You do not have to add another map. Here is how I do it. From your new node where the "plug in" is, click on it and drag it to the "Edge trans" Then, they will both be plugged into the same map. I found this out by cheating. I opened a Poser4 file that had a transmap. I then took it into the material room and found out how it was hooked up. You can plug in the Trans and the Trans Edge into the same node. Bill
You do not have to add another map. Here is how I do it. From your new node where the "plug in" is, click on it and drag it to the "Edge trans" Then, they will both be plugged into the same map. I found this out by cheating. I opened a Poser4 file that had a transmap. I then took it into the material room and found out how it was hooked up. You can plug in the Trans and the Trans Edge into the same node. Bill I can make a screen shot if you don't understand my weak attempt at explaining it.
Anyone know (or can tell me what page to look on in the manual) how to apply the same trans map to the different trans setting? I have skimmed through the manual and can't find where it tells you.
