Fri, Feb 7, 8:30 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: Tailor Question
MeInOhio ( ) posted Sat, 18 May 2002 at 6:06 AM ยท edited Fri, 07 February 2025 at 8:09 PM
I think I understand the process alright. The only thing I haven't figured out is this: I transfered the morphs other to the shirt (as one morph). Saved it out with a new name. Went back to Poser. Loaded Michael. Set muscular1 to 1. Loaded the shirt. Set all the shirt parts to 1. Created a full body morph. Set all the individual parts back to zero. Set the fbm to one and resaved it to my library. But when I load the "muscleshirt", I still have to set the fbm to one. Is there a way to make the one setting the default on load? Thanks. Kevin
Styxx ( ) posted Sat, 18 May 2002 at 6:30 AM
there are two ways.. After you set the fbm to 1, click edit>memorise>figure then save it to the library.. doesn't work all the time, but usually(for me anyway) The other way is to set the initial value of the fbm to 1 right in the cr2. Just open it in word pad and do a search for the name of your morph. Where you see, initValue 0 change that to 1 Then save the cr2. That should fix ya up :) Cheers, Noel.
ronknights ( ) posted Sat, 18 May 2002 at 6:56 AM
It appears you have a good grasp of The Tailor. Have you checked out my Tailor Tutorial that's available in Free Stuff?
MeInOhio ( ) posted Sat, 18 May 2002 at 7:00 AM
Thanks for the help, Noel. And I haven't looked at your tutorial yet, Ron, but I will. Thanks, again. Kevin
