Wed, Feb 5, 11:02 AM CST
Subject: Poser 5 How do you apply the same trans map?
Blue Moon ( ) posted Fri, 13 September 2002 at 8:53 AM ยท edited Wed, 05 February 2025 at 10:51 AM
Anyone know (or can tell me what page to look on in the manual) how to apply the same trans map to the different trans setting? I have skimmed through the manual and can't find where it tells you.
JeffH ( ) posted Fri, 13 September 2002 at 9:05 AM
You have to apply it in the material room.
Select the Material you want to apply the map to, then go down the list to "transparency" and click that plug socket>new node>2D Texture> Image_Map.
Load the map into that node and adjust the dial.
-J.
Blue Moon ( ) posted Fri, 13 September 2002 at 9:28 AM
I understand that. Do I have to load a new map for each setting? Transparency setting and the Transparency edge. How do I get this map on the Transparency edge setting? http://webpages.charter.net/renders/trans.jpg
JeffH ( ) posted Fri, 13 September 2002 at 10:07 AM
Try page 305 in the manual for transparency edge info.
wayneout ( ) posted Fri, 13 September 2002 at 3:31 PM
You do not have to add another map. Here is how I do it. From your new node where the "plug in" is, click on it and drag it to the "Edge trans" Then, they will both be plugged into the same map. I found this out by cheating. I opened a Poser4 file that had a transmap. I then took it into the material room and found out how it was hooked up. You can plug in the Trans and the Trans Edge into the same node. Bill
wayneout ( ) posted Fri, 13 September 2002 at 3:32 PM
You do not have to add another map. Here is how I do it. From your new node where the "plug in" is, click on it and drag it to the "Edge trans" Then, they will both be plugged into the same map. I found this out by cheating. I opened a Poser4 file that had a transmap. I then took it into the material room and found out how it was hooked up. You can plug in the Trans and the Trans Edge into the same node. Bill I can make a screen shot if you don't understand my weak attempt at explaining it.
Blue Moon ( ) posted Fri, 13 September 2002 at 3:51 PM
THANK YOU THANK YOU THANK YOU THANK YOU!!!!!!!! That was driving me nuts!!!!!
