Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 12:01 am)
I too would like a better UV map with the feathers separated. I started doing it in Lightwave,where I have no problem selecting single feathers, but it's slow going, because I am trying to put the same sized feathers on top of each other to save space on the map. The model is heavy in UV mode for my system. Although just separating the feather would be easier, I could give it a go that way if you can wait a few days.
Dominique Digital Cats Media
To dominique B: objaction Mover could be a solution to give an encrypted OBJ. To decrypt it I must have the original one. To Lovelylady: I don't know how to mix an UVS with an existing objet, I'm going to try. To hogwarden, in poser, I can't select each feather: the body parts are group of feathers, is there a solution?
Hello Everybody!! I'm trying to make a new UV map for the great Angelyna wings (with Steve Cox's UV Mapper) but I can't select each feather separately (either with select by group or select by material). I also tried to select by vertex but I've got points of other feathers selected. Have you a solution? Thanks
