Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Attached Link: http://www.soft-rabbit.com
Vile: If you're on a Mac, you're in luck. MartinC has created a plug-in for GraphicConverter which changes the "green" bump map back into an editable graphic. It's called SpeedBump, and it's pretty great.Unfortunately, I believe there's no such utility yet available for Windows. Boy that's a switch...
a BUM file can be worked on by changing the extention fro bum to .bmp Then bring it into your editing program, conver to greayscale and make your alterations... Then after you are done, change the extention back to .bum and your set. I always make the bum files manually by changing the extention of a bitmap (.bmp) I never let poser make them anymore. Hope this helps.
I am trying to modify the old muscle man bump map but I don't get how in this wierd green that opens in PSP is supposed to be edited. I mean I understand how to create one in grayscale but not here. Anyone know what I am talking about? Thanks in advance
