"Objects disappear in locked layers"
"Pasting or loading a material via the menu onto a group of objects made out of different materials would not apply the material" (it was happening all the time with Poser imports)
that's the fixes I was waiting for !
But what does "it may not perform as expected" really mean ? should I be afraid ?
Well I won't try it first... go ahead my friends, and tell me if it's running fine ! (especially if your OS is WIN2K)
I had many problems updating to 4.03 (even using the Back folder)...
Eric
BOY, am I glad I waited! I have had soooooo many headaches with vue, you would not believe it. The last time, it took me at least 5 times of install,reinstall to get it to work, so.....I think for now........I will let sleeping dogs lie, and not worry about the update. (: Thanks everybody, and I am sorry that you are having problems...........hopefully, you will be able to fix them soon. genny
It's late, but my little VUE must work properly before tomorrow morning...
I did a total re-installation :
The update process worked but I had the same message as Guitta "incompatible language". After pressing "OK" the interface was indeed in 2 languages (french and english). This is strange...because my OS is in english !
I won't try anything else, I'll stay with VUE 4.03 for a while...
For the following update I would really like a nice little CD-rom with ONE totally updated application in ONE language ! I'm even ready to pay for it ! Since I have VUE4 (2 months) there has been too much downloading, launching, replacing, removing, updating, uninstalling, etc.
How old is VUE4 ? 5 months ? and it's already update n5 ?!?!?!?!?!
Eric
LOL Hein! That explains it all. :) Folks, remember this patch is a beta. "May not perform as expected" means now that the fixes have all been implemented and the most outrageous patch bugs have been squashed, it's time to check for additional bugs that might've sneaked through. If you try it and run into problems, post the details here as Guitta and Eric have done. It helps all of us stay "on top" of what's happening, and it helps E-on find the nasties and eliminate them. :)
To Steve and all, First thing I did this morning was to fire up Vue 4.05 beta again. I got the same message about incompatible language. My OS (Windows 98) is is french. When I click OK, Vue opens fully in english language, but freezes immediately, I cannot create a new scene or open any existing one. I cannot do any thing on my computer either, because every thing is frozen (Windows). I had to shot down my machine (with the button) and restart it again. Also I have put back all the files and folders from the backup into the Vue root and it worked fine. But as I'm curious, I have done the whole thing again (installed the 05 beta) and got the same result as yesterday. Now I'm back to my Vue 4.03 and will wait for a better update. I'm lucky it works again. Guitta
OK, well now, the first thing I wanted to do was to test the boolean fix. I can't even import anything now. I go to the Object menu>Import Object. The screen flashes and then all the viewports disappear, and no import browser opens. Note that that's just for Importing objects, and the Load object dialogue works..as long it's a VOB from the library. Clicking on File in the library window has the sanme effect as trying to import, only the screen doesn't go blank, ut rather simply nothing happens except I can't move my pointer around for about 20 seconds.
Ok..this is weird! I installed the beta update and the program ran fine. Closed program and tried running it again later and WinXP brought up error message. Thought something had gone screwy with my system and rebooted. Tried to run Vue again..got an error. Program will NOT run. Decided to reapply the update on a whim. And guess what..now the program ran. BUT the screwy part is that it only ran the first time; casing an error upon trying to run it again. Reinstalling the upgrade allowed the program to run. So what's up? Is the program now screwing up some file everytime it runs??
I will not be experimenting with the "beta" version either. Besides, the main issue I wanted to see resolved it not listed... transparent materials showing white when illuminated by volumetric lighting :( Oh well, maybe in another 3 months.... meanwhile, I have 5 Vue renders just sitting waiting on a "real" patch. Greg aka Reddog3d
Guitta: It seems that the language resources are not being transferred correctly - that's one of the (numerous) problems that are caused by having updates available in all languages at the same time. On the other hand, I'm sure our international users appreciate not having to wait for the release of localized updates.
Anyway, you said your OS is in French. What language was Vue 4.03 before you installed the update? French also?
Audity: the program is not going to run if the update failed part way through. We are currently modifying our updater so that if it fails for any reason, the program being updated is automatically restored to its previous state.
