Thu, Nov 14, 12:09 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: Turbulent water
big_hoovie ( ) posted Wed, 15 May 2002 at 8:58 AM ยท edited Thu, 14 November 2024 at 12:01 AM
What would be the best way to make water look turbulent? I am doing this for a water fall(I posted a couple of times previously, under title of render tests) I want the water near the edge of the water fall to be more turbulent than the water farther away. Should I use lattices, or is there an easier way? Thanks
Aldaron ( ) posted Wed, 15 May 2002 at 9:15 AM
A terrain would probably be the easiest way.
big_hoovie ( ) posted Wed, 15 May 2002 at 9:18 AM
sigh...i'm horrible with shaping terrains....unless you know of a tut online somewhere, that can explain how to get the effect I want...???
Aldaron ( ) posted Wed, 15 May 2002 at 9:28 AM
Do you want just ripples coming from the waterfall or actually something closer to like a spray? For the spray I'd experiment with cloud textures using spheres. For ripples if you have photopaint or something similar you can create a greyscale using the ripple texture that is in photopaint or create concentric circles and add gausian blur(about 2 pixels).
cambert ( ) posted Wed, 15 May 2002 at 10:46 AM
Attached Link: http://petersharpe.com/Tutorials.htm
Peter Sharpe has tutorials on making waterfalls with terrains, splashes, and mist/water vapour. His tuts are always good to follow and downloadable in pdf form too (yeah pete! :-). Plus they're linked from the Bryce tuts section of r'osity. Hope this helps - good luck.
EricofSD ( ) posted Thu, 16 May 2002 at 2:44 AM
You can do it post production by using Photoshop filters. I like to put in sphere's with cloud texture.
big_hoovie ( ) posted Thu, 16 May 2002 at 11:34 AM
As I have no decent photo editing software, post-work is out of the question. I will prolly just use peter sharpe's tuts. In addition to ripples and spray coming from the waterfall, I would also like to have some turbulence at the top of the waterfall(realistic looking, if possible).
Erlik ( ) posted Thu, 16 May 2002 at 12:21 PM
Hm. What do you think about a little lattice with adapted bubbly glass texture? Might work that way.
-- erlik
sanvito ( ) posted Thu, 16 May 2002 at 4:00 PM
Attached Link: http://www.geocities.com/stevensanvito/page0006.html
I've got a coupla tuts at my site for doing water. There's one for large-scale waves and one for circular ripples. You may be able to combine them to get the effect you want. The ripple one requires a paint program. Paint Shop Pro has gotten to be pretty powerful and very reasonably priced. But I'm not sure if it has the ripple pattern needed for the tutorial. http://www.geocities.com/stevensanvito/page0006.html Steve Sanvito
sanvito ( ) posted Thu, 16 May 2002 at 11:31 PM
Doh! Forgot that there's some free ripple images you can d/l from my tut page. Steve
