You probabley already did this, but did you export is from Poser as an obj first? I can't imagine the Las Vegas hair is that much more complex than Antons changing pony tail (curly mode) with two extra tail bits added (which is part of the current scene I have going). Have you used heavy models in Bryce before? I'm new at this myself, so I don't know who's who here yet. Sorry if I'm pointing out obvious stuff to you.
I don't use poser much, (actually something very, very near to not using) but if it's possible you could try to cut the object in pieces and make a new file for evey piece of the model. Then import these files one by one in bryce and put them together, that might do the trick.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
i had kind of the same problem with the wood elf hair. someone pointed out a way to me that worked great for me. load the OBJ file into a text editor after exporting from poser. search and replace all instances of '#IND' and replace them with a ' ' (blank space) and resave. now it should import just fine. it did for me anyway...good luck.
Greetings all.
I've tried importing the wonderful "Las Vegas" hair into Bryce and get an error every way I try. Straight out of Poser I get the dreaded "I/O" error. After using UV Mapper, I get an "out of memory" error. I've tried importing it by itself, in individual groups, using Grouper, and everything I can think of. Anyone else have this problem, or better, have a solution to this? Thanks in advance!
