Sun, Jan 26, 12:18 AM CST
Subject: New User Same old problem
arrow1 ( ) posted Sat, 05 January 2002 at 9:36 PM · edited Fri, 24 January 2025 at 4:43 PM
I have trouble getting my characters (figures and things, like cannons and specialised clothing)to open up in Poser.The thumb shows up ok,I put cr files into either characters male or female or new figures ,Textures under the the name of the model and also obj's into geometries under the model name.When I try to open them into the studio some of them after a long while open to geometry type lines.Some won't open at all and POSER locks up.I don't have any problem with pz files,poses or props.I have searched forum archive files but they don't tell me exactly in plain terms what I want to know,and neither does the Poser manual nor any other tutorials. Can anyone explain in plain terms step by step how to put a downloaded character (CR File)with geometries (OBJ'S),textures and bumps into Poser and how they would set it up.Cheers Arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Little_Dragon ( ) posted Sat, 05 January 2002 at 10:51 PM
If it opened before, but has since stopped working, it's probably the ever-popular "corrupt .rsr" problem. Hunt down the .obj in the Geometries folder and delete the corresponding .rsr binary. Then relaunch Poser and load the character from the Library. Poser will rebuild the .rsr and that problem will be solved (at least until the .rsr gets corrupted again).
thgeisel ( ) posted Sun, 06 January 2002 at 1:42 AM
The easiest way to find out where everything belongs is to open the cr2 file in a editor ( best one www.editpadlite.com its free) on top of the cr2 you find a line in which folder the obj-file belongs. at the end of the file you find a section with texturelists and in which folder they belong
Nance ( ) posted Sun, 06 January 2002 at 6:35 AM
The only file type that absolutely, positively has to be in a specifically located, precisely named folder are the .obj files in the geometries folders. You said "obj's into geometries under the model name". If you meant that literally, that may be your problem. You cannot make up your own goemetries folder names, you have to use the ones designated by the author and encoded into the .cr2 files themselves. This case-sensitive file path for the .obj files is almost always give in the readme ('cause the author knows you're gonna need it). However, if accidentally omitted, you can simply do as thgeisel suggests and actually look inside the .cr2 file for the correct path to the .obj in the geometries folder. And, if you did just really hate where the author put the .obj files, you could change those file path lines within the .cr2 (there are two of them for each poseable figure included in the .cr2 and both must be changed).