Sacred Rose: we have found that some BUM files referenced by PZ3 scenes are actually not read correctly by Poser either, although Poser doesn't complain. In such cases, Vue will stupidly report an error... That is, for instance, the case with "P4 woman bump" and "P4 man bump" in the "Poser 4 textures" folder.
Is that one of the files that isn't loading in Vue 4?
MikeJ: does the same thing happen when you press "File" in the other browsers? (say, the atmosphere browser?) What about loading a picture into the material editor?
Uroboros: can you do the following for me:
Thanks to all for trying the update. It's only with your help that we can get them to work right...
Steve.
"does the same thing happen when you press "File" in the other browsers? (say, the atmosphere browser?) What about loading a picture into the material editor?" It sure does, Steve. I tried it with the atmosphere browser and the material browser, and it happens in them the same as in the object browser. Aside from that, the OpenGL shaded preview looks different...better, actually, unless I'm imagining it. And yeah, since Greg brought it up, that volumetric problem sure would be a nice one to have fixed. :)
Well. It says nice and clearly "beta" and what that means in software terms is "we think it'll work but it needs testing by lotsa peeps". Personally, there's no way I'd run up a beta on my only, essential, money-earning copy of an app this complex. I have two advantages though. I am only a hobbyist renderer; and I have nice natty swappable hard disk trays with differnt play OS installations on. So I will try it out on a cack installation and see what happens. Doesn't look hopeful though! :~ Poo! (can I check Adult Content now?}
Right, I've loaded the beta and it installed fine. Here are a few things I have noted so far. More details will be sent to e-on. 'import object' crashes the program. -------------- In terrain editor, reset the terrain to all zero, went into options and altered seed and an amplitude, clicked ok and still got a flat terrain. If I do this without reseting, using options does alter the terrain, but If I reset, I can't generate a terrain, it just stays flat. no other apparent problems in terrain editor.
Steve, concerning the .BUM problem. I been unable import any .PZ3's without the .BUM error popping up. It does not seem to matter what .PZ3 or .BUM file I choose to use, Vue always throws up the .BUM error message. I'm wondering if it may be something to do with file name conventions and/or program installation locations? Martin
Â
Twitter: Follow @the3dscene
Steve I did what yyou suggusted and it didn't help. Still had to reinstall unpdate to run program. So perhaps WinXP is doing something screwy to Vue. And it it means anything... Event Type: Error Event Source: Application Error Event Category: None Event ID: 1000 Date: 1/24/2002 Time: 3:11:18 PM User: N/A Computer: VBUTTARO Description: Faulting application vue4.exe, version 0.0.0.0, faulting module ntdll.dll, version 5.1.2600.0, fault address 0x00003741.
Red Dog: I know we have fixed some problems with volumetric spotlights, but I'm not sure it is the problem you are talking about, because I couldn't reproduce that problem. If you'd care to get me a scene I can check it out for you (make sure you include all the maps, especially the transparent ones).
Guitta: I can see now why you are getting the problem. The installer is setting some of your resources to your OS's language, while others are untouched, thus remaining in English. This problem has been addressed in Vue 4.04. We will fix it for people updating from 4.03.
MikeJ: what OS are you running?
Zoon: yes, I see that the amplitudes are not being kept between two openings of the Options dialog. I wasn't able to reproduce the problem with the plants, though... Re/ the import object crash, is it the same problem as MikeJ (does it happen each time you get to select a file using the explorer)?
Martin: to fix this problem we need it to happen here; unfortunately, it works fine on all our computers... The only other option would be to have someone who has the problem and would be willing to spend a lot of time installing test versions for us, and trying them out to see what goes wrong.
Uroboros: you mean that after restoring the Backed-up Environment files the program still crashes? Any chance you could be installing on XP without having administrative rights?
Steve.
