Tue, Feb 4, 5:56 AM CST
Subject: bad hair day!! please help!
BEANZ ( ) posted Fri, 08 February 2002 at 6:14 PM · edited Tue, 04 February 2025 at 5:24 AM
yeah very bad hair day here! i included a pic and u can c wotz wrong in it. i just cant get the hair 2 look right, i got the hair settinz up as u can c in the pic, so can any1 tell me the settinz i should hav and wot texturez go where?
VirtualSite ( ) posted Fri, 08 February 2002 at 6:22 PM
Set the transparency minimum to 100% as well. That should fix it.
Lovely Lady ( ) posted Fri, 08 February 2002 at 6:24 PM
Change the object color to white and the hightlight color to black and pull down the highlight size and that will get rid of part of the problem.
Impudicus Rex ( ) posted Fri, 08 February 2002 at 6:29 PM
BEANZ, I'd offer to help but I do not enjoy reading your maaner of writing. If I have to decode what you've typed, then sorry. I'm not personaly attacking you, I just don't care for what you've done to the English language. And don't get me started on people that say "axed" instead of "asked"... shudder
Valandar ( ) posted Fri, 08 February 2002 at 6:33 PM
Turning on anti-aliasing will also help
Remember, kids! Napalm is Nature's Toothpaste!
Little_Dragon ( ) posted Fri, 08 February 2002 at 6:45 PM
Check the other hair layers to make sure you have identical Trans Min, Trans Max, and Falloff settings. I like that font.
shadowcat ( ) posted Fri, 08 February 2002 at 7:03 PM
I have to agree with Rex.
BEANZ ( ) posted Fri, 08 February 2002 at 7:40 PM
ok i'll try and write normal this time if it makez you happy, lol i was in a rush last time. in the meterial drop down bit in the pic what iz the difference between mid_U and mid_L ? and the same with the otherz. also i have texture mapz and transparent mapz for mid and out layerz but only a transparent map for the in layer, i downloaded them so i dont know if thatz right? ive tryed what you have all said and it has helped but still lookz a bit weird :-S thanx for your time
VirtualSite ( ) posted Fri, 08 February 2002 at 7:45 PM
It could just be a weird hair prop. =)
Impudicus Rex ( ) posted Fri, 08 February 2002 at 7:52 PM
Okay... Mid_U and the rest are the names given to the seperately texturable groups of plygons on this particular object. Try giving each one a unique "Object Color" and look for yourself. Set texture map to 'none" for a better look. In order to get the best results from your hair: Hilight, Ambient, Reflective colours all to black. Make sure it is absolute black (RGB value of 0,0,0) Click thecolour swatch and make sure. Highlight size set as low as it will go. (1% I think) Transparnecy Min set to 0% Tranparency Max set to 100% Are there seperate textures for mid, in, and out? If so select each material group and assign them their respective textures.
Routledge ( ) posted Sat, 09 February 2002 at 3:24 AM
Not having a texture for the in layer makes some sense as being on the inside you wouldnt see it. I would guess the inner layer is only for the fringeing at the bottom and only needs a colour set on it. Dont use highlights on anything where the edges are supposed to be completely transparent, set it to black RGB = 0,0,0
Puntomaus ( ) posted Sat, 09 February 2002 at 4:42 AM
This looks like it is Kozaburo's sample hair that you can download from his site together with a tut on how he does his transmapped hair. I did't get it to work too but on the thumbnails on his site it looked great and I think you can make two different hairstyles with this probs.
