Sat, Feb 8, 6:31 PM CST
Subject: Realstic Grass?
Bigballa111cmb ( ) posted Sun, 20 January 2002 at 5:34 PM · edited Mon, 03 February 2025 at 4:20 AM
Is this possible with Bryce? Are would I have to attempt to paint grass in the post-work? I haven't found a good method of making realstic grass..
Stephen Ray ( ) posted Sun, 20 January 2002 at 8:43 PM
Grass is a hard one, Here's a place which has some grass models http://www.3dplants.com/ They work good for patches, but you can't really fill up the whole scene with them. Another option is to use a flatten cube or even a 2D plane with a decent tex & trans map for distant grass ( doesn't work to good close up ) Infinite planes don't work to good for this, because the tex map gets to stretched out. Then there's always the mask render and post work.
Stephen Ray
Wadus ( ) posted Sun, 20 January 2002 at 9:05 PM
you can make a new terrain--go into the terrain editor, hit new and then hit spikes a time or two. Instant patch of grass...
Wadus ( ) posted Sun, 20 January 2002 at 9:08 PM
forgot to mention you might want to make the grid size about 512-ultra fine for close grass.
Alleycat169 ( ) posted Sun, 20 January 2002 at 10:35 PM
Yes the Spikes in the old terrain editor works pretty good. For more detailed grass 3dplants.com is the place for free grass meshes.
dg3d ( ) posted Mon, 21 January 2002 at 12:34 AM
This is a demo of what Wadus said and it's a good way of doing grass. Me after doing spike and see the result, i will often use raise or lower, depending on what you are looking for. This trick was given to make a forest when mixes with another terrain. Pleiades
