Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
there are two ways.. After you set the fbm to 1, click edit>memorise>figure then save it to the library.. doesn't work all the time, but usually(for me anyway) The other way is to set the initial value of the fbm to 1 right in the cr2. Just open it in word pad and do a search for the name of your morph. Where you see, initValue 0 change that to 1 Then save the cr2. That should fix ya up :) Cheers, Noel.
I think I understand the process alright. The only thing I haven't figured out is this: I transfered the morphs other to the shirt (as one morph). Saved it out with a new name. Went back to Poser. Loaded Michael. Set muscular1 to 1. Loaded the shirt. Set all the shirt parts to 1. Created a full body morph. Set all the individual parts back to zero. Set the fbm to one and resaved it to my library. But when I load the "muscleshirt", I still have to set the fbm to one. Is there a way to make the one setting the default on load? Thanks. Kevin
