Sun, Feb 9, 2:17 AM CST
Subject: Mathematics Beyond Me
johnpenn ( ) posted Fri, 14 June 2002 at 8:51 AM · edited Wed, 05 February 2025 at 11:44 AM
So, I was helping out this guy at 3Dcommune with parenting. He was creating one of these doors, and wanted to be able to move all the doors at once. He was able to create his model and make it the way he wanted it, so he's good to go. In the process though, I made one of my own, and it's been driving me crazy. I don't have any use for it, the curiosity is bugging me. I need to know for sure. I've just decided that it's impossible, and I guess I'm looking for either confirmation, or the proper solution. So, here is this "iris door." I want to be able to create this door so that no gaps appear between the parts as it opens and shuts, and so that the parts don't overlap. (I can get it to do one, but not both) I also want to make it posable, so I'm really limited to rotating the parts, and not actually moving them. Well, I suppose I could move them by parenting to another object and rotating that, but that's another story. So, I guess what I'm asking is this: I have this model, and I don't know where the pivot point is to make the parts move tangentally to one another. I don't even know if such a point exists. I tried the logical ones, and then tried all sorts of points for trial and error. Then, I researched cameras, and there is a lot of overlap involved with them, it's really a different concept. Does anyone know how to make this work? Or can anyone assure me that it's just impossible, and I can rest my brain. It's really a frustrating thing, and what's worse is that I fear that the answer lies in all the Math I'd once learned but have long since forgotten. HELP!
ironbrew ( ) posted Fri, 14 June 2002 at 9:35 AM
Im not sure it can be done with no gaps,real iris shutters on cameras all overlap,in my opinion it cant be done without using overlaps though would love to see someone prove otherwise:)
Gorodin ( ) posted Fri, 14 June 2002 at 10:40 AM
ironbrew is right. Can't be done. either have gaps or use overlaps. If you have overlaps, it is ompossible to close entirely. there will always be a hole in the middle because of the thickness of the leaves.
ironbrew ( ) posted Fri, 14 June 2002 at 10:55 AM
Phew glad someone else backed me up as a Design Engineer would have been kinda embarassing if i was wrong lol. Here is some tech sketches i dug up to show real iris setup. They usually use either of these two shapes of leaves though others less common shapes have been used.
johnpenn ( ) posted Fri, 14 June 2002 at 11:28 AM
Thanks guys, I can live with can't be done, but I just wanted to hear it from someone else.
unclebob ( ) posted Fri, 14 June 2002 at 4:25 PM
that is just way too cool.... how did you do this ? would you do a short tutorial on this ? thanks and regards, bob
Spit ( ) posted Fri, 14 June 2002 at 10:42 PM
Just to answer the pivot question (the other stuff leaves me mind boggled!) you can change the pivot point on any object in Bryce. With the object selected, click the 'A' to get the properties up and check 'Show Origin Handle'. Then get out of that. Now, using different views, move the little green dot to where you want the pivot point to be. HTH Sylvia
johnpenn ( ) posted Sat, 15 June 2002 at 11:53 AM
Attached Link: http://www.pennypacker.net/tutorial/irisdoor/index.html
Unclebob, for you, here's a tutorial. I'd have posted it here, but I got a bit carried away with screenshots, and I felt uneasy posting 10 of them here. Anyway, it's at the above link, and I can can pretty much guarantee it'll be there for a while, and if it's needed again, I won't have to dig up this thread ;)
unclebob ( ) posted Sat, 15 June 2002 at 10:13 PM
Wow John.... thanks a million, I very much appreciate your making this tutorial. I was wondering about parenting too... and this helps with that as well. again thanks and regards, bob
Aldaron ( ) posted Sun, 16 June 2002 at 1:19 AM
Just a note. Instead of using a cylinder for the rotation point you could simply select "show origin point" in the attributes for the booleaned group and move that to where you want it to rotate. Does the same thing without having to create amother object.
johnpenn ( ) posted Sun, 16 June 2002 at 3:52 AM
unclebob, you're very welcome. Aldaron, you are quite right. I use parenting because the wire frame is so complicated to look at the parents seem to create a sense of order. It's not a big deal with simple models, but it might be if it were in a big scene. You know, after thinking about it, I just deleted a 3 paragraph rationale for parenting. I still would need the cubes to rotate around, unless there is another way to rotate objects around world center. Either way, I later unparent and delete the cubes anyway (I should add that to the tute). You're right, it would be a good and efficient way to go about this. Is there by chance a way that you know of to "copy/paste matrix" to just the origin handle? Or is it all manual entering? If I could do that, I'd be sold 100%!
Aldaron ( ) posted Sun, 16 June 2002 at 10:57 AM
You can't just copy matrix the origin handle. When you copy matrix then paste the matrix to another object it inherits the original object origin handle as well (IOW if the original objects origin handle was offset by 10 units in the X direction, so will the object you paste it to (as well as position and size)).
