Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Forgot to add - my morphs and texture, Yann hair. :)
Haha, David Bowie - in his "Aladdin Sane" guise.
Absolutely immediately recognizable. The cheekbones need to be slightly more prominent, or maybe it's that the cheeks should be a little more sunken in. Also maybe a slight taper applied to the head to make the forehead wider. I think the eyeshadow for that make-up is a little more pink and the red of the lightning bolt a little more orangish. Still, it's definitely not mistakable for anyone else. ;) Perhaps a slight 'sheen' to the make-up to give the look of grease-paint, and a regular skin bump under it all would make it almost perfect! Good work!
Thanks for the replies, people. You're right about the sunken cheeks, although he wasn't a full-blown (or is that snorted?) cokehead at that time, so he wasn't as corpse-like as he became in 1976. I'll try the taper suggestion, too. As for the colours, well I have 3 or 4 different versions of the artwork and they're all slightly different, so I'm going for a middle ground with those. Good point about the grease paint, though; I'll play with lighting tomorrow and see what I can come up with.
Try arching the eyebrows-- keep them low-- and rounding the eyes just a bit. You've done a great job. I'm a Bowie fanatic and this is really recognizable now. Still looks too healthy, have no idea what to do about that.:)) Well, yeah, I do, don't be afraid to paint in the painfully veined neck tendons and a good--well, bad-- bump map would thin that skin. Gotta take it from healthy Utah to too many ciggies paper thin English skin. Nothing works as well as a splotchy brush-- you're doing this with multiple layers, right? Emily
Right, thanks once again, everyone. I'll work on the reshaping and tweak the bump map. I'll post another version later. :)
