Yes, you can multireplicate along a path, I used it with metaballs to form a branch, you can offset them by a numeric value to space them along the path, but for the life of me I couldn't explain how, I read it in Realworld Bryce and followed the instructions, there's a post here somewhere on metaballs that explains how to do it...
Bryce Forum Coordinator....
If i'm correct Dark was lookin for a way to do away with moving each one individually? If so here's a workaround that can save alot of time if you're trying to align ALOT of objects to your path... Get started by aligning and spacing several of your objects.. for example 20 spheres to your path... Now select ALL spheres... press CTRL + D to duplicate them... now for the tricky part... Save your work/scene and close it. Reopen your work... all the spheres should still be selected. You can now click on them (as a group) with the mouse and move them as a group. Repeat this several times and you eventually can move as many of them grouped as you can muster. If you omit the save..exit.. reopen steps.. the objects want to snap to the start of your path.. VERY annoying. Drawbacks? Well as Elect stated, the spacing is not consistant.. so as you move the group you may have to adjust the spacing for some of them individually. How's that for jumping through hoops? If someone (Zahnn help!) can find the other way please postttt. Blue
And as a side note once you have the objects constrained to the path you can repose the path and get a new shape without having to touch the objects again. But if you duplicate the path all the objects are duplicated too except they are no longer constrained to the path(though they are still linked) thus the duplicated one can no longer be reposed. Do a search for my Oak tre on the forum, it was created with paths and metaballs.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=950827
Here's the link to the thread.It took me a few hours and several Bryce 3d crashes to learn this today, but maybe someone can use it. Anyway I had fun, now if Airbourne will just deliver my Bryce 5! turns out they couldn't find the place and its been sitting there since Wednesday. Needless to say I were ready to ...
well we won't go into that. anyway I learned someting today
Thanks Darkginger for asking the question and electroglyph and others for giving me the pieces with which to put the puzzle together (along with a little help from the not completely useless manual.)
The first step in doing someting is knowing that it's possable.
cheers,
it seems like the main key is to remember to only replicate through the x-axis. The way it looks, is that no matter where you are on the path, the start point could be considered the left, and the end point could be the right, and if you think of it that way, perhaps it can help as a reminder of how to do this.
Is it possible? I've just about got the hang of aligning objects to a path, and can manually shove them around it, but it's a pain having to space them all out evenly by hand, so I wondered if there's a way of multi-replicating so they'll stick to the path? Any suggestions appreciated!