Attached Link: http://cybervue.multimania.com/trans.jpg
Steve, thanks for your reply. The problem reddog (Graig) has with transparency is also mine (Vue 4.03). Whenever is used a volumetric spotlight (not a volumetric atmosphere) on a Poser figure (Vicki and others), the eye lashes, the hair and parts of the cloth what are supposed to become transparent, comes out white. I already had told that to Nicholas about last October, but he answered me also he cannot reproduce it on your machines. I have upload a sample image at the link above. If you also need a vue file, I will create one for you. GuittaAttached Link: http://reddog3d.crosswinds.net/volume.htm
Yep, exactly as Guitta shows (and it's Greg ;-) I too have several scenes that illustrate the problem. Let me know where you want me to send it, and it will be on it's way. As Guitta said, it was reported back in October when patch update to 4.03 came out. You can also check the link to see some of the other oddities I have some across when trying to work with the volumetric lighting.Well, I just discovered it's not reading the .prv files on any of the plants, so they load with no leaf materials. I was going to upload a picture, but when I clicked on the thingy to save the pic, the message, "you are about to save a picture that has been rendered in preview mode...blahblahblah..." came up. I wasn't worried about the quality, so I told it to not switch to final. Then Vue just simply crashed. Sop, no ability to use plants now either. as for how they look, just picture the trees with the leaf textures removed.
Wireframe without OpenGL works fine now. My house project no longer crashes when selecting the cylinder and cube for the door. However, droping my group is a bit unexpected, as it tries to drop the cylinder to the ground too - instead of maintaining the relative distance of the objects within the group. If I wanted the cylinder to drop, I'd select it by itself. Beside the missing branches and interface redraw issues, there is also a bit of an issue with rendering a full screen image on Mac. It doesn't seem possible to do anything with such an image after it's rendered. Actually you just have to push Escape before the menus return, but it's not obvious. And cancelling with Escape doesn't bring the menus back either - have to press Escape twice more (in 4.04 too btw). If you go back to the scene with F8 - getting back to the 3D scenes becomes difficult as F8/Esc don't do it. - n8
Interesting nathany. In Vue 3 (and even 4 sometimes) every now and then I had the problem of it dropping all the way to the ground things that were grouped, but they didn't ned to be boolean objects--just grouped objects. But it was pretty rare to have it happen. I'm sory to hear about your problems too, roadtoad, but at least I can tell you that the 4.03 patch (Full Update) on the E-on site took away most of the problems in 4.02. I just ended up reverting to before the 4.05 patch. While I don't have the problem Guitta had with not being able to even open Vue, it's still unusable if it can't import objects, open files in the ediors, or grow trees with leaves on them. ;) OK, I'm ready for 4.05beta2....
Uhm... Guys... wouldn't it be nice if it was possible to choose what language you want your Vue to be in? My OS is german, but I do prefer my 3D-programms to be english versions, because it makes it far easier to exchange data with english applications - something I have to do quite often. Oh, another thing: The german updater still empties all your libraries and forces you to manually rename all of your materials, functions, atmospheres and so on. With about 800 user-defined materials and about 200 atmospheres in my library, there is no way I am going to rename them all manually. So please, please add a function to the updater to choose the appropriate language and do not simple take the OS language. Joerg
Oh Yes Joerg ! that language problem should really be fixed. I run some softwares in french others in english and my OS is in english. It never causes any troubles...
With VUE, for each update, I have to replace some files here and there. The program is always transformed is a french version ! Once in a while I even get "sonnenlicht" instead of "sun".
Message to e-on :
In the root directory there should be a "preference" file, where all your personnal settings (language and options) are recorded. The updater would read it before doing any modifications. Or, like Joerd proposed it, the updater shouldn't launch itself directly. A little window with "select your language" is a good idea.
There is even an easier solution : make one update application for each language !
Eric
The very first beta of Vue 4.05 has just been released. It's actually our first update for the Mac version! Here is the list of fixes included in the update:
Please note: The update works for version 4.03 and up only.
You can download the update here:
Vue 4.05 Beta 1 Update for Mac
Vue 4.05 Beta 1 Update for Windows
Keep in mind that this is a beta version of the update, so it may not perform as expected... You can revert to the previous version by copying the files in the Back sub-folder (created by the updater) into the root folder of Vue.
Enjoy!
Steve
