Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Thanks for the quick responses.
ScottA - I checked in UVmapper and in Deep Exploration (a 3d model translator) and the name is the exact right name. In my tests, I hardly change any aspects of the model, except moving some vertices, so I don't have much of an opportunity to mess up the names ;)
I did find something interesting in UVmapper, though. There is an extra group called "default" in the modified Michael figure. It does not show up in Deep Exploration or Maya but does appear in UVmapper.
Vel - I checked the normals in Maya and everything is fine. However, I do not know how to flip normals in Poser, so maybe there is a problem once it is imported.
I was able to use a different method to export and import the modified Micheal that keeps the left forearm, but the morph targets and texture maps are messed up.
Thanks for the help, I'm still looking for the answer.
Sometimes the programs you model in will do something when you save them. Cinema4D for example puts a 1 at the end of body parts. Then truncates all the other numbers to a higher number. That causes the same invisibilty issue you're having if you don't change the names back in UVmapper. The first thing you should do is make sure you're hunting for the right problem: Import your .obj file intop Poser as a prop. If the forearm is visible. The problem is something in the naming structure. If the forearm is not visible. The problem is with the mesh itself. ScottA
ScottA - Good advice. Yea, I have imported the model as a prop and everything is there.
So, I believe it is either a naming thing or Maya is adding an extra group that is taking the place of the UVs of the left forearm. The reason I think this is because when I load the original p4 man model into UVmapper there is 53 groups, but when I load the Maya modified p4 man there is 54 groups. The default group is at the top of the list. Also, it does not seem that there are any actual UVs for the default group. Is there a way to delete groups in UVmapper? I'm relatively new to UVmapper, of course I will be digging through the manuals soon.
Thank you very much.
Here's what I'm doing:
1)Exporting Michael out of Poser as an obj
2)Importing Michael into Maya and making some modifications in Maya
3)Exporting the modified Michael out of Maya (note that I am also changing the model link text in the Poser file to reference the modified Michael).
The trouble happens when I open the modified file in Poser. Everything looks great except for some reason the left forearm is not there. Morphs work and textures are there. Everything else looks fine, but there but no left forearm. I have checked visibility. I have checked and switched normals. I have opened the model in Deep Exploration and it looks fine there.
I've been checking in both Poser 4 and 5, and I am using Maya 4.5
Any hints, link, ideas, solutions, or pity would greatly be appreciated.
ds
