Tue, Feb 4, 9:45 PM CST
Subject: vic 2 mike 2 steph eyebrows
ghost13 ( ) posted Sun, 01 December 2002 at 1:51 PM ยท edited Tue, 04 February 2025 at 5:22 AM
cna someone point me in the right direction on how to eliminate or modify the groucho marx eyebrows that come with these characters? their huge lol thanks in advance
thgeisel ( ) posted Sun, 01 December 2002 at 2:02 PM
select the head, and in the properties you find a morph "brows gone" set this to 1. Other way in the mat properties select a mat "upper eyebrows" set both transparencies in poser 4 to 100% in poser 5 to 1.
rogergordian ( ) posted Sun, 01 December 2002 at 3:36 PM
ARGH. I can't believe someone still thinks "brows gone" is a solution. Find some good tutorials.
ghost13 ( ) posted Mon, 02 December 2002 at 12:14 AM
thgeisel the 'brows gone' part worked when a texture was applied to the head, everything looked more normal but setting the transparencies to 100% in pro pack turned them into big white santa type groucho marx brows thanks for the help, i can work with this roger if ya know of any 'good tutorials' (which i have been looking for) i'd be happy to follow the link
Desdemmonna ( ) posted Mon, 02 December 2002 at 6:51 AM
Ron Knight's tutorials are back up again...here are direct links to the respective sections in reguards to your question (materials settings)for the 'groucho marks' upper eyebrow. Victoria: http://www.ronknights.com/victoria/upeye.htm Mike: http://www.ronknights.com/mikeset/upeye.htm These of course...are mostly for textures that don't have eyebrows painted on/use a transmap. If your using a texture map that DOES have eyebrows painted on...eyebrows gone dial is a definite must. Once again...links to materials settings for this instance. Victoria: http://www.ronknights.com/victoria/eyebrow.htm Mike: http://www.ronknights.com/mikeset/eyebrow.htm Hope this helps some! -Des
ghost13 ( ) posted Mon, 02 December 2002 at 9:02 AM
thanks des it does help, links are perfect much appreciated i'm on the right track now btw nice renders ya got posted TeeJ
ghost13 ( ) posted Mon, 02 December 2002 at 9:07 AM
thgeisel now i see what you meant by the 2nd part of your suggestion from the tutorials thanks again TeeJ
