Tue, Feb 18, 7:25 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: WIP. Comments, please.
SamTherapy ( ) posted Thu, 17 October 2002 at 8:24 PM · edited Wed, 05 February 2025 at 11:18 PM
Straight P4PP render, no postwork. Still needs tweaking.
SamTherapy ( ) posted Thu, 17 October 2002 at 8:27 PM
Forgot to add - my morphs and texture, Yann hair. :)
Jackson ( ) posted Thu, 17 October 2002 at 9:08 PM
Drat, I can't remember his name! Ziggy Stardust? You know, Major Tom to ground control? Oh jeeze, what's his name? Damn!
SamTherapy ( ) posted Thu, 17 October 2002 at 9:13 PM
Haha, David Bowie - in his "Aladdin Sane" guise.
depakotez ( ) posted Thu, 17 October 2002 at 10:05 PM
That looks great, First thing I thought of when looking at it was "Ziggy Stardust!... wicked." I think his cheeks should be a little more shallow/hollow. I don't remember him having even that much meat on his cheeks back then. Tom
hecate ( ) posted Thu, 17 October 2002 at 10:11 PM
Absolutely immediately recognizable. The cheekbones need to be slightly more prominent, or maybe it's that the cheeks should be a little more sunken in. Also maybe a slight taper applied to the head to make the forehead wider. I think the eyeshadow for that make-up is a little more pink and the red of the lightning bolt a little more orangish. Still, it's definitely not mistakable for anyone else. ;) Perhaps a slight 'sheen' to the make-up to give the look of grease-paint, and a regular skin bump under it all would make it almost perfect! Good work!
SamTherapy ( ) posted Thu, 17 October 2002 at 10:18 PM
Thanks for the replies, people. You're right about the sunken cheeks, although he wasn't a full-blown (or is that snorted?) cokehead at that time, so he wasn't as corpse-like as he became in 1976. I'll try the taper suggestion, too. As for the colours, well I have 3 or 4 different versions of the artwork and they're all slightly different, so I'm going for a middle ground with those. Good point about the grease paint, though; I'll play with lighting tomorrow and see what I can come up with.
SAMS3D ( ) posted Fri, 18 October 2002 at 4:24 AM
I love it...Sharen
Hiram ( ) posted Fri, 18 October 2002 at 11:26 AM
Beautiful! The cheekbones should be more pronounced, but I think much of the effect people are remembering was due to the make-up. The upper edge of the cheek color is more sharp.
SamTherapy ( ) posted Fri, 18 October 2002 at 11:43 AM
Thanks for all your comments and advice, you've all been very helpful. Here's the latest version - I don't think I can get it much closer than this now. I added a bump map, altered the colors slightly, tapered and rescaled the head (and made him a touch thinner), played with the lighting and so forth.
Valandar ( ) posted Fri, 18 October 2002 at 12:27 PM
The lips could be lowered a bit more... and the bottom lip should be a bit thicker. But outstanding work!
Remember, kids! Napalm is Nature's Toothpaste!
wolfshade ( ) posted Fri, 18 October 2002 at 1:03 PM
actually i think if you stretched the head to say maybe about 110% on the y axis..it would be closer to the picture and eliminate the moving of the lips..maybe
wolfshade ( ) posted Fri, 18 October 2002 at 1:06 PM
oh duh...and i forgot...the nostrils seem a bit wide...if you can maybe thing those out a bit it would damn near perfect...and raise up that philitrum....sorry...i'm just a perfectionist...lol but, great work :D
queri ( ) posted Fri, 18 October 2002 at 1:08 PM
Try arching the eyebrows-- keep them low-- and rounding the eyes just a bit. You've done a great job. I'm a Bowie fanatic and this is really recognizable now. Still looks too healthy, have no idea what to do about that.:)) Well, yeah, I do, don't be afraid to paint in the painfully veined neck tendons and a good--well, bad-- bump map would thin that skin. Gotta take it from healthy Utah to too many ciggies paper thin English skin. Nothing works as well as a splotchy brush-- you're doing this with multiple layers, right? Emily
SamTherapy ( ) posted Fri, 18 October 2002 at 1:26 PM
Right, thanks once again, everyone. I'll work on the reshaping and tweak the bump map. I'll post another version later. :)
SamTherapy ( ) posted Fri, 18 October 2002 at 5:46 PM
Well, here's the latest version.
