Sat, Jan 25, 6:42 PM CST
Subject: Need Help adding new texuters to Bryce
Dark_Raven ( ) posted Thu, 03 October 2002 at 10:13 AM · edited Sat, 25 January 2025 at 6:35 PM
Can anyone help me a little here, I go to material editor select import a new jpg i want to use for a texture and nothing happens, now I read somewhere that cube in the preview must be set to white and maybe im not doing it right but when i try to add my new jpg to make it a mat file nothing happens. Also one more question while i have your attention say I creat a building in Bryce and I want to do detail window textures, how do I need to do that do I need to export the whole building into UVMapper or what, if you can explain that process to me as well I be your new friend...:-) Dark_Raven
Rochr ( ) posted Thu, 03 October 2002 at 3:20 PM
You cant import a jpeg from the materials editor window! Use this small tutorial to add a jpeg as a texture!
Then, while the object is selected, go to the material editor a nd click "ADD".
That will make the jpeg to .mat!
Hope this helps!
Rudolf Herczog
Digital Artist
www.rochr.com
Colette1 ( ) posted Thu, 03 October 2002 at 11:18 PM
Hey this is great I was wondering how to do this too! Thanks. Now if I could just figure out how to get the print to wrap around the mug I'd be in business(figure of speech):))
dampeoples ( ) posted Thu, 03 October 2002 at 11:19 PM
Question about the .jpg's being turned into .mat's. Is there a way to add more than one at the time? Or a limit to the number I could install
Colette1 ( ) posted Thu, 03 October 2002 at 11:22 PM
Now that I am looking at the picture here you can't see the shadows from the letters too well, does anyone know how to get them to "wrap" around the cup?
johnpenn ( ) posted Fri, 04 October 2002 at 12:40 AM
Colette, In Rochr's "mini-tute" where it says Parametric, change that to Cylindrical and it will wrap. There's a bunch of options, and they're good to play with. But I think cylindrical will do what you want.
johnpenn ( ) posted Fri, 04 October 2002 at 12:41 AM
dam peoples, instead of clicking "Load" to add a texture, click one of the empty boxes instead. You can load a bunch (one at a time) that way.
Zhann ( ) posted Fri, 04 October 2002 at 5:00 AM
Thanks for the info guys, it is appreciated! :>
Bryce Forum Coordinator....
Rochr ( ) posted Fri, 04 October 2002 at 5:23 AM
Clicking on the empty boxes does work for the first frame, but youll still have to load frame 2( transmaps etc)! Of course, you can also use copy/paste, but its just a basic tutorial... :)
Rudolf Herczog
Digital Artist
www.rochr.com
Aldaron ( ) posted Fri, 04 October 2002 at 7:33 AM
Collette, are the letter part of the image or are they an object?
Colette1 ( ) posted Fri, 04 October 2002 at 9:37 AM
The words are a separate object made in Elefont. It works great on flat objects as I can place it so close to something you can't see the shadows,
Rochr ( ) posted Fri, 04 October 2002 at 12:13 PM
No need to be "crazy" by yourself, im with you there... :) Havent counted my mat-files, but its somewhere around that amount...+ a couple of cds filled with "good to have"-mats... :)
Rudolf Herczog
Digital Artist
www.rochr.com
Zhann ( ) posted Sat, 05 October 2002 at 12:24 AM
I have 5 cds full, everywhere I visit I always check for files to download :}...
SevenOfEleven ( ) posted Sun, 06 October 2002 at 3:14 PM
Unless you are doing a skyscraper with lots of glass windows, I would be careful with using texture maps to simulate windows. If you texture map the whole building with a high tiling value, it looks kinda lame. All the windows look exactly alike and/or they are too close together. Might be better to make floors and use a similar set of textures for each floor.
Zhann ( ) posted Tue, 08 October 2002 at 1:22 AM
Was that a hiccup?...:)
