow thx but do you think it might have adverse affects on the texturing,we might have to remap in uv mapper maybe?
Jaager ( ) posted Fri, 04 January 2002 at 4:25 PM
The problem is that actual area of the facets is much larger than the area for it on the texture, relative to the rest of it. What you can do is save the morph for the long length as a geometry, UV map this and use the default length as a morph for the long one. Squeezing facets seems less hurtful to a render than stretching them.
geralday ( ) posted Fri, 04 January 2002 at 4:31 PM
Jaager's spot on with his advice. ps.. the texture on the image is the default ground texture! Best wishes, Gerald.
jstro ( ) posted Fri, 04 January 2002 at 8:36 PM
Hey, that ground texture makes a pretty good material! Thanks for the freebie, geralday; and thanks also to Jaager, for the tip. jon
~jon
My Blog - Mad Utopia Writing in a new era.
wyrwulf ( ) posted Fri, 04 January 2002 at 11:27 PM
Online Now!
more good stuff, geralday. The ground texture is a good deal. I loaded it as a bump map a long time ago, and use it as a generic bump.
jamball77 ( ) posted Fri, 04 January 2002 at 11:53 PM
I really appreciate your freebies! The ring smart props, the barbie! and now a cool skirt MT thanks!
