Mon, Feb 17, 9:21 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 16 8:08 pm)
Check out the
Subject: Gothic Cathedral Modeling
Y-Nott ( ) posted Wed, 24 July 2002 at 2:25 PM · edited Mon, 17 February 2025 at 8:49 AM
I a mattempting to model a "gothic" style archway for a cathedral. The only way I have figured out to do it is using boolean objects.. ex: subtracting 2 cylinders from a cube to obtain an "arched" ceiling. Is there another way to go about this that someone could explain to me? I have attached a picture of what I am going for...
igohigh ( ) posted Thu, 25 July 2002 at 10:10 AM
yes, I too would like to learn more about how to do the intricate scroll-like work for such windows. I've tried starting with Boxes but there must be another way to approch or something I am not seeing?
Reyals ( ) posted Thu, 25 July 2002 at 4:32 PM
if you go to www.caligari.com and click on the Architecture Course there is one sample movie you can view which may give you both some ideas. However I believe it's the next movie that shows the actual construction of the vaulted ceiling. but still this maybe give you some food for thought. Hope that helps some, Steve
igohigh ( ) posted Thu, 25 July 2002 at 6:46 PM
Thanks, that does 'open my eyes' a bit, don't have TrueSpace but the consepts are there!
Y-Nott ( ) posted Thu, 25 July 2002 at 7:37 PM
Thanks, the "sample video" was very enlightening! Unfortunatly it ended just as it was about to show the part I REALLY wanted to see!! :-( I hate when that happens! I can't figure out how to get it "skined" from where the video ended...at least not in Cinema 4D. Oh, well...I'll sleep on it, maybe it'll come to me :-) Thanks for your help!
Reyals ( ) posted Thu, 25 July 2002 at 8:12 PM
Yeah I'm sorry for teasing you like that. I thought it might be helpful still ... I do have Cinema 4D 5 (the one that was givin out in a magazine.) and here's an idea if you don't like doing the booleans. once you have the "bars, struts" built (like was shown in the video) couldn't you make splines that followed the struts and then Loft them? I haven't used cinema much so this might not even make sense hehehe Steve
Y-Nott ( ) posted Thu, 25 July 2002 at 10:10 PM
Y-Nott ( ) posted Thu, 25 July 2002 at 10:11 PM
Thats alright, it was a good tease! :-) The booleans have actually been working pretty well for me so far. I suppose it is possible to do it with splines and such, but I don't have much experience modeling that way :-( Here is my work in progress though...hope you like it! By the way, what kind of system are you running C4D on?
Reyals ( ) posted Thu, 25 July 2002 at 10:24 PM
Wow I think you've done a great job on that. Well I must admit I don't use C4D very much I also have trueSpace and I use that for most things. I've got a AMD 800 Windows 98 256 Meg RAM. The Cinema 4D SE was from a magazine ... and I played around with it ... but I couldn't get my head around modelling everything with splines and lofting and such. (I'm sure I've just not spent enough time with it) But once again I think you've done a great job going the boolean route
Y-Nott ( ) posted Thu, 25 July 2002 at 10:33 PM
Thanks, I'm glad you like it! I'm still working on it, have a lot left to do!. I'm running C4D 7 on a Mac, (G4 Dual Ghz).. I was hoping you were a Mac user as well...not that I'm holing it against you or anything! I may have been able to help you out though if you were. Thanks again for your help and comments! I'll keep ya posted on my progress!
Cinema1954 ( ) posted Fri, 26 July 2002 at 3:58 AM
Here's another approach using Cinema 4D without boolean operations (quick tutorial follows).
Annie
Cinema1954 ( ) posted Fri, 26 July 2002 at 4:00 AM
Mini-tutorial, as mentioned above.
Annie
Y-Nott ( ) posted Fri, 26 July 2002 at 7:42 AM
Very cool! Thanks! I will definitly try this approach when I get home!
dan whiteside ( ) posted Fri, 26 July 2002 at 7:36 PM
Boy, I'd love to see more threads like this - especially cinema1954's mini-tut. Works exactly the same in my modeler (FormZ) and makes for some interesting food for thought :)
Thanks! Dan
Boy, I'd love to see more threads like this - especially cinema1954's mini-tut. Works exactly the same in my modeler (FormZ) and makes for some interesting food for thought :) Thanks! Dan
Y-Nott ( ) posted Fri, 26 July 2002 at 10:36 PM
Well...after all the help I got here I ended up putting my "Cathedral" on hold, and ended up creating this! I did my "vaulted ceilings" using a tecnique similar to Cinema 1954's great tutorial. I'll try to put a tutorial together showing the route I took, and post it when I get a chance! Hope you like my new picture!
Y-Nott ( ) posted Fri, 26 July 2002 at 11:19 PM
Heres my "walk through"
Y-Nott ( ) posted Fri, 26 July 2002 at 11:23 PM
tonyJ ( ) posted Sun, 28 July 2002 at 2:57 AM
okay Y-Nott here is my attempt.It's in 4 parts and in Cinema. You will need 2 free pluggins to do it though
tonyJ ( ) posted Sun, 28 July 2002 at 2:59 AM
part 2
tonyJ ( ) posted Sun, 28 July 2002 at 3:01 AM
part 3
tonyJ ( ) posted Sun, 28 July 2002 at 3:03 AM
part 4
jkelher ( ) posted Sat, 17 August 2002 at 7:01 PM
What do you mean, Cut Across the four corner points?
tonyJ ( ) posted Sun, 18 August 2002 at 3:30 AM
Like this
